Question about Belkin N1 Vision Router
How format a HD to FAT32 if the options are only NTFS and exFAT?
I'm trying to format this drive to FAT 32 on windows Vista but it is only giving me this two options; NTFS & exFAT. I did the exFAT (mac and windows can see it but not the router.) Are there any other options this is available on the net?
  • Belkin Master
  • 2,072 Answers
Open a command prompt. Start, Run, type cmd <enter>
If the drive you want to format is F: for example type
format F: /FS:FAT32
Posted on Nov 27, 2012
How to remove write protection from sony hd-e1
PC & MAC use different file systems.
It sounds like your hard disk is formatted as NTFS. NTFS will allow a MAC to read from the disk, but not write to it. You need to re-format it using FAT32 (if your MAC is older) or exFAT(if your MAC is fairly new)..
FAT32 will allow a maximum partition size of 2TB(when formatted from a MAC) and a maximum single file size of 4GB.
exFAT will allow pretty much any file size.
NB:Formatting a hard drive DELETES ALL FILES on the hard drive, so backup whatever is important before you re-format it.
1. Open Applications > Utilities
2. Choose you hard drive from the list on the left
3. Choose the "Erase" tab and choose your desired format (FAT32/exFAT)
4. Type in a new name..Click "Erase"
Apr 10, 2014 | Sony HD-E1 1 TB 2.5" External Hard Drive -...
Tip
How to Convert NTFS External Hard Drive to FAT32?
My friend Michael bought an external hard drive last month, yesterday he ran to me and ask how to convert external hard drive from NTFS to FAT32 safely and easily? I was so curious about why does he want to convert NTFS to FAT32; he said NTFS partition can't be read by DOS system. Since protecting data and files, I recommend him to convert external hard drive from NTFS to FAT32 with a third-party software-AOMEI Partition Assistant, which can convert hard drive from NTFS to FAT32 without data loss.
To computer users, NTFS and FAT32 are not strange. But seldom of them can tell what the difference between them. NTFS and FAT32 to partition are what DOC and TXT to text. In text, the file with DOC format can't be read by TXT application. Similarly, in some condition, not all files in different formatted partition can be read by same application. First, you'd better know some knowledge about NTFS and FAT32.
A Brief introduction of NTFS and FAT32
About FAT32
FAT 32 is one of partition format in windows system. It has 32bit file table, which strengthen FAT32's management to partition, and break through the limitation of 2GB space in every partition. Since the production cost of hard drive decreasing, the volume capacity is increasing. After applying FAT32 partition format, a big volume hard drive can be definite as a partition but not be divided into multiple partitions. It is good for management to hard drive. Now, FAT32 is replaced by NTFS.
About NTFS
NTFS is standard file system after Windows NT, 2000, XP, server 2003, server 2008, Vista, and 7. It replaces FAT to offer file system for Microsoft. NTFS make advanced on FAT and HPFS, such as to support metadata.
The difference between NTFS and FAT
As mentioned above, NTFS and FAT both are file system. However, NTFS is produced late than FAT32, but NTFS is more advanced in technology. In summary, the specific distinction are following below:
NTFS can support up to 64GB single file and 2048GB partition. FAT32 supports up to single file with 4GB and partition with 32G.
NTFS does not need Defragment your hard disk.
NTFS support to compress partition, folders and files.
NTFS takes a little cluster, which can help to manage space of hard drive effectively, and avoid wasting space of hard drive at the most extent.
In NTFS partition, you can share sources, folders and set access permissions on files. It is more secured than FAT32 partition.
How to know which partition format is suitable for you
As mentioned above, NTFS and FAT32 have its own advantages. When we choose which file system, you should consider the factors below:
Computer is installed with single system, or multiple systems.
The number and capacity of local installed hard disk.
Whether has consideration about security or not.
If computer is installed single system, and there is security to consider, you can select FAT32. Or NTFS is not bad choice absolutely.
Why need to convert NTFS External Hard Drive to FAT32?
NTFS and FAT32 are two different types of file systems, and both of them are commonly used and contain different characters. You may make conversions between the two types, and here we got several cases that you need to convert external hard drive to FAT32:
If your external hard drive is formatted in NTFS, you would not be able to access some files from DOS mode or Windows 9X, then you need to covert external hard drive to FAT or FAT32.
NTFS can't be recognized by many devices, such as Xbox 360, PS3, etc. in that case, you have to convert the external hard drive to FAT32 so that it can work with your devices.
There are more situations in which you need to convert external hard drive to FAT32, and there are different ways which you may realize the goal.
Methods to convert NTFS External hard drive to FAT32
At present, there are two main ways that you may convert external hard drive to FAT32, one is to convert to FAT32 with Windows built-in Disk Management, and another one is to convert to FAT32 with third-party software like AOMEI Partition Assistant. Let's see the details:
Method1: Convert an External Hard Drive by reformatting
1. Open the Disk Management in Windows.
2. Right click on the external hard drive and select "Format..." in the drop-down menu.
3. Select "FAT32" in the "File system" line and then choose "Quick format".
4. Finally click "Start" to format, and this process may cost you minutes.
Note: If the drive is larger than 32GB, the "FAT 32" option would be invalid and once format, the information or data in the external hard drive will disappear. So, backup the data or partition if necessary and you need to know how to convert hard drive larger than 32GB into FAT32.
