Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox 50" DLP will not turn on after bulb went out
I replaced the bulb and the tv still is not turning on. The power indicator light is turned on but when I push the power button the other 2 lights flash on then off and nothing happens
  • 1 more comment
  • jmill1082 Jan 12, 2009
    Only the power indicator light
  • jlp_55721 Feb 24, 2009
    I put a new lamp in, now when I turn it on the screen stays black. I can see that the lamp is working. I also can't turn it off with the regular power button. I have to turn the side power button off
  • Chuck May 11, 2010
    any lights on the front panel blinking after the set turns off
  • Philips Master
  • 5,138 Answers
If Fan is not runnung set will not come on.
Posted on Jan 10, 2009
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
Dec 09, 2015 | Televison & Video
Why does my magnavox 52 inch dlp make a fairly loud humming noise for 10 minutes or so after turning the tV on? It gradually get quieter.
It is likely a bad fan that gets quiter as it warms up from use. There are two fans on that TV - one under the bulb housing and one at the left vent hole. They are special fans with three leads - +, - and an RPM indicator (yellow lead typically).
Apr 24, 2014 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox tv when the power button is pressed the green light comes on but nothing else happens; there's no picture or sound or nothing; but the green light simply stays lit (no blinking).
first, press the channel -/+ button on the TV. If that doesn't turn on the TV, then it means you have to replace the bulb of your TV. The bulb is most likely dead.
Replace the bulb and your TV should be restored.
Let me know if you need further assistance.
Regards.
Aug 12, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox 50ML8105D/17. We moved and the tv worked fine and now nothing. Just 2 red lights. Temp and Bulb. I replaced the bulb about 6 months ago. all I did was move.I carried it myself. I have checked and...
My magnavox died due to cheap capacitors on power supply board, a common problem for magnavox tv's from wot i found on net!
I replaced a 2200uf 10v electrolytic capacitor and it works now:)
My tv would take a few atempts to turn on and finally would not turn on,light stayed red!
i recommend visually checking for bulging or blown capacitors on power board, if it all looks good, try warming the board with a hair dryer, this might be just enough to get it to fire up, so at least u know the prob is in that area.
I looked for a 2200uf capacitor near the low voltage output from board n replaced it, got lucky first one, I was expecting to replace all the low voltage electrolytic capacitors.
Justin
Feb 02, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Replaced the bulb on a 50ML8105D/17, the bulb starts to light but turns off at 5 seconds and the red led light on the front comes on.
Hi,try to reset lamp timer by unplugging tv wait 5 min and plug it back again.Check for clicking sounds it could be the ballast which is the board that powers the lamp that it could be bad.God bless you!
Oct 06, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My magnavox 50" DLP 50ML815D/17 will turn on and broadcast fine, but after about 30-40 minutes of viewing it will turn itself off & a red light comes on. If you feel the tv close to the bulb area it is...
Yes there is a Fan that keeps Lamp cool if it stops running Lamp will shut off it is designed that way to keep lamp cool also if Fans are OK it means Lamp is going out Call Mats 1-800-628-1118 for lamp
Sep 19, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
DLP HDTV shut off, sound but no picture
replace light bulb,
if you are hearing a click like the stove is because the lamp balast is trying to power on the lamp,
if you need part number and vendor please send me the model number
Apr 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
No power, lost power while watching tv
after picture is lost, does the screen remain lighting?
Jan 13, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox 50" DLP Tv power light comes on but then i hear a buzzing noise and then two red lights come on the tv. at no point does the picture turn on during this time. Can you please give me a possible...
Your bulb is burned out. I have had the same problem. It seems this television has an overheating problem--and short bulb life. I have had our 50 Magnavox dlp for two years and just put in the second bulb before Christmas. You can buy the bulb from a dealer on ebay for $99 and install it yourself. I is not in the housing so you have to carefully take out 4 screws and replace the bulb without touching the face of the bulb. To buy the one from Magnavox with the housing is much more expensive. I think the first time my husband replaced the bulb it took about 45 minutes--this time it took about 20.
Dec 16, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
347 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
