York Yankees Bedding MLB Comforter Logo
Posted on Jan 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a york stellar plus gas furnace, p2udd12n07601c that won't stay lit. the exhaust fan works and the burner ignites, but then goes out after about 5 sec. I replaced the flame sensor but still have the same problem checked the intake and exhaust no clogs help its cold outside
  • adamhammeran Feb 12, 2009
    YORK GAS FURNACE NOT STAYING LIT???
    I have a York Stellar Plus Gas Furnace installed on March 18 1994.
    Upflow Model Direct Vent Furnace
    Model # P2UDD 20N0 9501C
    Serial# EMB M431099
    The thermostat is sent to Auto and Heat. The Inducer fan motor turns
    on, then the hot surface igniter begins to glow. The gas valve kicks
    on the unit stays lit for 1 second and the unit cuts out. Then the
    unit attempts this process all over again. The units main burners do
    not want to stay lit so that the blower motor can turn on to blow
    heat.
    This has happened two times in the past two months and I have changed
    the flame igniter and flame sensor. I changed the furnace control
    module 50E47.
    This has happened twice and when I changed these parts the unit worked
    fine. Now it happened again, I don't know why or know what to do??
    Please help me.
    Thank you, Adam
Paul Carew
Level 3:
  • Master 3,808 Answers
  • Posted on Feb 02, 2010
Paul Carew
Master
Level 3:
Answers
3808
Questions
Helped
1299520
Points
10526
Hi try jumping out the pressure switch see if it lights and check th rair filter might need a clean
Kim mazotti
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Nov 13, 2015
Kim mazotti
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
3712
Points
I also have a York Stellar we've had our for 10+ yrs, first owner, started up a week ago, worked perfect, Now that's it's getting cold it stops heating. Can't get no flame, no fire, nothing crept that fan runs non-stop. Purchased new igniter for 62.00 which was a waste of money.HELP
Anonymous
Level 1:
New Friend:
  • Posted on Feb 11, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3712
Points
I think I found the common problem to your headaches with these units, yesterday I got fed up with the unit and decided to clean the inside of the heat exchanger I removed the inducing fan the plate over the heat exchange and vacuumed blowout and cleaned all the insides it seems that it gets clogged up and doesn't allow the furnace to vent properly which causes a backflash which then turns the unit off this has been happening to me for a long time now if you're experiencing the same problem it's not hard to do just take some time patients and being very careful not to break anything I'm also considering putting in a brand-new inducing fan while I hope this helps my fellow York furnace owners
Lennox furnace model G11Q3-110 v.2 burners light but go out before fan comes on
Troubleshoot an ignition problem on a Lennox gas furnace ...
? 2:44
https://www.youtube.com/watch?v=yXIxgzwMkPs
Nov 17, 2012 - Uploaded by grayfurnaceman
This furnace should light its pilot with a spark then the pilot proves its on ... Troubleshoot an ignition problem on a Lennox gasfurnace .... Pilot and no inducer but is the same model as that great video! ... You probably have dirty burners. ... How do you know spark module is not sending 24 volts to mv and pv ...
Lennox Furnace Model G11Q3-82-2 - RepairClinic.com
Janitrol GUPS075-3 Furnace burners will not stay lit
The first thing I would do is make sure the flame sensor is clean, this is a metal rod immersed in the burner flame on the opposite side of the igniter. If too much oxidation builds up on it, it will not allow the burner to stay lit. To clean, just turn off furnace and remove flame sensor and clean with steel wool and then reinstall. If this does not solve the problem there may be a problem with the gas valve.
4helpful
Rheem 90+ NG Furnace. When furnace starts, draft inducer starts, ignitor glows and gas ignites. Burners stay lit for 10 seconds or so, then the flame reduces for a few seconds then goes out. Main blower...
Check the draft inducer air switch ( vacuum diaphragm switch) If the switch is opening when the burner starts, you might have a blockage on air piping coming into the furnace. Also prime the condensate trap on the condensate drain from the combustion fan. Also check the gas pressure, if your gas pressure is dropping, the gas pressure switch will shut it down. If it's too high the moment it comes on could raise the pressure in the furnace dropping out the combustion fan proving switch.
2helpful
My York Stellar PLUS furnace (Model P2UDD12N07601C) will not stay on; The ventilator fan runs, the main blower runs, the igniter comes on for approximately ten (10) seconds and you can hear the gas valve...
Check gas pressure, inspect manifold & make sure there is not a blockage.Make sure gas is present and main gas shut off valve to furnace is on also check the knob on the 24 volt gas valve and see if it is in the on position , check the MV terminal on the gas valve to 24 volt common with a volt tester to see if you have 24 volts present, if you do have 24 volts at gas valve, replace valve. if you do not have 24 volts at gas valve check high limit control & roll out limits for a open circuit, Good luck.
3answers
Fault code says pressure switch lockout
This more often than not, indicates that your pressure switch is gone and needs to be replaced. Watch the YouTube video for a fuller explanation and heed the warning to use OEM parts! Gas Furnace Pressure Switch Failure and Replacement Amazon com gas furnace parts
Rheem gas furnace pilot lights, but no burners or fan
If the burners do not fully ignite, the sensor will shut the furnace down. The lack of sufficient burner flame is a gas valve or gas pressure problem within the valve.
Replacing the gas valve with the original one may get you going. I surely suggest a professional service company for safety reasons and a thorough inspection. A 20 year old furnace is past it's normal life span.
Owners Manual
York Corporate Headquarters
631 South Richland Ave.
York, PA 17403
Phone: (717) 771-7890
Contacting York
Mail:
York International Corp.
P.O. Box 1592
York, PA 17405-1592
USA
Phone: (877) 874-7378
York Website
York was purchased by Johnson Controls in 2005
Johnson Website.
I cannot find an actual manual online. I hope this information helps you. Good Luck.
2helpful
4answers
My Ruud Furnace wont stay lit
Hi Bmreid
The problem you describe sounds pretty much like your gas valve is going bad. There is a brand by Honeywell called a Smart Valve which is anything but smart, when the electronics in the valve start going bad the furnace will run great for a day or two and then the next day may not run at all and then an hour later my run and then an hour later may not run again. Very sporadic operating furnace is usually the Honeywell Smart gas valve going bad.
No heat, trouble shooting light has continious flash.
There is a vacuum sensor on most units tied from the exhaust gas fan to the sensor. Does the unit try to start? If the unit's exhaust fails to pull the switch it will turn off after about 30-45 sec after starting. "IT" thinks it's not exhausting and stops to keep from overheating. Do you have this exhaust fan and rubber hose to sensor? Can you see if that fan is turning on start?
Top York Sport & Outdoor - Others Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a York Sport and Outdoor - Other Expert? Answer questions, earn points and help others
