Question about Microwave Ovens
Drum not turning on siemens xl1400 washing machine, but it will turn by hand
Already changed brushes & motor is turning freely
Hi I have a siemens inno-wave HF17055GB Microwave and the plate turner is not turning, otherwise it seems to be working? help please
Replace the motor. The teeth in its gearbox have probably been damaged when trying to turn the plate by hand.
Aug 25, 2014 | Siemens HF17055GB Microwave Oven
My bosch washing machine is leaving a grimey residue in the drum after the wash. I have tried to run the machine without any clothes to see whether it was simply not emptying properly but that's fine -...
This bosch washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 31, 2011 | Bosch Microwave Ovens
DRUM MOTOR NOT WORKING TO TURN DRUM. PROGRAMMER OPERATING OK AND ALSO PUMP MOTOR. HOT AND COLD WATER FILLING MACHINE OK AND EMPTYING OK.IT WOULD SEEM TO BE THE MOTOR AT FAULT? THE MACHINE IS 6 YEARS...
Your question was head "microwave ovens" but I think you are talking about a washing machine.
Replacing the motor is a matter of judgement as to the reliability of the machine generally.
If this is the first time the machine has failed in 6 years, then I would have the motor replaced.
If there have been a series of faults, then replace then machine.
(Incidentally I assume that you checked the drive belt).
Jan 06, 2011 | Microwave Ovens
The turntable on our XL1400 stopped working. Is
the diskmotor is defect?
mesure the resistor of the motor with reduction under the plate the value must be bethween 60 and 100 Ohm.
if not the coil is burnd and you have to replace the motor.
Feb 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How do you change the belt if there is one for the
There is no belt on unit. There is a turn table motor and a turn table tripod or coupler. Either the motor is out or the coupler is broken. You can check coupler easy by removing glas tray and see if coupler turns around. If its appears ok, then t/t is probably out. This can be replaced by removed screws from bottom of unit and the complete bottom folds toward wall. Its in the middle with 2 wires connected too it.
Dec 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver microwave table wont turn
either your turntable motor part# WB26X10037 G.E. is bad or the motors capacitor part# AP2026076 is defective they are both the same price
Oct 08, 2009 | GE JVM1440 Microwave Oven
The turntable in my GE XL1400 stopped turning. How do I reach the motor to clean or replace?
They MIGHT have a belt between the motor and the turntable drive wheel that may have gone bad, rather than the motor. The unit will have to be removed from the case to get to the innards.
Sep 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker XL1400
Key panel (touch pad) shorted.
This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Jul 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker XL1400 GE Microwave
my xl1400 spacemaker ,it just won't heat, everything else works
ok, can you all advise me what to do, what could be causing it to not heat.
wendell
Dec 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Repair turntable for spacesaver XL1400
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Nov 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
