Question about Hisense Televison & Video
Hisense tv blurry
The letters and numbers are all blurry, On channels like ESPN when they start moving across the screen, you cannot read what it is saying. How can i fix this.
jerryg50
  • 1667 Answers
SOURCE: plz help me out i really like this tv i dont wanna toss it out
On some of these models, hold down the Menu key on the front panel for more than 10 seconds. On some models, use the menu key on the remote for the same results.
If the above does not work you should call the tech support for your set.
Jerry G.
Posted on May 21, 2008
  • 17 Answers
SOURCE: I bought a new 47 in flat screen TV and looking
Hello cruisinptl1
Let me help you today. ok so what kind of flat screen is it some flat screens are blurry depending on the brand, You might also want to get it calibrated by the store you bought it from it cot around 200 dollars to get it calibrated but thats really the only way to get the picture just right
Posted on Apr 16, 2009
dsacco86
  • 1077 Answers
SOURCE: I have a one-year old 37LG50 TV with a direct line
Assigning a station name
Select SETUP.
Select Manual Tuning.
Select TV.
Select Name.
5
Select the position and make
your choice of the second character,
and so on.
You can use an the alphabet A
to Z, the number 0 to 9, +/ -,
and blank.
6
Select Close.
7
Select Store.
Posted on Jun 07, 2009
eagle338
  • 4889 Answers
SOURCE: i have a samsung dlp
What do the lines look like? Are they colored or just plain white/grey lines? It sounds like the DMD is faulty which is a notorious problem with this set. Just want to confirm.
Posted on Nov 23, 2010
  • 33 Answers
SOURCE: cant change channels with remote or side of tv -
Your TV is most likely locked to that station because it doesn't have any other channels programmed in.
In the menu for the TV, run a channel scan. This will take probably 30-45 minutes for most TVs and will program the available channels into the TV so that they become available.
Posted on Mar 15, 2011
Why is the text blurry on my 55" Hisense HD TV?
Could be many items but most likely the main video board needs updating or replacing. Google your model number and see if there is a software update that you need on your set.
Dec 11, 2014 | Hisense Televison & Video
On certain channels the TV has a blackscreen come upwith letters across it???
This is probably the text box function of the closed captioning decoder. Look for the closed caption button on your remote and turn it off. It might be labeled "cc" or "ccd". In some cases you may have to go into the menu to turn it off.
I hope this is helpful to you.
Bobya.
Oct 18, 2010 | Hisense TC14FS68 TV
When TV first turned on often has blurry dark lines
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts...
Jun 26, 2017 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
I'm having double vision problems, more so when reading lettering on screen. I have no prob with color. If looking at espn the lettering is blurry and double.
The conversion ics are probably going bad another common problem with this unit is fluid leakage on the convergence module this might be the problem also you must start out by seeing if that is the case both problems are repairable
May 19, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Pt61g42v.this is a panasonic 61 FOCUS OUT
my tv flat lined the screen went black with a twisted line across the screen what is the problem?
May 13, 2010 | Televison & Video
Insignia 32" TV Thin line across screen 1-2" from top
This is usually caused by bad capacitors in the vertical circuit. If you have an electronics background you should be able to find the defective ones with an ESR tester .
Dec 16, 2008 | Insignia NS- 27" TV27 TV
High def programs
You need to change the setting on your tv to see the whole picture on those channels (look for display button)
Dec 13, 2008 | Televison & Video
Dim and blurry
try adjusting the focus control located on the flyback of the tv. good luck
Jan 31, 2007 | GE 32GT740 32" TV
Televison & Video Logo
69 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
