Question about RoadPro Road Pro 12 Volt Dc Portable Battery Jump Starter & Air Compressor 12V Dc Portable Battery Jump Starter & 260 Psi Air Compressor
Can a Duralast jump starter kit start a car while plugged into an outlet?
I need to jump my car and do not have hours to wait for the Duralast kit to charge all the way. A friend is coming to help, but I am wondering if I can run an extension cord from the house to the kit so that it is plugged in while I attempt to start the car. Could this damage the house, outlet, starter kit, or my car in any way?
The charger to a Jumpstart charges at a low rate (300mA to 500mA) and will not push enough current to start a car. Best to have Jumpstarts recharged every 6 months to be ready for emergency.
Posted on Sep 17, 2013
SOURCE: I have a duralast jump
Adaptor for DURALAST BP-DL
Model HB-208b
Input AC 120V 60Hz
Output DC 12V 450mA
Posted on Jan 17, 2009
SOURCE: I have a Duralast Gold Jump Starter.I charged the
I had the same problem today and I found out that is the battery itself causing the problem. It's actually the connection. So disconnect the battery and scratch the battery pins and connect them again. If you can dip them in soda water (no sugar in it!) that would be better.
This problem starts as the battery beggins to get old and combined with cold weather outside becaomes a receipe for disaster. Anyway, if you can't afford a new battery at the moment remove your battery from your car (but first try and drain it totally...leave a light on or something) and recharge it (fully) with the duralast (havbe the duralst plugget into a outlet). It will have your battery working for couple of weeks.
Posted on Jan 21, 2011
archaeology
  • 662 Answers
SOURCE: My Duralast Gold Jump Starter does not take a
There is a battery inside which may need to be replaced. To check, run the compressor (it runs off
the battery) - if the compressor dies quickly, then the battery has failed to charge and would
need to be replaced. You may want to check your Warranty Management software (or
shoebox) to see if your Starter/Air Compressor is still under warranty - if so, replace it.
Duralast products are carried exclusively by AutoZone, Inc.
The Duralast web site: www.duralastparts.com is useless - it only shows automotive parts,
and I cannot find the product at www.autozone.com, so it seems that AutoZone fails to support this
product with replacement batteries or other replacement parts (or even an online Users manual).
Posted on Feb 21, 2011
motor1258
  • 6674 Answers
SOURCE: I have a Duralast Jumpstarter Gold. It is fully
You should be able to try it immediately, or whenever you need to.
Posted on Dec 29, 2009
anil_valayil
  • 218 Answers
SOURCE: I have a Duralast Jump Starter BP-ELG and the
Since you say, it is a 12v DC portable Jump starter, the battery inside it is also a 12V battery. You need a 12V charger (eliminator, wall adaptor or whatever you may call it) Regarding current, it could be anything above 500 mA. Better if it is a 1A or 2A or even 3 A depending on the amount you are willing to spend. Now is the most important part. The polarity. I do not know it since i do not have this equipment. Most chances are that you will find (on the RoadPro) a circle and a dot (along with a +VE and -VE marked near it) around where you plug in the adaptor. For most equipments the outer circle is the -ve and the inner dot is the +ve. (unfortunately this could be reversed in some equipments) If you can find this notation on your RoadPro you are lucky. Just go to any electronic shop and buy an adaptor (12V) that matches this circle and dot notation. The same symbol representing polarity will be marked on the adaptor also. Else, you will need the assistance of someone who can check the continuity using a multimeter. This way you can find the polarity. It is pretty easy. Hope this helps.
Posted on Jan 20, 2010
My duralast 750amp jump starter did not jump my truck off why?
probably low charge or wearing out , use a jump from a running vehicle and see if yours starts, getting the earth cable to a good earth is vital
Nov 18, 2014 | Cars & Trucks
I have a duralast 900 jump starter that reads FL when plugged in won't charge . new unit any help?
I called the Service Call Center and they said that "FL" means the battery is fully charged, which is the way it is shipped from the manufacturer.
Aug 20, 2013 | RoadPro Road Pro 12 Volt Dc Portable...
Duralast jump starter says charged but it's not?
You already have a bigger problem. The internal battery won't hold a charge. Time to replace it.
Jul 05, 2013 | Air Tools & Compressors
My Duralast Gold Jump Starter does not take a charge when I plug it in to the wall socket. While the charger is connected to it, it will show the green light. But when I remove the charger, after...
Feb 20, 2011 | RoadPro Road Pro 12 Volt Dc Portable...
I have a duralast jump starter BP-DLG. i cannot get it charged. i have pluged it to a standard electrical outlet and now it is dead. i have used it in the past and it worked very well. i mis-laid my...
My Duralast Gold Jump Starter Model BP-DLG will not take a charge. When it is plugged into the charger it shows fully charged; when I unplug it it goes dead, will not start and the red light shows. I have used it about 4 times in less than two years.
1995 Ford Taurus not starting. Sometimes it starts and sometimes the starter won't turn over not even a click. Wait half an hour and it may work fine. Starter less than a year old as is the battery
Even though new-ish, I'd still suspect the battery has no charge, ask a friend to give you a jump start. Then give your car a good run, 20 miles, if is doesn't work again the next day either the battery fails to keep its charge or the alternater isn't charging it. A good garage will be able to test either for you, you'll need to change the failing part.
Feb 17, 2011 | 1995 Ford Taurus
I have a Duralast Gold Jump Starter.I charged the battery green light is on but when I try to start a car engine it looks like the jump starter does not have enough power to do the job. Note.- I acquire...
Dec 03, 2010 | RoadPro Road Pro 12 Volt Dc Portable...
Need a charger to charge my Jump Starter BP-DLG
Need confirmation that the AC adaptor for Duralast jump start model BP-DLG is a 12volt 450ma. Is this correct or do I need something else?
Nov 06, 2010 | RoadPro Road Pro 12 Volt Dc Portable...
RoadPro Road Pro 12 Volt Dc Portable Battery Jump Starter & Air Compressor 12V Dc Portable Battery Jump Starter & 260 Psi Air Compressor Logo
1,092 people viewed this question
Top RoadPro Air Tools & Compressors Experts
Lawrence Oravetz
ray gallant
 Bob Oppenheimer
Bob Oppenheimer
Level 1 Expert
Are you a RoadPro Air Tool and Compressor Expert? Answer questions, earn points and help others
