Question about Samsung WF328AAW Front Load Washer
Cant get power to my samisung front load washing machine
    Top Expert:
  • Samsung Master
  • 9,472 Answers
What is the model number listed on the machine?
Posted on Nov 27, 2012
Power cut off during operation and cant get power now
sounds like a short circuit. was it pumping / washing or spinning at the time? this will tell you where to start looking for shorts. also if there is water around the inside of the machine, this may have caused the problem.
Nov 10, 2013 | Samsung WF328AAW Front Load Washer
How do you adjust the water level on an LG front loader washer?
You cant, water levels are factory set for optimum water efficiency, new machines use a lot less water than older machines, poor wash results are usually caused by over loading
Oct 17, 2013 | LG WM-2277HW Front Load Washer
I have a front load washing machine...model # W10254421A.i would like to use just a spin cycle. I cant seem to find any info on how to just use that.
Press your "Power On" button, then select the "Spin Speed" button, and then press "Play" This will do a Spin only cycle.
Mar 06, 2011 | Washing Machines
GE clothes washer WHDSE820C1WW started filling itself up and i cant get it to discharge the water out, spin or anything
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101 .
Oct 10, 2010 | General Electric Clothes Washer Timer Hub...
FRIGIDAIRE AFFINITY LTF600 FSO PUMP KEEP,S RUNNING AND WONT SPIN
I fixed mine by replacing the door lock they are about 50.oo
The door lock has two locks, one is instant when you push start the other is a time lock, so you cant open the door for a little if you stopped it during the spin cycle. The problem is what they call the WAX switch or heater. When power is applied to this WAX lock it takes 30 to 60 sec. to lock and to unlock when power is removed.
The machine will not spin, if this lock is not working correctly.
You cant bypass it by jumping the power from one side of the shitch to the other. The board moniters the power draw and when the switch closes the lock contacts. You can how ever open up the lock very easy and bend the contacts closer to get you by for the weekend. unplug washer, remove the two screws on the back of the top panel behind the washer, remove top, open front door and remove the two screws that hold the lock, reach in an pull up the lock, remove wires, now open up lock and bend the piont contacts in side or install new switch.
Aug 07, 2010 | Washing Machines
Washer does not spin or agitate cant find a fuse
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 03, 2010 | GE WPGT9360EPL Top Load Washer
Door is locked, no power to on off switch
if there is still water in the tub.then you can use a wet dry shop vac and attach it to then end of the drain hose and remove all the water,once the water is removed the door should unlock after you turn it back on.then you can check the drain pump for obstructions.
have you checked the power coming off the board to the switch
Mar 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
Got the Bosch Classixx 6 Express 1400 washing machine cant
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently. Means the machine is locked, for children. I think if you do it again it locks.
Pl rate me 'very helpful' for the free help, thanks
Feb 22, 2010 | Bosch Classixx WFO 2466 Front Load Washer
Beko wmb1ow leaking cant see where from
Have a look at the hose that runs from the dispenser to the tub front.
They can leak when they rub against the shell.
Hope that helps
Nov 25, 2008 | Zanussi ZWF1430W Front Load Washer
Wf860 test and pretest on the screen
try unplugging machine from power plug hold power button down for approx 30 sec restore power and ck
Aug 10, 2008 | Hotpoint Ultima WF860 Front Load Washer
Samsung WF328AAW Front Load Washer Logo
47 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
