Question about Logitech Z313
Loud noise wen i power up on remote or pod..just repaired brken wires,,help!!
Makes a loud noise wen turning right
Can be many things. Balljoints, hub bearings, C-V joints, and tierod ends can all make noise. You need to have someone lift the front components and manually check for play.
These components can be checked by someone doing front-end Alignment work. Some signs can be seen on tires with unusual wear patterns.
If you replace some of these components, a front-end Alignment would be a good idea. There is a remote chance that a loose brake caliper can make a noise you can hear. More likely is a weight bearing component like a strut, or the other components I mentioned.
Aug 13, 2013 | 2000 Lincoln LS
My washer makes alound grindin noise wen trying to empty
1) most Noises coming from washing machines coming during the cycles of SPIN .Clothes load can be un-balance. Stop the machine and balance the clothes.Start again, and repeat the step if necessary.
God bless you
Jun 28, 2012 | Washing Machines
I have a loud continual squeaking in the front of the car
a squealing wen you tern the steering will or rev the engine is a belt. or bearing tenchoner Polly.you need some one with a good ear .it may be loos starter .maybe.
Feb 14, 2012 | 2006 Ford Focus
Bought a used Tassimo, is it supposed to make loud noise when brewing?
The water tank is probably not seated correctly.It can look as though it is, but you have to make sure the forward edge of it has been tilted so that the angled indentation in the plastic exactly mates with the machine.If it doesn't, water is not drawn from the tank, the pump makes a noise, and steam comes from the pod area.
Sep 24, 2011 | Braun Tassimo Espresso Machine/Coffee...
I have a westpoint washing machine wen it is spinning it make a lot of noise serial number wtw 500. it is a 5kg. can you help me with this problem.
Thanks for choosing FixYa and welcome to the site. You need to check your spin bearing and the motor drive. If the noise is only during spinning, you need to check these. Anytime a washer makes loud noises during spinning, always check the spin bearing and motor drive.
Apr 24, 2011 | Washing Machines
I have a sony cdx-gt45ip wen playing a cd or using the tuner my sub works but wen using the aux all bas dissaperes, the sub still has power why is this happening ?
use the blue/white wire (amplifier remote turn on) to turn the amp on instead of the blue wire (power antenna remote turn on). the blue wire turns off when leaving tuner mode.
Mar 02, 2011 | Sony XPlod CD Player w/MP3 Playback...
We heard a loud pop & now the lights won't work. Tried new bulbs & nothing. Can we order/buy a new light assembly?
Best to look for a wire that shorted out ( made the popping noise) and repair it.
Turn the power off and disessable the fixture carefully looking for a wire that the insulation ha worn through or that has broken or come free. You'll also probably find a nice burn mark.
Check the breaker that the light is on also ... it may be tripped
Jan 24, 2011 | Hunter Fan Co. 60 In.Brushed Nickel...
My turbo is realy realy loud wen excelarating u can hear it befor u see the van help its a renault trafic
Hi
The turbo may have a split hose causing a loud whoosing (only way I can describe it!) noise. If the noise is a screeching noise it will be the bearings in the turbo.
Does the Trafic have any blue smoke coming out of the exhaust? If so this would point to the turbo being the culprit. If you have a loss of power this would be a split hose.
If the noise is only when the engine is under load, then a again I would be looking for a split hose.
Best of luck.
Jul 07, 2010 | Renault Fly 1:32 5 Turbo Slot Car -...
My washing machine makes a loud banging noise wen it reaches the spin cycle only happens wen it is a full load not a half load
Form the front of washer, spin drum by hand, and if it fees rough, or is rumbling, then the main drum bearings are worn.
If no noise from drum, then could be worn shockers, or the washer is not properly levelled, or concrete balance weight, I'm afraid it is a process of elmination.
Hope this helps.
Jan 26, 2010 | Hotpoint WMA66 Front Load Washer
Tuner works but when cd or i-pod are selected they indicate theyare playing but no sound.
Is your stereo sytem amplified? if so then the remote turn on wire may be hooked up to your power antenna turn on wire. The amp needs to be connected to blue w/ white strip.......not solid blue. The solid blue turns off to lower a power antenna when the tuner is not in use. Blue with white always stays on with tuner cd or ipod.
May 23, 2009 | Car Audio & Video
Logitech Z313 Logo
20 people viewed this question
Top Logitech Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
JP Services
JP Services
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
