Question about Health & Beauty
How do I put the blades back on my conair HC95RWV?
I took the clippers apart to clean it , and noe I forgot how to put it back together.
  • 1739 Answers
SOURCE: took apart my Conair HC500
The Instruction Manual for your product can be found here:
http://www.conaircanada.ca/pdf/en/ibs/en_HC500C.pdf
Posted on Apr 25, 2011
SOURCE: oster clippers
Found another web site where some one had posted the information I needed. I just used Google search and found the information.
Posted on Jul 15, 2008
EwingElect
  • 276 Answers
SOURCE: Cannot put blade assembly back together
Sounds strange, since I don't think that the HQ5 heads in the shaver have the pointy parts that other shaver heads have. If your comb has 2 pointy edges, make sure they are located correctly in the head housing - they will need to be located inwards, with the the spindle that the retaining bracket attaches to in the center of the the two pointy parts.
But apart from placing the combs in first, locating the cutters in then putting the retaining bracket in (which may be broken if it won't fasten properly) I'm not sure what you can do, other than calling your local Philips Service Centre,
Posted on Apr 08, 2009
clipperdoc
  • 17 Answers
SOURCE: Putting back together hair clippers
are u talking about the clipper it self or the clipper blade i need to know which one
Posted on Nov 14, 2009
  • 5 Answers
SOURCE: I took it apart to clean, and now I barely cuts
Make sure the blades are even. It sometimes is hard to match when you take them apart. If they are even off a little bit they don't work. good luck
Posted on Jan 07, 2010
I have clippers model number HC95WV. I can not get blades back together
Ok place the small metal cutter on top of the large metal comb, place the white plastic piece into the top of the cutter with the protruding bit at the back, place the metal bracket with 4 holes on top first locating the front into the white plastic slot, then place the last metal bracket on top with the raised part to the front, then simply hold it all together and put the screws in form the back!
Hope I got the right blade style!!
Mar 18, 2014 | Conair Health & Beauty
Replacement blades for conair hair clippers hc114wv
I have a Conair HC114WVR and I took the blades off to clean the hair out. It's not that old, but when I put the blades back on they vibrate to a point of grinding. I can't figure out what I need to do to get them back on straight.
Jan 25, 2014 | Health & Beauty
Clippers stopped clipping. I changed to a new blade but it didnt help. I took the clippers apart and put in a new holder for the clippers. I put the clippers back together and although they clip a little...
Sound as though the blade drive needs replacing, commonly you will notice tram lines in the cut on your longer blades or the shorter blades struggling to cut
Jul 05, 2011 | Andis AGC2 Hair Trimmer
I can't find the manual of my Conair GMT 170X. I took the blades apart to clean and lube and now I don't know how to put the spring assembly back together with the blade. Please help
their is 2 long wires with a l shaped hook on the the smalles blade that goes on the bottom the points of those wires go in the holes in the bottom of it which is a white thing with 2 groves in it make sure the blade is facing away from where the screws go the take the plastic pad and put it in the 2 holes of the top blad the set it on their facing the same direction the push down till its flush the put the 2 screws back in
Dec 17, 2010 | Conair GMT 170 CS Beard Trimmer
Oster clippers blade
John! No Problem!
First put the bigger of the two blades witht the size/number facing down, put the cutter on top. (with the side with the flat side of the teeth facing down) Then put the tongue guide inside the tension spring, make sure the tension spring rail is on the tension rail and place them on top of the cutter. To see which bits these are go to: http://www.sheareaseltd.com/clipper-blade-sharpening/clipper-blades-the-parts
This picture whows the front and back, it differs slightly from your blade, but its same meat different gravy!
Hold all this together with your finger and thumb, flip it over and scre the whole lot together!
Jul 01, 2010 | Oster Golden A5 2-Speed Universal Motor...
Have not cleaned the clippers ever since I bought them. What do I need to do to clean and oil the clippers
There should be 2 screws on the bottom where the (Blades) are just unscrew them and and put them in a spot where you will not lose them and then take both blades off and use the little brush that it came with and brush the hair out. When you are done and have put them back together, make sure the bottoom blade is straight, when that is done turn on your trimmer and put a small drop or two of on the blades when it is running and it should be all set.
Jan 18, 2010 | Conair HC117 Hair Trimmer
Nov 07, 2009 | Health & Beauty
Conair GMT200 Assembly
Hey dude i had the same problem n_n. Attach the screws in place and try to screw one by one gently. Soon this pressure will keep the spring tighten (instead your finger's pressure) then it will be easier to reassemble the component. I know you'll fix it n_n.
May 20, 2009 | Conair GMT200TD
Can't snap on blade for dog clippers
Not sure why they won't go back on unless the clip has collapsed in which case you would need to take a screwdriver and pop it back up. Andis and Osters are the best clippers out there however.
May 11, 2009 | Conair Health & Beauty
Health & Beauty Logo
101 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