Method2: Convert an External Hard Drive without formatting
You can download the third-party software to convert external hard drive from NTFS to FAT32, what is the most advantage is that convert NTFS to FAT32 without data loss. Comparing with disk management in computer, the third-party software will save your time and money. You don't need to buy other external hard drive to store data, just for converting partition format. Of the third-party software, AOMEI Partition Assistant is good choice. The specific introduction of how to convert NTFS external hard drive to FAT32.
As a kind of advanced partition software, AOMEI Partition Assistant can easily convert an external hard drive to FAT32, and you can also convert an external hard drive larger than 32GB into FAT32. This software is running well with Windows platform including Windows 2000, XP, Vista, Windows 7 and Windows 8. Both 32-bit and 64-bit Windows editions are supported. With its help, you need no to format your external hard drive and thus you can convert NFTS to FAT32 without data loss. Now, you may download AOMEI Partition Assistant Pro Edition and have a try.
source from
on Dec 29, 2017 | Computers & Internet
I have a 1tb Buffalo HD-PCU2 ministation. I want it formatted as Fat 32 to use on my Humax recorder but Windows vista or 7 don't recognise it? Is it fixable?
FYI: fay32 doesn't support files larger than 2GB so if your putting movies than do NTFS.
To format as FAT32 you have to open an command prompt as admin. Window Button > All Programs > Accessories > Right CLICK command prompt and run as admin.
<VOL> = your drive letter ex E:
Command to format as FAT32
format <VOL> /FS:FAT32 /X
Dec 22, 2012 | Computers & Internet
I am trying to format my FreeAgent GoFlex 500 GB to FAT32, but the only options available to me are NTFS, and exFAT. How do I format it to FAT32?
The problem is that Windows doesn't format anything larger than 32GB as FAT32. You need to use a specific tool to do so. Have a look at this website
Jul 22, 2011 | Seagate 500GB FreeAgent GoFlex Hard Drive
How do I format my new Seagate 500GB FreeAgent GoFlex Hard Drive to Fat32 for use with Xbox 360? I am using Windows 7 and when I open up the formatting options only NTFS and exFAT are available.
Windows Disk Management can only format a hard drive less than 32 GB to FAT32. If you want to format your 500GB drive to Fat 32, you need to use third party program like AOMEI Partition Assistant. http://www.disk-partition.com/free-partition-manager.html
Dec 25, 2010 | Seagate 500GB FreeAgent GoFlex Hard Drive
Datatraveler is format as exfat. I want it format as ntfs or fat 32??
connect it to the computer and right click on the icon of the drive in my computer and choose format a box will apperar click on the file system and choose fat32 or ntfs then tick quick format and press ok a promt wil appear that all data on the drive will be erased click ok your drivbe will be formatted in fat32 or ntfs file system you want .
but before doing this please make a note that all data on the drive will be lost so please back up data before continuing with format
Dec 06, 2010 | Computers & Internet
I have an external hard drive (300gb) that I want to convert to FAT32 it is currently unformatted and windows only gives me the option to convert to exfat or ntfs and neither are of use to me. How can I...
You cannot format FAT32 on such a big drive unless you break it up into many, many, suitable partitions, to format a drive this size you MUST use NTFS....
You see FAT32 simply cannot mathematically address that amount of address space, it is just that simple.
The biggest size partition is 32 squared or 1024MB
Jun 22, 2010 | HP (EK423AA) 300 GB Hard Drive
I need to format the USB I have to a Fat the only options I have are Fat32 NFST and exFat
normally you would format to fat32 that will be compatable with most systems ..... exfat is used only for linux ... but linux can also use fat32 and NTFS .... microsoft can't read exfat without a special program ... you can use NTFS if you hve a very large USB drive ...but fat32 will be compatable with the most systems ...
Apr 03, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Iomega fat 32 formatter program does not allow me
If you really must have fat 32 (maybe for MAC use ?) then windows itself does not support doing a fat format on large drives.
However there is a fix Yup thats why they call it FIXYA
Here is a link to just what you need
Hope its what you need and good luck
Nov 20, 2009 | Iomega 250GB Ego Portable HD Red 250 GB...
Recently bought a Maxtor portable 250 GB HDD, need to format it to FAT32 so that my Playstation 3 can recognise it, but Vista will not allow it, can only format it to NTFS and exFAT. How can i format the...
You must be logged on as an administrator to perform these steps. Before you begin, note that the FAT32 file system has size limitations. In this version of Windows, you cannot create a FAT32 partition greater than 32 gigabytes (GB). In addition, you cannot store a file larger than 4 GB on a FAT32 partition. For more information, see Comparing NTFS and FAT file systems.
blank.gif Converting a hard disk partition or volume from NTFS to FAT32 requires that you reformat the partition, which will destroy any data on it. Be sure to back up any data you want to keep before you begin.
Nov 04, 2008 | Computers & Internet
Belkin N1 Vision Router Logo
306 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
