Question about Kitchen Ranges
Burner markings rubbed off - Kitchen Ranges
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 27, 2012
  • app_3rp86496
    app_3rp86496 Nov 27, 2012
    Hi the model is GE Profile gas cooktop model JGP9338.
Sounds like the flywheel is rubbing when running pulled transmission and it looks like the flywheel is rubbing on stater side
Does your starter fully retract when disengaging? Your problem may be one of geometry if the starter is slightly out of position it will rub on the flywheel, or the Bendix gear isn't fully retracting.Try hitting the starter with a mallet to see if the Bendix gear pops back out fully after you start your car.
Apr 05, 2014 | 2007 Mazda 6 2.0
Tip
Clean difficult marks off your whiteboard
When a message or any marks are left on a whiteboard for longer than 24 hours it becomes very difficult to clean off the board. These marks are difficult but not impossible to get off.
You will need rubbing alcohol and a soft clean cloth. There will be fumes given off by the rubbing alcohol therefore if you are going to be cleaning up a large whiteboard you will want to open a window.
Taking the cloth, apply some rubbing alcohol and rub it on the ink. It is important that you not use a soft cloth because using a brush or abrasive sponge will cause damage to the board.
You might need to apply a little pressure to get really old stains off. If you find that a stain isn't coming off it is possible that it is permanent marker, to get these off you can draw over the marks with a dry erase marker and then wipe it off using a clean cloth that has rubbing alcohol on it.
To avoid getting in these situations, only use dry erase markers and clean the board as soon as you are done with it. Leaving marks on the board will make them harder to get off.
If you are worried about ruining the whiteboard you can always use a whiteboard cleaning solution. For this you just spray the solution on the board, let it sit for five seconds and then wipe it off. The solution will also get rid of any residue left behind by other cleaners that you may have tried to use.
on Feb 10, 2014 | Office Equipment & Supplies
Burner won't light
if its electric ignite but gas powered then take the grill cover off find where it sparks and rub it with a pencil eraser.
Oct 10, 2012 | Pitco Frialator 45C Deep Fryer
We have aFEF352 AWE stove and one of the burners does not work so we bought the terminal block kit and it still doesn't work any ideas?
Each burner has a switch with 5 wires. 2 wires are power in and are marked L1 and L2 2 wires to the burner are marked H1 and H2 a 5th wire is marked P The p wire goes out to a small lamp and shows power is on to a burner. Check for power between H1 and H2 with the switch on to that burner. If you have no reading then your switch is bad.
<iframe width="640" height="360" src="http://www.youtube.com/embed/JjTYPabs3M4?feature=player_embedded" frameborder="0" allowfullscreen></iframe>
Jul 21, 2012 | Kitchen Ranges
GE JB900 burner does not work. Indicator lights up but no heat. Worked a couple of weeks ago. Warming burner doesn't work either. Other burners ok.
Sounds like you need to replace the burner, or the wiring is burned. Have you checked the connection between the burner and the oven? They should be clean and fit tight, no burn marks. Burn marks mean loose connection.
Mar 30, 2010 | Kitchen Ranges
Diplomat ADP3322/3340 oven, temperature markings rubbed off
You can buy the decals from Ovenlettering.co.uk they send you a sketch of the control panel so you know where to place each number.
Aug 29, 2009 | Ovens
When car is loaded ie- four adults , if you go over a bump or dip in road a rubbing sound is heard, any ideas
Check for rub marks on the inside of the tyres and wheel acrhes .If there are marks get your suspension checked.
Jun 28, 2009 | Jaguar Xj Series Cars & Trucks
LITEON LVW 5001 doesnt recognize DVD's
Laser either dirty or starting to go.Try cleaning laser with commerical disc cleaner,put a drop of rubbing alcohol on brushing.Laser can be cleaned manually with a Q tip dipped in rubbing alcohol but this requires opening burner.If you do this MAKE CERTAIN ELECTRICAL PLUG IS PULLED,lasers cause nasty burns.
Some times the problem is just the brand of disc,some brands don''t work in Liteon's.
If laser is going the burner can be replaced.Most of the Liteon 5001's used Liteon 401s burners,411s or 451s dvd burners all will work.The dvd burners mount from the bottom PC burners mount from the side so they would have to be adapted,many PC burners won't work in these older liteons some freeze up the second you hit fast forward.
Jan 18, 2009 | Lite On LITEON 8X DVDRW +/- Burner
Ilo-DVDR04 recorder problems
The laser is either dirty or is starting to go.These lasers in this model usually only last two years.To clean but a commercial disc cleaner philips or Maxell work good in this model.Put a drop of rubbing alcohol on brushes this helps clean laser.I would do this every 15 hours of use .The best way to clean laser is to rub gently with a Qtip soaked in rubbing alcohol but this requires some technical knowledge for you have to open burner.If you attempt this make certain electrical plug is pulled lasers cause nasty burns.
If laser is going you can replace the burner/loader unit,this model uses a 411s or 451s Liteon burner.The 401s and 813s will also work without problem.
Jun 05, 2007 | iLO DVDRH04 DVD Recorder
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
