Question about Panasonic PT-61DLX75 61" HDTV
I have a Panasonic PT61-DLX75 TV which I just changed the lamp and now it wont turn on at all. HELP PLS!!!!
5 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: I have a large screen panasonic tv. The lamp
Turn On tv.
Press and hold Volume Down button on TV Front and PIP/ SPLIT button on Remote at same time for 6 Seconds to reset Lamp Timer and tv will show you timer reset message screen.
Hope this info will help you.
Thanks.
Posted on Mar 31, 2010
SOURCE: Panasonic PT-52LCX65-K problem to turn on.
THERE IS A SERVICE BULLITIN BY PANASONIC IF YOU GO IN A PANASONIC SERVICE CENTER THE WILL CHANGE THE DEFECTIVE COMPONENTS IN THE BALLAST
Posted on Jun 14, 2010
hardrocko
  • 1476 Answers
SOURCE: Panasonic PT-43LC14; I changed the
terayamam001,
Here is the procedure,
1. Turn on the television
2. Press the volume down button on the TV display (not the remote)
3. While pressing the volume button, press the "split" or " PIP" button on the remote.
This should solve your problem.
Thanks for using FixYa and for the great rating!!
hardrocko
Posted on Sep 12, 2010
SD Tech
  • 14553 Answers
SOURCE: Panasonic PT50LC13 TV problem turning on TV
This is a model that was subject to a massive recall and all were supposed to have been exchanged.
Main issue was it ate lamps alive---problem was in the Ballast the set uses to drive the lamp---when they ran out of Ballasts they devised a kit to fix them--too little and too late as the class action suit was well under way.
I know as our shop was involved in picking them up working or not and delivering a brand new set---Panasonic told us they wanted (they had to) the old sets back (crusher bound) but we could take anything we wanted out of them----had over 100 remotes before it finished not to mention other things.
I do not think it is a reset issue--most likely if you owned the set from new or a long time the Ballast may not have been rebuilt or you just got lucky.
Lamps (Good oem ones) should last on average 2 years or 2,000 hours.
Another possible cause (remotely possible) is puffed up caps on the power board--I post two photos so if you look there you will know what to look for---one is mild and the other an extreme example of bad caps.
Also if the set is dusty inside use air and clean it completely out as if fans run slow from dirt the set may have issues coming on.
I hope this information helps in some way.
Posted on Jun 12, 2012
My name is Callie and my panasonic PT-60LCX64 projector tv wont turn on. I can hear it running and hear the fan, and read about a switch that needs to be pressed in but i cant find the switch.
PT-60LCX64 - Panasonic
shop.panasonic.com > Get Support
Panasonic60" Diagonal LCD Projection HDTV. ... Details http://shop.panasonic.com/support-only/PT-60LCX64.html ... Will the Touch Pen (TY-TP10U) work with my TV?
Panasonic TV Not Turning On? (PT-60LCX64)? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 13, 2010 - When I power the TV on, the green light flashes for about a minute, and ... Source(s): panasonic tv turning pt 60lcx64: https://tr.im/EBjDN ... I have apanasonic tv PT-56lCX66 and it wont turn on? Why won't my Panasonic PT-52lcx16TV turn on? Panasonic lcd rear projection 60 inch tv..model #PT-60LCX64.
Panasonic PT60LCX64 Lamp with Housing TY-LA1000
www.amazon.com > ... > Projector Accessories > Lamps
Amazon.com, Inc.
Rating: 3.8 - ‎30 reviews
PANASONIC PT-60LCX64 TV Replacement Lamp with Housing ... Howere, EVER TIME we turn the TV On a Pop Up Message comes up to Set a Lamp Timer!
Panasonic LCD Projection 1 Orange Amber Blink PT 43 50 ...
? 5:48
https://www.youtube.com/watch?v=Z9tLqxpD1qU
Apr 18, 2013 - Uploaded by norcal715
Dec 26, 2015 | Panasonic Televison & Video
I have a panasonic 52"
The tv projection lamp timer must be reset,read ur ower manual how to do that or call panasonic customers service for the help with the prosedure,sorry i don't remember how to do it anymore.The problems with the HDMI 2 setting all the time.Tries tv unplug,replug the tv back about an hour later for the tv to do a resetting itself back to the factory setting.Than go into the tv Menu changes to all the manually setting and turn off all of the auto functions of the HDMI hubs setting should solved this problems.
May 09, 2011 | Panasonic PT-52DL10 52" Rear Projection...
I changed the lamp and the tv wont turn on
hello, is the light on the tv flashing red if so make sure the lamp is fitted securely and also the lamp cover as well this down to the safety switches hope it helps
regards
shaun
Dec 25, 2010 | Panasonic PT-40LC12 40" Rear Projection...
My Panasonic PT-61LCZ70 keeps shuting off
Most likely problem is bulb failure. Replacing the bulb is first step in any LCD rear Projection troubleshooting.
PT-61LCZ70 has a special "Super Dooper" long life lamp that costs a ton to replace. US users have 5 year warranty on the lamp assembly. Canada users can whistle for help from Panasonic Canada. There is no replacement bulb available, only expensive lamp assembly.
TV has to be completely taken apart to change the lamp. Panasonic service information is 12+ pages for lamp change instruction.
Check Panasonic Lamp Gallery for an image of this lamp assembly.
easyab
Apr 22, 2010 | Panasonic PT-61LCZ70 Television
Turn On tv.
Thanks.
Mar 31, 2010 | Panasonic PT-50LC13 50" Rear Projection...
When I turn my tv on, there is a box that comes on and says replace lamp bulb and lamp timer, I changed the bulb but I do not know how to change the timer?
I can help you reset the lamp timer for your Panasonic PT-61LCX66 Projection HDTV.
Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Mar 28, 2010 | Panasonic PT-61LCX66 Television
Dec 02, 2009 | Panasonic PT-52LCX65 44" HDTV
Panasonic PT43LC14 wont turn on
hi sir im tech in electronics ,if you go to change the lamp for another check the fan that is running cool sounds like the fan does not refresh the lamp and it burn again .
Jan 11, 2009 | Panasonic PT-50LC13 50" Rear Projection...
TV WONT TURN ON
I found the problem with my set! I pulled out the lamp to inspect and low and behold the filiment was burned out. Just ordered a new lamp to replace it. That should fix it.Very easy to pull the lamp .
Dec 11, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic PT-61DLX75 61" HDTV Logo
49 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
