Question about Acer Aspire 5742 Laptop/notebook
I have an acer aspire 5742 ....the problem is when i turn my laptop on ..it shows acer logo during POST and then restarts again ....i tried pressing f2 to go to system settings but system settings do
I know about computers and understand that my hard disk has malfunctioned .......actually i was running about 10 different tasks and watching a movie too ....movie got stuck (vlc media player) when i tried to forward a scene.....now my friend pressed the power button to turn the laptop off....i think at this moment sone read/write operation was being performed by read/write head of the HDD and when turned off read/write head remained there (did not come back to its default position = boot secor).normally when we turn laptop off the read write head moves back to boot sector so that it can start booting when we turn the device ON again ..but read/write head of my HDD is stuck where i turned the laptop off ...how can i get the read/write head of HDD to come to its proper place ...????plz
  • Acer Master
  • 2,878 Answers
Try System File Checker. It finds and replaces corrupted system files. You may need a copy of OS. At command prompt type sfc /scannow ENTER.
You can also use the Win 7 install disc:
Boot with a Win 7 disc, and choose Repair Your Computer. Then use Startup Repair option. Type bootrec /fixboot ENTER if end up at the command prompt. It does the same thing.
Posted on Nov 27, 2012
Testimonial: "i tries your solution ...sadly it did not work ...but it was a possibility ...thanks "
  • 1 more comment
  • abdul moueed Nov 29, 2012
    i tried boooting from a win 7 bootable cd and from a bootable flash drive having backtrack5 and linux.....but the laptop does not boot....after post (when logo of acer is displayed ) laptop restarts automatically...and does not try to boot from cd or flash(flash was plugged in the usb port and cd was already inserted in drive)....i removed the hard disk drive from laptop and tried to boot from flash ...now laptop booted correctly from flash drive ....now i know...when harddisk is inserted in laptop it can not boot from any media(here boot sequence is 1.USB flash drive ,2.dvd drive ,3. HDD primary...so boot sequence is not an issue) .....when harddisk is removed, laptop boots correctly...the problem is with harddisk and i took it to a repairs shop and they could not fix it ...when i start laptop ..ticking noise is heard from HDD...now i want to ask following : 1).can my HDD be fixed(without opening using software or anything) ? ,2).can my HDD be fixed(by opening it or any method)? , 3). if it cant be repaired how the data on it can be recovered(through software or hardware utilities)?....thanks in anticipation ....
  • Jose Diaz
    Jose Diaz Nov 30, 2012
    It sounds like physical damage. The cost to fix is very expensive, more than a new computer, but try to connect as an external drive with an adapter.
  • abdul moueed Dec 01, 2012
    i tried that too :D ....but unsuccessful ....the HDD is not recognized when connected to an external hard disk adapter...anything that i can try
2 Suggested Answers
  • 77 Answers
SOURCE: the acer t120 computer frezes up and have to restart
If you are looking for a new hard drive, then I would highly suggest a Seagate Barracuda for size/speed verses cost.
1 Terrabyte version: http://stores.tomshardware.com/search_getprod.php/masterid=48683394/mode=toms_charts/
750 GB version: http://stores.tomshardware.com/search_getprod.php?masterid=60350382&mode=toms_charts
160 GB Version: http://stores.tomshardware.com/search_getprod.php?masterid=683289&mode=toms_charts
One thing I would suggest is booting up and run a disk (error) check and select the option for scan and attempt recovery of bad sectors. If you need help on running that let me know what operating system you have and I can walk you through it.
Posted on Mar 13, 2009
My Acer aspire turns on shows windows logo then goes to black screen, what can I do?
Depending on your version of windows, I would trying starting in safe mode to see if the computer does boot. If it does, then you want to restart again, go to advanced boot options and select "start windows with last known good configuration." Access advanced boot options following the steps at this link. Need to Start Windows 7 in Safe Mode Here How
Jul 18, 2015 | Acer Computers & Internet
How can I start up my Acer Aspire 5733-6410 in Safe Mode
Restart your laptop.
