Question about Whirlpool Dryers
Whirlpool duet dryer goes to sensing..but wont turn on
Duet dryer
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
The control board senses the inlet thermistor shorted. The inlet thermistor is a part of the hi-limit thermostat which is located on the heating element box. Here is the part to order.
Posted on Nov 27, 2012
SOURCE: Whirlpool Duet dryer won't move past sensing function on any cycl
Found the culprit. The thermal fuse was blown. Had no conductivity with ohm meter so I placed a jumper around it and presto dryer runs. Cleaned the exhaust and fan but found no blockage and really was not that bad. Hoping maybe just a weak part. The model on the Whirlpool Duet electric dryer is GEW9250PWL I believe the the last three are just the color. The part number on the Thermal Fuse is #3392519. This is easy to get to through the front panel just below the load door. Hope this helps some else out.
Posted on Jan 22, 2009
SOURCE: whirlpool duet front loader dryer....sensing light won;t shut off
I have a whirlpool electric dryer and it cuts off and shows E 1... What is the problem?
Posted on Apr 21, 2009
localwonder
  • 6784 Answers
SOURCE: I turn the dryer on (Duet GEW9250pw1) and it just
HI. Your unit is equipped with an electrode(moisture sensor). This sensor helps the unit, in conjunction with the thermostats, to dry the contents during the cycle selected. This error is concerning this sensors integrity. It may be covered with lint, in return, preventing it to sense the moisture correctly, or the sensor may be damaged as well. It is locate just behind the Grill on the outlet lint screen door. I recommend to clean this sensor properly. if the unit continues to show the error code(sensing), this will confirm that the sensor is damaged, and it must be replaced in this case.
Posted on Oct 29, 2009
SOURCE: Error code E6 on a Whirlpool Duet Dryer
Whirlpool Duet electric dryer only dries clothes on heavy duty selection. what is wrong?
Posted on Jan 19, 2010
heatman101
  • 43501 Answers
SOURCE: whirlpool duet GEW9250PW1 electric dryer squeals
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Posted on Apr 06, 2010
Testimonial: "Thanks, so now how do I get the extended warranty plan to pay for it. They will not send someone out for squeaks and squeals. "
Why wont whirlpool duet dryer model WED8300SW1 heat?
Is the dryer gas or electric? But you can also try cleaning the vent tube the pipe that goes outside also the pipe that goes into the dryer it's a good chance it's full of lint.
May 07, 2014 | Whirlpool Dryers
Whirlpool duet dryer - when using the settings that automatically sense if the clothing is dry the dryer is saying the clothes are dry but the clothing is still damp
Easy fix: Look inside the drum below where the filter goes in. You will see two metal strips. They sense the wetness. Now get this: the dryer sheets rub against them and a thin wax buildup on them prevents the controls from properly determining wetness. The control has no clue the clothes are still damp and thinks everything is kosher; so it advances to the end. Solution. Clean the stuff off of the sensors so that they can sense the true wetness once again.
May 22, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet front loader dryer....sensing light won;t shut off
Apr 01, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer problem
You need to listen for the motor working ? Open the dryer door hold the door switch in and start the dryer . A buzzing sound may indicate a bad motor. If you hear a slight spinning noise ,it may just be the belt.
Sep 24, 2008 | Dryers
Whirlpool Duet dryer won't start F30
well the sensing light will stay on till it feels wet clothes against it if you in auto dry mode it says it wont start without feeling wet clothes against the silver bars in the vent housing it says it will run in manuel mode even if it doesn't feel them pull the top off the dryer and on the right hand side is a tech service sheet in a plastic bag see what it says
Mar 30, 2008 | Dryers
Whirpool duet dryer quit working
chould be a fuse inside dryer its oblong white ck it but unplug dryer first
Mar 21, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
592 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
