Question about pch.com
Wb300 Hope I did this right. I'm sure what I am doing.
    Sergeant:
  • 198 Answers
Whats the problem
Posted on Nov 27, 2012
How fix it:''windows was unable to complete the format''
You have to be the computers administrator to change any values on any hard drive on your computer
click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
click start click on my computer you should see your usb drive
right click then select format
another way is to control panel administrative tools computer management disk management right click on your drive select format
hope this helps
Nov 08, 2012 | Computers & Internet
WHEN MAKING A BOTTON HOLE THE RIGHT SIDE SEWS GREAT BUT THE LEFT DOESN''T? WHAT CAN I DO TO CORRECT THIS?
you may have to use a washable stablizer when doing the buttonhole
also check to make sure you have the right needle & the right thread for the fabric
Mar 08, 2012 | Singer 8280 Mechanical Sewing Machine
Ive just installed two 12in kicker cvr's and i bought the kenwood kac 7205, and ive hooked up everything right and used a digital multimeter to check that the current is coming throught but the amp...
So you check the remote wire to make sure there is 0.5amps running through it, right? Check the fuses of the amp? Checked your ground? Hope this helps
Aug 22, 2011 | Car Audio & Video
I have just installed my JVC KD-R720 in dash reciever in my 1999 Pontiac grand am and also have subwoofers. The amp turns on but i am getting nothing to the subs. I know its not the amps connection cause...
Check a few things. Make sure the head unit is getting power. Then make sure that your RCA cables are connected to the right output RCA's fromt the head unit. If this is ok, check to make sure the RCA cables didn't get crimped somewhere. If this is still all ok, check the volume on the unit and to see if you have the unit on mute. Sometimes it's little things like that. Did you adjust any settings to the amp? If so, check the gains. Hope this helps.
Aug 18, 2011 | JVC Car Audio & Video
Can you tell me where I can order a power cord for this older model dvd writer?
I'm not quite sure which model you're referring to since you haven't mentioned it. But generally speaking, you won't be able to order another ac cord without spending a lot of money.
Try looking at some universal adapters that come with different tips from your local electronic store. See if the tips plug into the ac jack of your writer. So long as you can select the right voltage and ~ right amp, it should get you going with 20, 30 bucks.
Hope this helped...
Jul 14, 2011 | Computers & Internet
The volume is very low & I can't find any way of increasing it; I don't want to add separate speakers as I have my phone linked to a headset via "internetcalls.com",in which the...
if you are referring to a computer with your microphone & headset attached
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
hope this helps
Jul 04, 2011 | Computers & Internet
I have a transcend 4GB pendrive. it has become write protected due to virus. how can i format it. i have tried many processes but can't get my pendrive formatted.pls help
Some usb keys or flash drives have a little switch thatlocks it & makes it read only. Try looking for something like this. Or youtry following these steps:
For USBdrives:
1. Open Start -> Run...
2. type diskmgmt.msc and press enter
3. right click on the partitin you want to format (where the leter and is)
4. select 'Delete Partition...' and confirm
5. right mose button in the same place and select 'Create partition'
6. select primary partition
6. select , file format, disk leter, label etc should be all right if youleave defaults.
7. click ok
This will recreat the partition and format it in proper way.
I hope this information will be helpful. Thank you for using FixYa!
Please vote if it helped you.
Jun 27, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Right side low beam headlight is out. I replaced it. It still does not work. I am sure it is a fuse.. I do not have my owners manual to see which fuse corresponds to that head light.The high beam does...
The fuse for the right (passenger) side low beam headlamp is located in the fuse box under the hood in the engine compartment. Below I gave you a picture of the fuse layout and the fuse you are looking for is the fuse in the number 6 location and should be a 10 amp fuse. I hope you don't take this the wrong way but some people get right and left mixed up and don't understand when you are talking right and left, it's as if you are sitting in the car. I just to make sure you have the correct fuse. If you happen to be talking about the "drivers" side low beam, that fuses is in the number 1 position in that same panel. I hope this helps you and good luck.
Jun 19, 2011 | 2007 Honda Accord Sedan
I cannot format my USB. it's write protected.
Some usb keys or flash drives have a little switch that locks it & makes it read only. Try looking for something like this. Or you try following these steps:
For USB drives:
3. right click on the partitin you want to format (where the leter and size is)
6. select size, file forma, disk leter, label etc should be all right if you leave defaults.
7. click ok
Jun 13, 2011 | PQI 512MB Intelligent Stick USB 2.0 Flash...
N64 Games Show Green-Grey Screen
Having a green/grey screen shows there is signs of life. I believe the power supply that's the problem. In my recent experience the following solution has helped me:
1.) Wiggle the power supply left & right two times. Now try and see if the Nintendo 64 works.
2.) If not, then disconnect and reconnect the power supply and wiggle the power supply left & right twice. Again, try and see if it works.
I hope it works for you!
Mar 13, 2009 | Nintendo 64 Console
pch.com Logo
18 people viewed this question
Top pch.com Computers & Internet Experts
James Castro
Level 1 Expert
tony wahlman
tony wahlman
Are you a pch.com Computer and Internet Expert? Answer questions, earn points and help others
