Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
Programming hv board
Need code for board Maytag Ice2O MFI2568AEB
I have the same Maytage MFI2568AEB on the inside top left of the refrigerator the code is 0302, i still cannot enter the code, showing PEO OOO.
Posted on Jan 26, 2009
  • MaytagSux11 Feb 17, 2011
    FYI - our label code was 1411. That did not work for us, but when I tried the code "paulettegg" listed (0302), that *did* work for our unit. I imagine Maytag only had a few various codes depending on the option-package of each unit; based on the quality of the design, it wouldn't surprise me if they got their code-labels mixed up in manufacture. Suggest if more people enter their codes, others can try them to see what might work. Best.
  • Rebecca Franklin Sep 23, 2012
    You are so right. My code was also 1411 and it didn't work either. I tried the code 0302 this morning before I left for church and it accepted the code. I will see when I get home tonite if the refrig works. I did not want to pay someone to come out and do the same thing I have tried even the repair guy had the same code as I and figured there had to be something else wrong with the refrig if the code did not work. I found fixya.com this morning. Will post if it works but everyone should post their codes so others can see it they work. I wondered the same thing when the code did not work. Did they mix up the codes. I see they may have. Thanks for the posts.
The ICE2O has gone crazy
Billy, your HV control board has failed. (I know this because I serviced one just last week for the same symptoms and promptly diagnosed and repaired it.) The board can be accessed from the back of the fridge. Roll it out from the wall and look about 2 feet up from the floor on the left hand side. You'll see the cover held in place by 4 1/4" screws. Remove 3 and loosen the last one, rotate the panel out of your way. The board is a snap to remove and replace. The part number you will need is #12920710 and is available at your local appliance parts retailer. It lists for ~$150.00. The kit DOES come with instructions to program it once the repair is complete. Read these completely BEFORE doing the repair so you'll know what to do when you've got it back online.
Aug 13, 2007 | Maytag (MFI2568AEW) Bottom Freezer French...
Maytag programming code for HV Board.
One indirect way is to buy online a replacement board wich comes with the code. Use the code. Return the board for a credit. Make sure you can get a return credit before opting this way.
Nov 27, 2010 | Maytag Refrigerators
Need program code for the refrigerator there is
Look under the toe plate for the tech sheet. If it is missing the part number is 16026830
eric
Jun 30, 2009 | Maytag (MFI2568AEW) Bottom Freezer French...
I have a Maytag model no: MFI2568AEB I replaced the HV Control board in the back, when plugged in the front panel now reads PEO OOO and the you cannot put your code in O3O2 all freezes, please help. Thank...
i would unplug and start again,refer may be board.as you seem to know with out that code in there it wont work[been there done that]and you have to read carefully and do just as instructions say to pull it off.you can do it though. God bless ,tom
Jan 24, 2009 | Maytag (MFI2568AEW) Bottom Freezer French...
MFI2568AEB HV Programming code
I have recently gone through same problem . The cose that was installed in the new control card for MFI2568AEW was 1411.
Mar 25, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Lights flashing all cooling appears normal ice maker flap continually opens and shuts no water buttons not operational
As I mentioned before my Maytag was doing the same thing, I called Maytag expecting a big fight but they were really nice about it.
This is a recall problem and even if your warrenty is up Maytag will repair it at NO COST to you.
They shiped me the HV board and sent a repairman who had it fixed in about 10 minutes with a newley designed HV board.
Oct 28, 2007 | Maytag (MFI2568AEW) Bottom Freezer French...
I found the problem and the answer to my problem BUT the part is backordered and I am wondering
See the post on Samurai Appliance Repair Man's site http://applianceguru.com/forum1/13035-1.html for instructions on how it's possible to fix the HV Controller Board power supply filter caps for $5 in Radio Shack parts (really!). You need to be able to solder electronic components, or know someone who can. There are 2 power supply filter caps that appear to go bad and the result is the blinking and flapping. I had the same problem and decided I could not wait for a $150 replacement back-ordered board.
Jun 19, 2007 | Maytag MFI2568AES Stainless Steel Bottom...
FRONT DISPLAY SHOWS (PE0-000)
Usually the owners manual would show the error codes so check there first. As for the compressor running, it "should" be cooling if the compressor is running. But lets go back a little, why was the HV board replaced?
Feb 05, 2007 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
1,283 people viewed this question
Top Maytag Refrigerators Experts
Richard Roth
Richard Roth
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
