Question about Sony Audio Players & Recorders
Receiver sony str365
My receiver has a protector problem
2 Suggested Answers
smarthome2
  • 1114 Answers
SOURCE: Sony STR-GX800ES receiver "protector" blinking - no sound
The most common problem found on FixYa for Audio Video2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jun 13, 2010
How do i get my sony DA30ES am -fm reciever out of protector mode
Here is a guide for you: STR DA30ES Protect
let us know how , if you need further assistance.
Jun 09, 2012 | Sony STR-DA30ES Receiver
My sony str- is getting a sony protector check code 22. Is that a fuse problem or do i have to get sony to fix it? napa.king@yahoo.com
Unfortunately this is not a fuse problem, as the fuse would burn before the protector check code appears. Probably there is a short circuit and you should take to an authorized sony repair shop. Good Luck.
Flavio/BRAZIL
Jul 22, 2010 | Sony STR-DA5000ES Receiver
How do I correct protector code 11 on sony str da3100es?
Sometimes the protector code means audio amplifier IC fried and need to replace him
May 13, 2009 | Sony STR-DA3100ES 7.1 Channels Receiver
Receiver goes into protector mode
Nope, power supply it would not even power up.  The capacitors are fried
Jan 04, 2009 | Sony STR-DE635 Receiver
PROTECTOR MESSAGE
Yes, It is receiver internal issue.
Jan 02, 2009 | Sony STR-DG820 Receiver
Sony da333es : protector (fan) ;how do I fix this
It's warning you that the fan is dead or clogged. Look at it and possibly clean out the dust bunnies.
Dec 26, 2008 | Sony STR-DE898 Receiver
Stuck protector mode
find out why the fuse blew in the first place.the protector is just PROTECTING the main circuits of the receiver.the receiver turns on just to confirm the power circuit is OK.
have it checked by an electronic engineer.
Apr 16, 2008 | Sony STR-DE597 Receiver
Protector mode SONY STR D1011S am fm receiver
I've had this happen, it's when you have speaker wires crossed.....
Dec 27, 2007 | Sony STR-DE945 Receiver
Sony GX800ES protector
Make sure none of the speaker wires are touching each other. If they are, it will short out the stereo which triggers protection mode and cuts out all of the sound.
Sep 21, 2007 | Sony STR-GX800ES Receiver
19 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
