Question about Frigidaire FGQ332ES Gas Dryer
Dryer starts, runs a short while, then shuts off!
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
Does the dryer shut off or do you mean the heat shuts down?
Posted on Nov 27, 2012
Why does my dryer stop heating
Clean your vent!
Try running dryer with vent unhooked if still shuts off could be bad thermostat. Try running on timed dry instead of sensor dry, could be sensor circuit.
Aug 30, 2014 | Whirlpool Dryers
Why does my GE Dryer shut off prematurely?
sorry but sounds like u may have a bad motor, going out. does it make u wait about 30-60 minutes before u can turn it back on? then it runs for a short while andf goes out agin?
Aug 15, 2014 | Dryers
My Kenmore dryer runs for for ten minutes then shuts off. It also pops the circuit breaker. The drawer runs fine and then just turns off. Heats up. Lint is all clear, but don't know why it shuts off?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Either the motor gets hot and blows the breaker or if it is electric the heater element gets hot and then shorts out...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 09, 2010 | Kenmore Dryers
Hoover dryer runs for a short time then shuts down , once it is cool it can be started again.
heatman101
Aug 17, 2010 | Dryers
Runs when PTS held but shuts off when released/no heat
No problem at all.The motor has a start and run winding.Your run winding is bad.The reason you have no heat is the run winding has to run to close the contacts on the motor switch.Replace the motor ,both problems solved. Hope this helps Please rate my response :)
Dec 13, 2009 | Kenmore Washing Machines
Dryer runs for about 5 minutes and shuts off.
You may have a faulty motor winding or run capacitor.If the motor wind is shorted it will get hot and the thermal cutout goes open circuit (inside motor)and it starts again when cool.Also check that the air flow is OK eg Some models have a separate fan belt.Hope this helps.Cheers.
Jul 28, 2009 | Whirlpool Dryers
Neptune mdg3000aww starts heating and runs fine but stops heating shortly after start up can restart heater starts again and shuts down
If the machine keeps running but just not heating you have a thermostat issue. It could be the operating therm. or the high temp limit therm malfunctioning, shutting off the element.
If the machine stops running completely, check the door switch.
Jul 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer won't stay running. It will start, run 10-15 seconds, then shut off. I can restart it immediately but get the same results.
i would check the door switch. it may be worn just enough that the vibration of the dryer opens the circuit for just a moment. then check for other loose connections. the fact that you can restart immediately usually indicates a momentary break in the circuit. a temperature switch usually takes a short time to reset. while it's still running, try rattling various switches or smack the door to see if it shuts off. (just a couple of simple ideas to start with).
good luck....jay
May 21, 2009 | Maytag Dryers
Roper dryer won't shut off
The timer motor isn't moving the timer. You'll need to replace the timer. Turning the timer **** to off should stop the machine.
Exception: If the shutting the door automatically starts the motor, then the start switch/relay is probably shorted.
Mar 10, 2008 | Roper REX4634KQ Electric Dryer
Dryer and breaker
you have a week breaker or a breaker that is to small you need a 40 amp breaker 20 on each side (two breakers locked into one) or worse you have a short in the dryer. If dryer runs for a little bit and then shuts down its the breaker.if it throws breaker as soon as you plug it in or start it then the short is in your dryer good luck
Dec 29, 2007 | Maytag HYE3658AY Electric Dryer
Frigidaire FGQ332ES Gas Dryer Logo
63 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
