Question about Inverter Aims Pure Sine Wave Power 2000/5000w
Aims Inverter PWRINV5000W Installation Manual I just went to install it and no manual in the box
  • 21 Answers
Here you go- contact info for Aims. They can provide you with a manual. Good luck....gary
AIMS Power Contact Information:
9736 S. Virginia St. STE A
Reno, NV 89521
Tel: (775) 359-6703
Fax: (775) 359-6753
e-mail:
sales@aimscorp.net
techsupport@aimscorp.net
customerservice@aimscorp.net
Posted on Mar 14, 2009
My 3000 watt aims inverter/30amp charger seems to work but the charger will not charge/transfer when I turn on the generator. Charging indicator will not come on. It does transfer the generator power
dear see that :
1- the range of voltage which inverter work between it for example 180-260 v
2- most small generator voltage reach more than 260V so the inveter not work
3-check the frequency of genaratoer if it not fix the inverter will mot work
Oct 12, 2014 | Aims Power AIMS PWRIC300012W 3000 Watt |...
COLD CATHODE BACKLINGT CHANGE
If your back light went out, and you need assistance go to your manufacturer's website and download an installation and user manual for your computer. I just change out a Dell inverter which supplies power to the backlight. The inverter is the one that usually goes bad.
Apr 09, 2012 | LG W2242s 22 Silver Tilt Tft Monitor
Having issues with my laptops when the AIMS 600W Pure Sine Inverter turned on. As soon as I exit the cab of the vehicle with the laptop the issues resolve themselves.
You will need to either mount the inverter further from where you are using the laptop or shield it enough to get the laptop out of the "arc" of the power generation.
Now the problem: The inverter does produce heat so you can't mount it in an unvented box.
You are dealing with the same problem as the high tension power lines, that has a radiation zone, and you either need to cut back the zone or move it further away.
If it the inverter was modified in any way, then they might not have gotten all the shields back correctly.
Sep 10, 2011 | Inverter Aims Pure Sine Wave Power...
Manual, for a aims 1500 pure sine inverter, not putting out. need manual or help in diagnosing the problem
The manual for aims1500 pure sine inverter is not available. The particular manual for this inverter is not not available.
Click the below link and check the inverter manual. You might find it helpful.
Click here: http://www.psui.com/pdf/75-1000-0001.pdf
Regards.
Jun 04, 2011 | Vacuums
I have a Aims Inverter PWRINV5000W with all the lights on but no output at plugs.
Hi!!
There is a fuse or thermal device for the AC outlet(s) protection, is either next to the outlet or same place but inside the unit. The cover need to be removed to change/reset it.
Let me know if you found it. Good Luck!!
Dec 08, 2010 | Inverter Aims Pure Sine Wave Power...
Aims 5000w inverter
Try shutting down the load completely, then power up the inverter with no connected load. Then bring a little on at a time and see what happens.
May 21, 2009 | Inverter AIMS Power 2500 / 5000W
Aims 5000 watt inverter troubleshooting
The amp meter on this unit measures the battery current. So if you have an 8 amp load at 120 vac you will draw more than 80 amps at 12 volts and 40 amps at 24 volts. While this may not explain the 180 amps that you are seeing -- it's possible that the dryer is drawing more than 8 amps.
Dec 10, 2008 | Inverter Aims Pure Sine Wave Power...
Inverter Aims Pure Sine Wave Power 2000/5000w Logo
1,894 people viewed this question
Top Inverter Electronics - Others Experts
mntech1
ray gallant
Tom Chichester
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
