Question about Hotpoint Refrigerators
Hotpoint FFM71 fridge freezer tripping
When i plug in my fridge freezer it trips out my electric not straight away sometimes 1 maybe 2 hours later
    Top Expert:
  • Hotpoint Master
  • 9,472 Answers
Replace the breaker. It may be out of tolerance.
Posted on Nov 26, 2012
Oceti
  • 51 Answers
SOURCE: fridge/freezer trips my circuit breaker
This sounds like a grounded wire in your defrost system. Start by finding the defrost timer and checking the wires. One may have been pulled loose or pinched while it was being moved.
Posted on Dec 13, 2007
gaeb7
  • 25 Answers
SOURCE: Fridge keeps tripping the circuit breaker
Your fridge should draw no more than 5amp. Presuming your breaker is at least 15amp there's a problem. Move to a different circuit first. If the condition persists check the start relay on the compressor. I have a suspicion the circuit may have another item you are not aware of.
Posted on Mar 01, 2009
get an inexpensive clamp amp meter (Harbor Freight has them). Turn off power to the plug. Remove plug from wall but do not disconnet wires. turn fridge OFF. plug the unit in the recept. turn on the power. set the meter for the higest reading (amps) & clamp it around the black wire. turn the fridge ON & observe start up current & the "run" current. If the fridge is within limits on the data plate the problem is in the wiring circuit, maybe a loose connection either @ the plug or the breaker. if there are several plugs in the circuit, the problem could be in one of them. In addition, if there is a gfi plug in this circuit, it could be faulty also.
Posted on Mar 02, 2009
  • 400 Answers
SOURCE: lg multi air flow gr-349sqf
It sounds like the defrost element is faulty and is causing a leakage to earth when the unit comes onto defrost cycle. Check the defrost element in the freezer compartment behind a panel cover.
Posted on Mar 10, 2009
Maytag317
  • 1136 Answers
SOURCE: Maytag model (MTB1950GR) tripped off the power switch and smell
Hi, It sounds like the relay onyour compressor. They will smell when it goes bad. Remove the rear panel on the back of the refrigerator and see if the smell is around the compressor.
Please let me know If I can assist you further.
Vic
Posted on May 23, 2009
Hi my samsung fridge/freezer suddenly started to trip my electricity,I changed the plug but still is tripping the electricity,also checked the socket,definitly the fridge
First you must isolate the problem. remove the rear service cover(unit unplugged) disconnect the wire plug to the compressor. replug the fridge. If the circuit doesn't trip ,then the compressor or relay is defective.
May 04, 2018 | Samsung Refrigerators
Samsung rsh1nhmh fridge freezer not turning on and tripping electrics.
sounds like electrical fault within your freezer any small fault will throw your contact breakers on your consumer box without blowing the fuse in the appliances plug
Aug 30, 2015 | Samsung Refrigerators
My hotpoint rfa52 just started to trip the electric out no warning just kept tripping it out
drawing excess current due to either a short in wiring,, or could be bad fan motor or compressor windings
Aug 28, 2014 | Refrigerators
Why does my 15amp arc fault breaker trip when no one is in the house and when i reset it it won't trip right away but it trips roughly and hour later or longer
There must be something tripping the breaker whilst you are not in the house.
I would guess it is something like an electric water heater which cuts in from time to time. It is probably faulty and tripping the breaker - it may still heat the water so the fault is not obvious. Other things are air con units, fridges, pumps, anything that might come on whilst you are away.
Dec 22, 2010 | Hammering
Hello, my hotpoint FF187E fridge freezer keeps tripping my electric off, sometimes it will stay on for a couple of days other times it does this straight away, any idears would be appreciated, thanks...
you may have a burned wiring which when wet trips off you electricity. the location may be in front of your unit between the doors if you have a two door fridge. if you have a singole door unit it may be located on lower area of the fridge body which where the water flow down when you have excess water dripping infront of your fridge. those two location are most likely because the wiring installations from thermostat, heater, and ligth are there. ofcourse you have to check first the compressor and it's auxillaries
Jan 13, 2010 | Freezers
My Hotpoint Refrigerator keeps popping the outlet breaker and shutting off. I took the rear vent grate off to clean any dust out and noticed there is about a 1/8" of water sitting. Is this what could be...
Normally if the fridge is tripping the circuit breaker, it is due to a short caused by the defrost element.
However, the second problem could be caused by a faulty timer.
Ash
Oct 22, 2009 | Hotpoint Refrigerators
Steam iron trips the main fuse
It could be your iron drawing too much current but it sounds more likely that you have a weak circuit breaker on that circuit. You might try the iron on a different house circuit to confirm if its actually the iron or the house breaker giving you problems.
Sep 07, 2009 | Philips HI-296 Iron
I have a 22 yr old top freezer fridge. I took it to my cabin last year when I bought a new one for the house. However, it does not work-get cold at all. We don't leave the electricity on when we are not at...
ok Sounds like a place i would love to go but .... First, if the trip to the cabin was very bumpy chances are it sprung a leak and lost its gas charge , if this is the case , repairing it may cost more than replacement depending on the location of the leak , if the trip up to the cabin was smooth then consider this, When moving it around to load it up did you maybe move it around suddenly , and if you did this too would cause a leak specially considering  the age of the system, chances are its lost its charge and would require leak testing and repair , here in Australia anywhere up to $ 600.00
May 11, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Amrican fridge freezer keeps tripping the electric. i changed the fuse and tried running it from a different socket but still it trips. is there something else that could be causing this to happen
if the unit is tripping the electric breaker, then there is a short in the unit. if you know how to use a resistance meter, you can trace your unit.
short could be coming from the power cord itself, check for broken wire and maybe touching the ground or the body of the unit.
next check your compressor. this is the biggest load of your unit. if this is shorted to ground, then it will trip your electric.
be care full on plugging the unit if you are not sure that you found the shorted wire, it might trip again.
if all of those still does not correct your problem, check the mullion heaters. but the connections of these heaters are sometimes very hard to find to check. their are hidden and only technician can sometimes find them.
tnx 4 using fixya
drcool
Sep 01, 2008 | Whirlpool Refrigerators
Hotpoint aquarius1100 electrical prob.
you say tripped the switch?... are you talking about a circuit breaker???.. I was thinking maybe you have a bad breaker... If you had no problem before... maybe try in a differt plug in reciptical... if the washer has a short.. hard to find sometimes..like looking for needle in hay stack..
Sep 02, 2007 | Washing Machines
Refrigerators Logo
116 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
