Question about Danze D135300BT Single Handle 3/4 Volume Control Valve
My Danze showerhead runs even when turned off
I have three of these valves in my shower and recently one of them began running even when the valve is completely closed. It seems that water is leaking around the cartridge - not a good seal. Danze has send me three replacement cartridges, but all of them begin to leak within 10 minutes of installing them in the valve. Weird thing is that if I move one of the original cartridges from another valve, the leak stops. Danze tells me there is only one cartridge and there's no chance they are mailing me the wrong part. Any help would be appreciated - I've run out of ideas!
  • 51 Answers
Try cleaning the inside of the valve with 1500 grit wet sandpaper. and then put a lot of waterproof plumbing grease in there and also on the cartridge. sometimes you can get a build up of hard water inside the valve body and that will cause leaks. just dont over do it with the sandpaper and dont anything more abrasive than 1500 grit.
Posted on Dec 18, 2012
2 Suggested Answers
SOURCE: Getting into Danze Roman faucet to unscrew it
I don't want to pay for anything.  I didn't realize there was a fee attached until I got to the last part so I just shut my computer down without selecting a payment and still you contacted me.  No thanks!  Remove me.
Posted on Jun 23, 2009
Danze shower on off valve leaking. How do i repair it?
This a common problem with most shower valves.After time the internal parts of the valve wear and need to be replaced. You can purchase a new shower cartridge for about $50.00 at your local hardware or on line. Be sure to turn off the water before removing the old cartridge. Install instructions should be included or go to Danze.com
Dec 02, 2016 | Danze Home
How do I set the stops? with the valve close the white moval stop is against the the fixed stop - where should the black movable stop be when the valve is closed> Also what is the function of the stop -...
the white is a temp limiter stop...and the black is a personal temp setting...the white at max temp should be up to the brass stop and the black is adjustable to personal adjustments...good luck
Aug 28, 2011 | Danze D500558T Parma Shower w/ 4"...
When I rotate the shower handle up to the point where hot water starts to mix in I get a 'moaning' type sound and a very low vibration. The last time I replaced the valve the vibration was very...
The seal for the hot water is loose, allowing it to vibrate and give you that noise. The springs will go into the valve body, replacing the old springs and giving the seal more strength to resist vibrating from the water flow. I bet they give you directions, if not a good plumbing supply store may be able to walk you through it. Sorry to say I'm not familiar with your brand, but the generic problem is quite common.
Jun 01, 2011 | Danze D500558BN Parma Shower w/ 4"...
New installed no water flow?Water is flowing before and after the tub;so not a problem with valves or line???
If flow is slow to shower,pull showerhead,small watersaver hole and screen have garbage in it,teflon tape-rust sand etc Tub spout working fine?
Jan 28, 2011 | Danze Sheridan Tub & Shower Faucet
Installed new tub/shower valve, water comes out of showerhead when water is turned on even though spout is open
the diverter valve is probably bad. put a new one in. the valve cuts off the water to shower, while running bath water.
Nov 23, 2010 | Delta Faucet Plumbing
Shower valve has a thumping sound when other faucets or toilets are turned on and off.when you turn shut offs to danze shower valve off sound goes away.could this possibly be the plunger in the valve?
Vfiippone,
I have the same issue with a Danze Sonora shower Valve. I called Daze and they sent me a new cartridge. After installing it I have the same problem. I also put a surge arrester on my toilet which had little effect. If you find the cure please post it.
Nov 04, 2010 | Danze D500058BNT Parma Shower Trim Kit w/...
Danze pressure balance single handle shower faucet (D500558BN) pipes vibrate when adjusting hot and cold water.
it the valve is full of dirt or needs to replaced not all the time but i have fix many buy just cleaning it out or pipes are fasten down. try just cleaning.
Jun 10, 2009 | Danze D500558BN Parma Shower w/ 4"...
Danze control valves producing loud water hammer
It sounds like your flow diverter isn't closing properly. Try removing the flow restrictors from the shower nozzle and see if that helps.
Apr 06, 2009 | Danze D500058BNT Parma Shower Trim Kit w/...
Water leaking from tap when turned off
In order to remove the Danze handle from this particular model grasp the handle of the valve and then the body of the valve and turn the body counter clockwise in order to remove.
Hope this helps.
If you don't have a supply house near you that carries parts for the Danze products you can go to danze.com and order them there.
sanray
Jan 02, 2009 | Danze D500058BNT Parma Shower Trim Kit w/...
Danze shower kit
your husband is 100% correct unless you change the shower head or take the one off that is there and take out the little plastic filter thats right inside where it screw on to the shower arm,, easy fix
Nov 09, 2008 | Danze D500558T Parma Shower w/ 4"...
Danze D135300BT Single Handle 3/4 Volume Control Valve Logo
166 people viewed this question
Top Danze Home Experts
Mike
Rabbit Brains
Rabbit Brains
Mike Herrington
Mike Herrington
Level 1 Expert
Are you a Danze Home Expert? Answer questions, earn points and help others
