Question about Apex Digital Televison & Video
What does it mean when theres a picture of a key on the bottom left screen
    Sergeant:
  • 198 Answers
  • If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired.
  • If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels.
  • If you have a GT2011J or GT2011S Television, hold the (Display) button for 10 seconds, it will unlock the screen. If password or code is requested, try 3308 or 6688.
  • Posted on Nov 27, 2012
    I have a Swintec 8016 that doesn't have a "print" key. How do I print stored files?
    Hi Linda, Once upon a time, I worked on Swintec typewriters. When you speak of printing do you mean to an external printer or just allowing the thy writer to to type out of memory? What kind of printer, what type of external port. Did it ever work? With what printer? I,m not familiar with this particular typewriter , give me as much info as you can , I mean anything you can think of . The smallest detail can tip the scale. You stated there is no print key, that tells me there must be an alternative way to print. let me know what you find out. If you can take a picture of the plug ports on the back and the keyboard, in this case a picture is worth more than words! Good luck. Bret... I was a typewriter tech for 7 years there are not many of us left.
    Jan 04, 2015 | Swintec 8016 Typewriter
    Screen dimmed
    goto your control panel and open display settings you might be able todo it from there.
    Apr 01, 2014 | Acer Aspire Computers & Internet
    The picture on my monitor is completley turned to th e left, and is now sideways with the task bar on the right, the icons on the bottom and my wallpaper (husbands picture )looking ike he is falling out of...
    first hold the keys Ctrl + Alt and use the arrow keys if this fails
    if you are running windows Vista or Windows 7 right click on the desktop, and select personalize, when the window pops up select Display (lower left) you should see advanced settings .. in there you will see screen orientation that should allow you to fix it
    Mar 03, 2011 | Gateway 22" Widescreen Flat-Panel LCD HD...
    How brighten the screen?
    Look on your keyboard on the "f" keys (f1, f2, etc...) for a symbol that looks like a sun or shining light. Something that would indicate brightness. Now, hold down the 'fn' (function) key on the bottom left of your keyboard and then press the backlight key you just found.
    Mar 01, 2011 | Gateway MX6214 Notebook
    How to change setting picture just opposite
    If opposite means that you want to rotate the image or picture for projector mount in the ceiling.
    KEYS location: (keys are located back side of the projector there is 2 keys 1 for menu and second is a joystick witch have 4 arrow keys and center press is a enter key)
    Press MENU button to display the menu screen.
    then use joystick UP and DOWN to select the OPTION menu. Press joystick for ENTER to display the option screen. Then press joystick UP and DOWN to select INSTALLATION.
    Then press joystick RIGHT and LEFT to select your required image rotation there is four type of rotations.
    1. FRONT DESK
    2.FRONT CEILING
    3.REAR DESK (A translucent screen is required for rear projection)
    4.REAR CEILING (A translucent screen is required for rear projection)
    If opposite means negative to positive so there is no any setting in your projector witch is chang your picture or image positive to negative.
    Jan 21, 2011 | Panasonic PT-LB60NTE LCD Projector
    How do i use the front camera on my nokia 6288
    turn on phone, ake sure that " Desktop " [the name of phone, e.i. METROPCS, etc. is showing on front screen. If not, press what looks like a arrow key facing left or " Back key ". until you see the name of the phone on screen. then on the bottom left or right corner of screen U should see "menu", press that and you should get a list or pix [pictures] of what U want to do. You should see a pix [picture] of a camera. Some were (usually in the center of [left side] pix of speaker, [right side] back key,are the up,down,left,right GO keys. 'tab' to or move to camera. and press center key. there U go.
    Oct 09, 2010 | Nokia 6288 Cellular Phone
    We have a widescreen plasma (Panasonic TY ST05-K). The picture all of the sudden shrunk to about 3/4 of the screen. Fortunately, the picture is not cut-off, so you can see the whole picture. The...
    Hi there! If picture is smaller top to bottom with blank section on top and bottom then check your aspect ratio settings. If blank at the bottom only the Bottom Y-Drive board may be faulty. If blank at the top The Top Y-Drive may be faulty. If blank on the Left (TOP TO Bottom) then the Right X-Drive Board and on the Right, the Left X-Drive Board. May also be bad connections on the cables or flexible ribbon cables. Best Wishes and Good Luck, JUS004
    Aug 23, 2009 | Televison & Video
    I'd like to lock the keypad of my HTC S740.
    To lock the keys so you don't accidently activate the phone whilst carrying it about.
    Press and hold down the "end call" button ( phone handset down picture) until Unlock shows at bottom left screen
    To unlock, press the top left button, above the "start call" button (phone handset up picture), then press the * button (bottom left).
    You get a screen prompt to press * to unlock
    Mar 06, 2009 | HTC S740 Smartphone
    I JUST BORT AN ADVENT NOTEBOOK HOW DO I PUT ON THE WEBCAM AND BLUETOOTH
    hold the Fn key located in the very bottom left hand corner and at the same time, press one of the F keys numbered 1-12 with the picture of a little webcam on it. a picture will appear in the right hand corner of the screen and this means that next time you click your webcam it should be on. the webcam key on my advent notebook is F6 and i have the model 4489, it may be different for other models. i don't know how to do bluetooth - have a play with the other F keys.
    Dec 21, 2008 | Recoton Advent Advent Q2035A 20" TV
    Apex GT2015 20 inch television
    TVs Power Supply Unit may be faulty and you will have to get it fixed.
    Opening up the TV may void the warranty.
    Its better talk to TV Manufacturer's Tech Support.
    Jan 09, 2008 | Apex Digital GT2015DV 20 in. TV/DVD Combo
    Televison & Video Logo
    54 people viewed this question
    Top Apex Digital Televison & Video Experts
    Jaime Hernandez
    Electro Med Services...
    Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
