Repair pad for anodyne therapy model120
Pad wont work led green light will not light
When I want to print it says error 6C10 switch off switch on. Doesn't work!
that indicates full waste ink pads/absorbers. to reset the counter try this:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button.
(DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s)according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
any way if the absorber/pad is full, it have to be cleaned!
Sep 20, 2011 | Canon PIXMA iP4600 Color InkJet Photo...
How do I change the Waste Ink collector on a Pixma MP170?
Cleaning or changing the pad is a messy project. This ink pad reset will reset the printer ink use conter to new status and your pad full message will be gone. This is a common occurance with Canon printers and the fix causes no harm. I reset my own MP470 about two years ago without incident.
This reset has been sucessful on many MP150 and simular units and should work on your MP170.
The second works on models with different control pads simular to theMP470.
printer powered off but connected on power source , you must:
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button.
Waste ink full reset
These are the instructions which worked for me on my Canon pixma mp470:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Mar 27, 2011 | Canon Office Equipment & Supplies
Error code 5100 check printer
This is probably a Canon printer and code. If so, it is the "ink waste pad is full" warning. There are work arounds to keep from having to clean the pad. Here are two methods to eliminate the message. The only other ways are to take it to a repair shop or dismantle the printer and clean the pad yourself. Not advised, This is messy.
This works on many different printers.
mp150 and simular printers:
Jan 22, 2011 | Office Equipment & Supplies
I'm getting a message that my overflow ink tank is full. How do I fix this?
You can reset the waste ink counter:
However, you also need to blot the ink out of the waste ink absorber. The "tank" is a pair (usually) of plastic squares with a small piece of absorbant pad in the square on the sides of the carriage. For best results you need to partially disassemble the printer. Some find just drying the pads on a bunch of towels until it stops transferring ink is sufficient. (Also dry excess ink from around the plastic.) Otherwise, rinse the pads until the water runs clear. Then let the pads dry (blotting helps) completely. Without the cleaning step, you can get ink smearing on the back of the page as well as inside the printer.
I hope this helps.
(the counter is set to a number of pages that is the expected lifetime of the printer under normal use. Other failures may come up soon.)
May 19, 2010 | Canon PIXMA iP90 Mobile Printer
Getting Waste Ink Asborber is Full message, What do Ineed to do to fix it?
The waste ink absorbers are usually small pads at the bottom of the printer. You need to pull them. This is usually messy and can require basically taking apart the printer. Then either replace (contact a service center) or rinse clean the pads (just running water works). Once the pads are dry (if reusing them), reinstall them.
Then reset the counter:
Do not do the reset until the ink absorber is cleaned. The waste ink will get everywhere in the printer and the pages you print.
I hope this helps.
(most ink jets are really designed to be replaced if the waste ink absorber is full - the other parts may soon fail too.)
May 02, 2010 | Canon PIXMA iP90 Mobile Printer
Re my pixma mp13o printer. message"ink waste tank almost full" how do I rectify it. tried switching on and off and unplugging for 10 seconds.
Three choices. 1. Take it in for repair. 2.Take the top off and remove and clean the pad. 3. Use the following instructions to reset the printer and continue printing. I chose number 3 and haven't had any problems.
These are the instructions which worked for me on my Canon mp470 and has work on many other Canon models:
1) Close the print2_bing.gif head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
Mar 24, 2010 | Canon PIXMA MP130 All-In-One InkJet...
How to reset absober full mp198
PLEASE TRY THIS, Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter
Feb 26, 2010 | Canon PIXMA MP160 All-In-One InkJet...
For Canon MP210 absorber is full
These are the instructions which worked for me on my Canon ip470 and has work on many other Canon models:
Feb 16, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Waste inki absober is full. The indicator orange
You can remove the top of the printer to remove and clean the pad or reset the printer and continue without cleaning.
These are the instructions which worked for me on my Canon pixma ip470 and has work on many other Canon models:
Feb 15, 2010 | Canon PIXMA iP90 Mobile Printer
How do I take out the over flow cartrigde on a mp130? Printer wont print it says i need to empty my over flow and I don't know how.
SAome have a pad some have a small tray. This cancelled the warning and reset the printer for use.
These are the instructions which worked for me on my Canon pixma ip90 bought August 06:
Dec 18, 2009 | Computers & Internet
18 people viewed this question
jasbo
jasbo
