Question about Gemmy Life-Sized Animated Santa
Santa will do noyhing
Has power. No movement, no sound.
WE only have h im...need to purchase a adapter to plug in. Seller said mmusic did not work. Would like to get him to grow some. Please help
Posted on Nov 28, 2012
I got the stepping Santa 3 years ago. This season it just stopped. No music, no movement. I tried pulling the head off to adjust the dial - mine does not have one. Now he's headless. Help!
Points to a faulty power supply, but no information on fixing a beheaded Santa!
Troubleshooting No power No power Make sure adaptor is plugged into a working outlet. Product Support
Jan 14, 2016 | Cars & Trucks
Sony wega 42 flat screen no remote,turn on button stays red noyhing else happens
Set might be OFF using the remote control's power Off button. If so, you must have a remote control to power it ON. Any remote control to Sony will work.
Sep 16, 2013 | Samsung Televison & Video
Just don't know how this hooks up and works please help?
There are two components to your monitor - the sound sensor and the movement sensor.
The movement sensor is a pad that is placed underneath the crib mattress on a solid surface - if you just have springs supporting the mattress, you may need to buy a piece of plywood to place underneath the mattress. The pad is connected by a cable to the movement sensor port on the sound monitor. The other connection on the sound monitor is the power. So, position the sensor pad under the crib mattress, then plug it into the sound monitor and connect the listening unit to a power source.
You have two listening units. Just plug them in and set them to the same channel (A or B) as your sound monitor. You'll hear what's going on in the nursery, and if the movement sensor doesn't sense movement for 30 seconds, it'll chirp. If it still doesn't sense movement for another 10 seconds, an alarm will sound.
Feb 27, 2011 | Graco Angelcare Movement Sensor With Sound...
2004 Hyundai Santa Fe? squeaky noise frnt driver side wheel
I do think the same way. If the pads look flat and not so worn have the rotor turned to eliminate the squeaksyou are encountering
May 31, 2010 | 2004 Hyundai Santa Fe
Dell computer was working and i turned it on next day and it was dead no lights or noyhing
If your computer is under warranty, I'd suggest you contact either the Vendor where you bought it, or the Dell support site. Either should be able to acquire a new power supply and install it for you free of charge (if under warranty).
Some other thoughts though, before you do that. If there are no indicators that your power supply has died (smell burnt electronics, any weird buzzing sound prior to the computer not working, etceteras), then you might want to check the connections to the wall socket, the connection to the PSU itself, and even test the circuit breaker for your socket (some wall sockets have test / reset buttons that cut the power during surges).
-Jon
Sep 26, 2009 | Dell POWER SUPPLY Power Supply
The train sounds but there is no movement. battery been charged overnight.
MAKE SURE CONNECTIN GOOD W/TRACKS THEN CHECK BATT.CONNECTIONS ALOT OF TIMES IT IS THE CONNECTION
Jul 15, 2009 | Peg Perego IGED1084 Santa Fe Train
Hyundai santa fe 03 running problems
If your Santa Fe has a V6 engine 2.7L , it sounds like you have an ignition break down happening. You will need to renew all the ignition wires and check the two coils also for arcing .
Mar 28, 2009 | 2003 Hyundai Santa Fe
2003 Hyundai Santa Fe Lost power now won't start
Sounds like the timming belt jumped or broke. A faulty crank sensor could also be at fault.
When asking a question about a problem with your vehicle you should always state your vehicles od reading and engine size, thanks.
Mar 19, 2009 | 2003 Hyundai Santa Fe
Say's it is printing but is not
Sounds like you are on a Mac, if so use a different method to add printer.
Try a different port than the one you are using.
Oct 24, 2008 | Office Equipment & Supplies
Gemmy Life-Sized Animated Santa Logo
161 people viewed this question
Top Gemmy Toys Experts
NOEL
NOEL
Are you a Gemmy Toy Expert? Answer questions, earn points and help others
