Question about Casio Music
I have a Casio CDP-120 digital piano and I need disassembly instructions to service noisy keys
I'm concerned about taking out the wrong screws, so would appreciate specific instructions. And I had read that there's a thin layer of felt which should be reinforced. Perhaps someone could verify that, and suggest some methods that might work. Thanks.
danforddan1
  • 192 Answers
SOURCE: Loose keys on my wonderful Technics digital piano
You would be very surprised of how few moving parts are in side one of these keyboards. There is no fix to the action,trust me. play the day lights out of it until it stops then get a new one. Have some fun and explore, if you find an old one that is shot, take it a part and you will see what I mean. These units are really a disposable instrument.
I hope this doesn't disappoint you . I hope it helped. Keep on rockin in the free world. DFD
Posted on Apr 13, 2009
  • 1138 Answers
SOURCE: Need to get instructions how to use the metronome
Check the manuals for the Eurogrand EG540/EG1040 (which are apparently similar but discontinued) at this site:http://behringer-en.custhelp.com/cgi-bin/behringer_en.cfg/php/enduser/std_alp.php?sm=2
Posted on Oct 18, 2009
Prestopick
SOURCE: I need a service manual for Roland FP8 piano, or..
Did you ever get hold of an FP-8 service manual? The weight replacement is relatively simple: The case opens by removal of eight screws, four at each end on the underside. The top then hinges up. Keyboard assembly is removed by first unplugging the two white ribbon connectors at the center, then removing the screws at the front edge (underneath) and the screws (gold) at the back of the assembly (accessible from the top). Keys pop out by spreading the two "wings" at the pivot point, and then the weights (Roland calls them "hammers") lift out. Roland will sell you new ones, but I have no idea whether the replacements are any better than the originals. I've done two of these pianos so far, and have a third waiting to be worked on. I do have a service manual, but I think I downloaded it freebee somewhere.
The other failure mode on this piano is the electolytic coupling caps on the output board - I've replaced all of them on both pianos - don't remember the value offhand.
Paul Prestopino presto11@verizon.net
Posted on Nov 19, 2009
SOURCE: Key won't come back up on Roland digital piano
Roland FP is a nice keyboard but has a known problem on cracking key weights. There is a counter weight under each key to push the key upward. There are two sizes of weight beams, longer one for white keys and shorter one for black keys. Roland did not make the original weight beams strong enough to last. They will crack and eventually break. When it happens, the key will stay down. Fortunately, they can be easily replaced.
Roland FP-8 has 4 black screws at the bottom on each side end. Remove the screws, flip the ends up and expose the interior. Near the hinge of the problematic key, carefully ply open the hinge tabs and remove the key from the hinge. You will find a weight beam under the key. Remove and inspect the weight. There should be a metal wrapped in a plastic beam. If the metal part is missing, find the missing part and replace with a new beam. You can order weight beams from Roland. It costs about $10 each plus shipping. Put everything back in the reversed order.
Posted on Jul 03, 2010
  • 5603 Answers
SOURCE: I Have a Casio Privia
Yep... Roland pedals are reversed, that is, normally closed contacts. Unlike some Yamaha keyboards, the Casio doesn't have an inversion function available. You have two choices to solve this: 1. Buy a pedal with the corect sense 2. Open the Roland pedal and MAYBE with a soldering iron you can move a wire to select a contact with the opposite sense.
Posted on Aug 05, 2011
CDP100 CASIO PIANO VOLUME CONTROL SCRATCHY. UNABLE TO ACCESS THE POTENTIOMETER. PL HELP
Try this first with the piano off, run the control from stop to stop rapidly several times. The object is to clean off any dust deposits and shine the contacts inside the pot. If the pot is not damaged beyond repair, then this should fix it.
Dec 05, 2016 | Casio Cdp-100 88 Note Digital Piano
I have a Casio cdp 100 keyboard and two of the keys are stuck in the down position. Almost like the spring has gone in these 2 keys. Can this be fixed and if so, how?
is it under warranty ?
if not
you may have to contact your point of sale to find their local repairer
if you cant un stick them yourself that keyboard will have to be taken apart
are the two keys ... white keys or black ...nearby or way apart
do the two keys drop loose..and lift up
or stay down
example will vacuum cleaner suction help lift the stuck keys or not
sales blurp says this
A spring-less hammer system
Scaled Hammer Action Keyboard
https://www.jbhifi.com.au/musical-instruments/casio/casio-cdp-120-digital-piano/91120
Jul 31, 2016 | Casio Music
What is causing noises in my Casio privia Digital piano?
Pivots worn out or need lubricant. Make a warranty claim first.Otherwise, If out of warranty I would try to lubricate the hammer pivots myself. You will need "grease suitable for plastics".
Jun 10, 2014 | Casio Privia PX-350 Digital Piano Black...
Casio CDP - 120 turns itself off
Casio CDP has Auto Power Off: 30 minutes after last key operation, Auto Power Off can be disabled.
Please read the manual.
If it turns itself off while playing, I would try to buy a new AC Adapter to test. DC cable of AC adapters are often broken internally after much "bending".
Jan 06, 2014 | Casio Music
Casio - 120 Turns itself off randomly
I have a Casio digital piano and some keys stopped working after my daughter finished "cleaning" the piano. I'm thinking maybe a fuse needs to be replaced?? Some keys plays and some do not. Any
Old reply so hopefully it's fixed. Dust or hair can get through the gaps and land on or near the contacts of the electronic key sensors. To be on the safe side (rather than doing a diy) take it in to the technicians. They'll have it fixed in a jiffy
Feb 25, 2013 | Casio Privia Px-130 Px130 88 Key Digital...
I Have a Casio Privia Digital Piano and a Roland DP-10 pedal. The pedal function is inverted. When I press it stops the sustain and the effect comes back when I release the pedal. The pedal does not have...
Aug 05, 2011 | Casio Privia Px330 Px-330 88 Key Digital...
Yamaha P-120 Piano: Graded Hammer (NOT key) dysfunction?
My opinion is you should take the instrument to a yamaha authorized service center.. It's doubtful this will be user serviceable, particularly if the problem isn't on all the keys, and the service center will have access to the parts needed as well as more information from Yamaha than they will share with an end user.
Mar 15, 2017 | Yamaha Music
Music Logo
701 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
