Question about ASUS K52F Notebook
Asus k55a will not recognize my network
My Ipad works fine. Is there a wyfi switch to turn on?
  • ASUS Master
  • 27,725 Answers
Turn on your computer and locate the Wi-Fi icon.
This could be located on the upper row on a laptop keyboard it should have a key something like (((.))) press it on
The internet connection is located in the system tray in the bottom-right corner of the screen.
The icon looks like a series of rectangles that increase in size from left to right.
Right-click the Wi-Fi icon and select "Connect to a network." You will see a list of available wireless networks.
Choose a Wi-Fi network you want to connect to and select "Connect."
Enter the password into the password text box if a password is required.
If a password is not required, you will automatically connect to the Wi-Fi network.
Click "OK."
Posted on Nov 27, 2012
  • gwfarmer42
    gwfarmer42 Nov 29, 2012
    The solution was successful. Thank you for the help!
  • Brian Sullivan
    Brian Sullivan Nov 29, 2012
    Thanks for getting back with the good news hope it all goes well for you
How to connect to internet doesnt recognize router password
Are you sure of Wifi password is correct?
if so, 1st; try restarting your ipad by holding down power/sleep button untill it show "Slide to shut down" leave it off for 10 seconds & then re-open it.enter the Wifi -password, sometimes this step works.
2nd solution ; try resetting your iPad network settings, it will not affect your ipad in any thing except it will forget all entered passwords for any wifi you have already connected before. go to General from Setting, choose resett, and inside only reset network setting, shut down ipad & try to connect to the wifi again. Hope this solution work for you. Also you may try shutting down & opening your router again after 10 seconds while off. Good Luck.
May 19, 2016 | Apple iPad Mini
Asus k55a will not turn on. Power light comes on, fan comes on. No hard drive noise or any other light. Running windows 8.1
Take it back to where you bought it and ask them to check the Power Pak. But it sounds like the Hard drive has bit the dust.
Feb 02, 2015 | ASUS Computers & Internet
ASUS K55A won't boot from OS installation on C: Drive. HDD does not show on BIOs boot.
try re seating the drive and your ram. if it does not show then your hard drive is bad.
Dec 28, 2014 | ASUS K55a 15.6-Inch Laptop Black Intel...
"k55A" dc jack replacement
Hello Kenneth,
The dc jack replacement cable connects from the white connector to system board and the connector where you connect the adapter lay on the edge of board usuallyc6c10d03-2117-4a84-8cc2-a16171601653.jpg
I like to use a litte bit of super glue to keep it held in place on the board.
Gotta remove some components to access it .
Mar 12, 2014 | ASUS Notebook K55A-DB51 15.6inch Core...
Asus k55a-rbr6 Cd Drive not recognized in Devices and Printers, will not run any CD.
The Asus K55A-RBR6 optical drive uses the Windows built-in driver. The drive may have failed or it could have a power or cable issue. To check for a power issue, try ejecting the optical drive by pushing the disc tray into the computer. If the drive tray ejects and retracts, it has power.
First, go to the Device Manager and check if there are any driver issues identified by Windows. (Click Start > Control Panel (in the right hand column. Click on either System and Security > System or Hardware and Devices and then select the Device Manager. Expand the section for DVD/CD-ROM drives and look for a yellow triangle with an exclamation point or a red triangle with an x. Try to uninstall the driver and then reboot the machine. Windows will try to restore the driver. (You should alsocheck Windows Update for any optional drivers. Start > Control Panel > System > Windows Update.)
Check that you have installed the latest available BIOS upgrade (407), from http://www.asus.com/Notebooks_Ultrabooks/K55A/#support .
The laptop uses a SATA slimline internal optical drive. The drive needs a power connector from the internal power supply and a SATA cable connected to the motherboard. You can access these if you disassemble the laptop. You may want to try just replacing the drive (~$25 at many vendors). If the second drive doesn't work, then try replacing the SATA cable and make sure it's well seated at the motherboard and the optical drive. There aren't extra power cables in most laptops but you should check for damage. Alternatively, get an external USB optical drive to replace the internal drive.
I hope this helps.
Nov 15, 2013 | ASUS Computers & Internet
Touchpad enable
you enable/disable touchpad by pressing the Fn-key and press F9 at the same time.
Sep 07, 2013 | ASUS Notebooks K55a-xh51 15.6" Led...
My asus n61j won't connect to the Internet using internal adapter
Hi there, I just bought a new Asus NJ series, and all of a sudden my wireless dissapeared! I FOUND THE SULOTION, well, I hope it works for you. Look on the left side of your laptop, right at the front left side is a switch/button. I think I accidentally switched it of, but now everything is working fine!
Feb 04, 2010 | Computers & Internet
ASUS K52F Notebook Logo
642 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
