F&p washing machine
I takes hours for my f&p excellence smart drive washing machine to fill. The water comes in trickles eventhough the tap is fully open
  • 15,935 Answers
Replace the dual inlet water valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Hello. my Lavamat 74500 update does not start the wash cycle. everythig is on, door locks but nothing happens.
sounds like a water fill problem to me, normally at start of cycle door locked, program set, start water solenoid opens and fills machine with water, once water reaches set level heater will come on and wash program will commence,
so if you have a restriction in the water supply/ water tap not turned on correctly, on blockage in water solenoid valve water flow to machine will be restricted causing a long delay before machine starts, things to try
1. make sure hose connection water valve is fully open
2.open soap draw to see / if you can hear water flowing into machine,
3 if its very slow you have a restriction in water supply
could be a twist in water supply hose, causing a restriction
all above is if machine is taking to long to fill with water,
good luck .
Oct 05, 2016 | Washing Machines
Machine wont fill with hot water
problem in hot water tap
hot water solenoid not activating to let water in
to prove either switch the hoses on the taps and press cold water wash
that proves the tap
then press hot wash and that proves the solenoid
Jul 21, 2016 | Fisher and Paykel Washing Machines
I have a LG Punch WF-C5856TC washing machine. Off late, Notice that the water is trickling in rather than flowing. Hence it takes really really long time to wash clothes. Pls advise
The first place to look is the inlet tap in the wall
even you have the tap on full the tap washer inside jams and prevents the full flow of the water
next check out the filter in the hose at the tap or at the washing machine end
next replace the water inlet solenoid
you can check this by changing the hose from the hot water tap onto the cold water tap and pressing the hot water button to fill
solenoids do not know the difference , they just work when the power is applied
Sep 08, 2015 | LG Washing Machines
We can hear water running but it's not filling the wash tub. There is no water leaking anywhere.
check that the tap is fully opened , the filter in the end of the hose is not blocked
check that the tap washer is not jammed off in the tap as they can expand and not move up to let water in
check water inlet solenoid is functional
Aug 23, 2015 | Amana DLW330RA Top Load Washer
It takes a very long time for the machine to fill up when the wash temp is on warm-cold, but if it is on Cold wash temp only it fills up straight away. I have a Smart Drive 703 Model washing Machine
(This is pre-typed so for hot and cold please read hot- but check both anyway!)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Aug 14, 2011 | Fisher and Paykel Washing Machines
Hey, my f&p smart drive 9 excellence washing machine does not start wash cycle after entering water level etc.... upon pressing the start button nothing is happening any thoughts?
Is the bowl turning slowly when you press start.if it does then you may have a faulty inlet valve,make sure taps are turned on.try advancing the machine to spin cycle,see if it will do any other things such as spin & drain.if it does then probably just not letting in water & inlet valve needs replacing..try filling machine by hand & see if it washes.
May 24, 2010 | Fisher and Paykel (IWL12)
My washing machine when rinsing the water comes out in a trickle and takes about two hours to fill, it is only 6 weeks new
being a new machine, first thing i would check is the water supply of the faucet feeding the machine. remove machine hoses and run supply water to make sure you are getting normal pressure, like at any faucet. if that is good remove hoses at machine, make sure there was no packaging left on that may have bblocked the line.
Aug 26, 2009 | Washing Machines
The cold water trickles out and it takes a hour to fill the tub. someone said the delay switch but where is it?
check your water supply lines. there is a small screen filter where the hose from the tap or other water supply line enters the machine. it may be dirty from mineral build up. make sure all is clean , both ends.
Jun 14, 2009 | Washing Machines
Hello, I live in Dubai and have a 5 year old Fisher Paykel IWM12 top load washing machine that just developed an issue. When starting a cycle it "auto senses" the water level, fills up then tells me...
First question that comes to mind is why you would want to have a machine if their is no service support where you live. I assume you have done the basics like taking hose off machine inlet and pointing it in to a tub, turn tap on and make sure there is a good supply of water. Put hose back on machine, fully open tap & start (on cold supply). Lift lid while it is filling. Check that a strong flow is coming in to machine. Then repeat with the hot tap. If water is only trickling in & sounds like it is struggling then more than likely it needs a new inlet water valve.
Jul 15, 2017 | Fisher and Paykel IWL12 Top Load Washer
Washing Machines Logo
181 people viewed this question
Top Washing Machines Experts
