Question about Ricoh Aficio 250 Copier
HP 2840 Jam in Print Paper Path
I have had this unit for 4 years without any problems. I just moved my office, and while I handled the HP with care I am getting a "Jam in Print Paper Path" message.
I have removed and cleaned everything that comes out - the drum, all toner cartridges, rear removable fuser unit, paper tray. I used a can of air and gave it a good once over with a vacuum. No sign of any paper, foriegn object, nothing.
My thought on this is possible toner dust on the sensor's. Please help I'm out of ideas and I dont know where the sensors are.
Thank you in advance,
Joe B
  • pkilchrist Jan 10, 2009
    I have the exact the exact same problem and the message code will not clear.
There are 2 primary paper sensors. One is the registration sensor where the paper feeds in, the second is associated with the fuser unit.
The first sensor is located under a cover under the transfer unit.
i) Open the door
ii) Lift out the transfer unit (Q3964A)
iii) Locate the black plastic cover plate with a small green flap in the centre. This assembly is directly under where the transfer unit was installed.
iv) There are 2 shiny screws that secure this cover plate. Carefully remove these screws.
v) Lift out the black cover plate by lifting the left section up first which allows the right section to come clear of gears.
vi) Check for paper obstructing the small movable lever under the cover plate.
vii) To reinstall the cover plate, insert the right hand side down first and line up with the mounting holes.
I can supply photos if required.
Posted on Sep 12, 2009
  • Stephen Lea Mar 03, 2012
    You are a star! I didn't know about that... and the moment I lifted the cover plate, there was my problem, a piece of wire under the cover plate. It didn't work first time when I reassembled, because I didn't get the cover plate back quite tight - but once I saw to that, off we went. Very many thanks.
    President:
  • Ricoh Master
  • 990 Answers
Dear Sir; You do a very good cleaning job, but you didn't use right thing to clean right place; you have to buy a can "rubber rejuvenator" (stationary store) to clean paper pick up ,feed, deliver rollers, now you still have paper jam message,you may check the paper sensor it located where the paper stop, make the sensor freely.
Posted on Jan 10, 2009
    Problem Solver:
  • 10 Answers
Change the pick roller first if still a problem the tray spring tension may need to be adjust put moore tension on the spring i seen it a lot
Posted on Jun 30, 2009
Printing envolpes and now I have jam in print paper path how do I find the the problem
If the jam is not evident in the feeder, then you need to open the printer, remove the imaging drum and look straight down to the bottom. This area is called the registration assembly and it is the most likely spot for a jam to occur. If you see any paper there, carefully remove it. Turn the printer off first before reaching in there.
Mar 23, 2011 | HP LaserJet 2840 All-In-One Printer
Error code 6A00
The 6A00 is a Canon generic code for paper path jam. Somewhere in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if it is jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs Incidentally, the 6A00 error pertains to all Canon printers made in the last several years; it is not just used in one model. And it is always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has an electrical pump to milk the print heads and test for ink flow. Move back and forth several times (with the power off)
Feb 12, 2011 | Canon MP830 All-In-One Printer
6a00
Jan 05, 2011 | Canon PIXMA MP530 All-In-One InkJet...
When trying to print from the cassette get paper jam error but no paper is jammed. It doesn't even pick up the paper in the cassette. The error will not clear. Any suggestions as to what to do? It will...
The 6A00 is a Canon generic code for paper path jam. Somewhere in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if it is jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs Incidentally, the 6A00 error pertains to all Canon printers made in the last several years; it is not just used in one model. And it is always a paper path error or purge unit.
Dec 08, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Jam in print paper path HP 2840 printer
does the paper feed at all(1/2 way) no feed,if not pick-up paper most likely will be feed motor if 1/4,1/2 or 3/4 fed will be sensor at falt or 2nd tray conectors dirty or making false contact.
May 20, 2009 | HP LaserJet 2840 All-In-One Printer
The printer cites error 6A00. I'm told that this
With thanks to a canon tech :-)
Ok Well again I will repeat this answer with a titch more detail.
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
May 07, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Printer wil not print there is a err 6a00
Your A600 is a paper path error, usually related to the purge unit. Try checking the purge unit for paper stuck in it.
          To say in detail ERR 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.The offending item needs to be removed or the purge unit needs replacement.            The purge unit is a plastic assembly (on the right side of the printer where the print head homes) that is spring loaded on rides on a rail. move it back and forth about 5 times, close everything up, and restart. Note the the purge unit is NOT the print head! to be more specific: Take out all the ink cartridge, push the cartridge holder back and forth and clean the inside without taking it apart.
            Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit. here goes, the purge unit.
Plz rate this solution.. thank you..
Apr 08, 2009 | Canon Pixma MP500 All-In-One InkJet...
Paper Jam? Print quality
If the toner wipes off the printed pages, then the fuser is the problem....not hot enough or enough pressure to heat the toner to the paper. I would try to reseat the fuser...make sure it is making good electrical contact. I have also seen the paper actually wrap around the fuser roll, which would cause the same symptoms...be careful removing the paper if that has happened...the fuser roll can be easily damaged !
Jan 22, 2009 | HP LaserJet 2840 All-In-One Printer
Paper jam in HP 4255 office jet all in one printer
the paper path may have some jam. It may have some solid particle or paper that's causing disturbance.
If not the paper moving mechanism is having problem.
Better get your printer serviced.....
Jul 17, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Paper Jam HP Color LaserJet 2840
Pull out the drum cartridge by it's green handle then
look for your paper at the timing roll section-there is a plate you can lift or release to access jams.
other than that the fuser unit on the rear of the mfc can be pulled out by moving two levers.
Jun 16, 2008 | Office Equipment & Supplies
Ricoh Aficio 250 Copier Logo
2,024 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
