Question about Whirlpool LGR5636L Gas Dryer
Whirlpool gas dryer (LGR5636LQ1) heat remains on with door open
Dryer heat remains on with door open and dial in 'off' position (whether it's timed dry, automatic high heat, or auto low heat). This is intermittent - right now it is not on. Yesterday after dryer use, it remained on.
  • dave brewington Jun 16, 2013
    So - finally replaced the timer, but it still does the same thing. Can you think of any other causes?
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
You will need to replace the timer. It has some sticky contacts. Here is the timer to order.
Posted on Nov 27, 2012
  • 1 more comment
  • dave brewington Dec 02, 2012
    Thanks, Richard. A few more symptoms I've noticed, wanted to see if they are in line with the timer diagnosis. The heat will fire up randomly - not stay on right after a drying cycle. Also, the heat will fire up when the dryer is unplugged.
    * meant to say, the heat will ALSO fire up randomly, not JUST stay on right after a dry cycle.
  • Richard Roth
    Richard Roth Dec 03, 2012
    Sounds like the timer. Replace it and all should be good.
Illeagle
  • 525 Answers
SOURCE: Whirlpool Electric Dryer Model LER8858EQ1 TYPE NO. 180-0
Based on the information that you provided, if you open the door in mid-cycle and the motor shuts off, but the element stays on, this will stop the air flow through the dryer and the element. The element temperature will rise drastically because it is not being cooled. Subsequently, to prevent a fire, the thermal fuse will open, shutting the element, and in some cases the motor, down.
A heating element gets its power from the timer, through the cycling thermostat(s),and to 1 side of the element.
When the motor starts, power is passed through the centrifugal switch in the motor, through the hi-limit thermostat and the thermal fuse to the other side of the element.
There is no ground wiring involved in the heat side of the dryer.
1. An element can stay on because it has broken and fell against the metal tube where it picks up a ground. Solution is to replace the element.
2. The centrifugal switch mounted on or in the motor can fail to open when the motor stops and allow current to flow through it
until the points in the timer open up, breaking the circuit.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 23, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool commercial gas dryer - heating problem
Check the voltage to the switch when turned to high and the power button pushed on. If you are not getting any power there then the setting switch is bad replace it at repairclinic.com
Posted on Feb 14, 2009
jumptrout51
  • 3361 Answers
SOURCE: Whirlpool Gas Dryer keeps running on auto dry setting
When you moved the sensor wire on the moisture sensor may have fallen off.
Remove the front panel and locate the wire and the connection. It will be on the right side near the lint filter vent. If it is still connected your timer has gone bad.
Posted on Mar 26, 2009
aasc
  • 1606 Answers
SOURCE: Gas dryer not maintaining heat. 70 Series Kenmore/Whirlpool 76722
Fuse is ok . Problem is the soils on the burner valve . If the dryer heats when started , the electricity goes thru the coils to open the valve . Once the coils get warm , 1 will open (short) until it cools back down . The coils can be replaced just by removing the front panel . Only 2 screws hold the coils in place . No turning off gas , dissasembling dryer .
Posted on Jul 19, 2009
  • 4088 Answers
SOURCE: Whirlpool gas dryer GGQ9858JQD runs fine not drying
Check the inlet and exit venting around the burner for lint or other obstruction.
Posted on Aug 23, 2009
I have a Whirlpool Gold Senseon electric dryer that will run but does not heat. When the dryer is started it will remain in the "sensing" cycle for 9-10 minutes then jump to the cooldown cycle.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Sep 19, 2011 | Whirlpool LER4634J Electric Dryer
I have whrilpool dryer and I am getting no heat, dryer runs but no heat. Sensor and thermo fuse good. Timer keeps clicking if dryer is off but knob is in some cycle position not off position. Open door and...
heatman101
Aug 12, 2011 | Dryers
I have a whirlpool dryer and for some reason it has quit getting hot so it's not drying my clothes. Also my dial wont turn. When I turn the dial to start a load it never moves from the begining...
heatman101
Jun 24, 2011 | Whirlpool Dryers
The dryer is taking a couple of ctlces to dry items. I opened the door and depressed the button, so that the dryer would run while I was checking for heat. The heat comes on but then after a couple of...
heatman101'
Mar 12, 2011 | Kenmore 72802 Gas Dryer
Kenmore dryer, heat element ALWAYS on
Good day,
Sounds as if the element inside the canister has shorted to the canister body. You will have to remove the element to check it. I'll include a tutorial on how.
If that doesn't resolve the issue, please reply back.. Whirlpool makes Kenmore dryers.
Jack
http://www.applianceaid.com/wp_element.html
P.S. Look close. It doesn't take much....
Feb 01, 2010 | Dryers
Installed a new whirlpool gas dryer. no heat.
Well being "new" I'd not suspect many parts being defective other than the ignitor for the gas burner. You can view its operation behind the kick panel below the door. It should glow brightly when your dryer is calling for ignition. It may have been damaged if you had dropped it or very roughly handled your dryer wrestling it into position.
Otherwise i'd suspect that the gas line is still turned off, or a wire loose somewhere, or the heat setting in "air fluff"..
best of luck, and have fun,
ttfn
Feb 01, 2010 | Whirlpool WGD9500T / WGD9500TC / WGD9500TW...
How to use the dryer rack in dryer ??? how to set up so doesnt spin.
The dryer rack should hook to the bottom of the door opening(using the lip of the door). If the rack is properly placed the drum should be able to turn without touching the dryer rack. Some dryers have the option of turning off the drum. If your dryer does not have this button or a dryer rack position on the timer dial then you cannot turn off the drum.
Jan 22, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Jul 14, 2009 | Whirlpool Dryers
Dryer does not release any heat
Is yours the gas model? If so I need you to look for some things. Open back door panel and see if while trying to light the igniter is glowing orange. Sea Breeze
May 22, 2009 | Whirlpool LGB6300 Gas Dryer
Whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
My dryer is not heating, where is the cupling at in the dryer i have it open tho
Jan 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool LGR5636L Gas Dryer Logo
286 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