After it shows acer logo..Press F8 multiple times... (preferably 3 to 5 times)
a screen will show you multiple options.. Select Safe mode (this will be first option and then hit enter... It will show you your Window name (windows 7 / windows xp) press enter again and it will boot your window in safe mode
regards,
Bilal
May 31, 2014 | Acer Aspire 5600 Series 5630-6951 Laptop
My acer laptop showing ACER logo and press F2 to setup and restarts every 5 seconds . Changed 2 GB RAMs one by one and checked up. But problem not solved. Only on removal of battery the laptop could...
If machine not booting it could be a bad cmos, hard drive, mo bo, peripheral, corrupted OS, bad power supply, bad memory,
Remove the hard drive and see if it posts and then gives you message that there no boot drive If that does not happen then machine is not even posting which means something is wrong with the cmos. - not a good thing.
Sep 23, 2017 | Acer Aspire 5742 Notebook
Need manual for aspire5742-6439
Got here as quick as I could.............just a minute, I'm out of breath!
Whew!
Acer Aspire 5742-6439 product review,
http://techwiki.hardwarecanucks.com/product/2MTExNTc4NQ/Acer-Aspire-AS5742-6439-Notebook/#pics
For specifications in case you need them.
Acer Aspire 5742 series disassembly guide,
http://www.laptopguides.info/acer/acer-aspire-5742-service-manual/
On this page go down to the bottom of the paragraph, and left-click right on - Acer Aspire 5742 Service Manual.
It works, I'm looking at the Service Manual right now.
Aspire 5742/5742G/5247Z/5742ZG Series Service Guide
[ The above is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name ( Acer Aspire 5743 Service Manual), it may take up to 30 seconds, before the first page comes up ]
Not what you had in mind?
User Guide,
http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=3277
Now, may I ask what the problem is? Post back in a Comment.
Regards,
joecoolvette
May 13, 2012 | Computers & Internet
Factory reset without using a disk and ALT + F10 doesnt work
his MIGHT work:
1. Click "Start," "Turn Off Computer" and then "Restart", if it is on. If your computer is off, turn it on by pressing the power button above the keyboard.
2. Press the "F2" function key on your computer's keyboard to enter the BIOS utility.
3. Use the laptop's right arrow key to scroll to "Main." Confirm that the "D2D Recovery" is "Enabled." If the D2D option is "Disabled," scroll down to the option using the down arrow key. Press "Enter" to change the option to "Enabled."
4. Use the laptop's right arrow key to scroll to "Exit." The "Exit Saving Changes" option will be highlighted. Press "Enter" to save the settings and exit the BIOS utility. Your Acer Aspire will restart.
Reformatting the Acer Aspire
1. Press the "ALT" and "F10" keys together while your computer is restarting and the Acer logo is showing to enter the Acer Aspire's reformatting utility.
2. Follow the on-screen prompts. Your laptop's hard drive will reformat and the original applications will be reinstalled. Your computer will restart after the reformatting process is complete.
3. Enter your name and other personal information when prompted during the Windows operating system setup process.
Mar 22, 2011 | Acer Aspire One PC Notebook
I want to restore my acer aspire 5741 to factory settings but when i go to restore it, a message comes up saying hard drive configuration is not set to the factory default. reboot aborted.
Before performing a restore operation, please check the BIOS settings. To activate the BIOS utility, press F2 during post.
To start the recovery process:
1. Restart the system.
2. While the Acer logo is showing, press <Alt> + <F10> at the same time to enter the recovery process.
3. Refer to onsreen instructions to perform system recovery.
Follow this steps.
Thank you for using FixYa.com
Jan 08, 2011 | Acer Aspire 5100 Notebook
Hi I bought a new ACER 5742 laptop yesterday. Its not recognising the CD's but showing the D:/ drive I have uninstalled the CD-ROM and restarted laptop, but doesn't help me.
AS you bought it yesterday, I wouldn't mess with it. Take it back and accept it again when the sales person demonstrates it working or demand a replacement.
Dec 31, 2010 | Acer Aspire 5742Z-4200 Notebook
Acer Aspire 5742 Laptop/notebook Logo
126 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
