Question about Broan-NuTone CV450 Central Bagged Central System Vacuum
My cv450 nutune wont shut off, I have to pull the power switch
Is it the relay something else
    Scholar:
  • 95 Answers
It should be the relay and that is very easy to change out yourself.
Posted on Feb 13, 2009
Our cv450 wont turn on when plugging into the wall or using the rocker switch on the unit, there is power to the outlet, the unit is 12 years old,any suggestions to further diagnose?
Check the filter. If it's dirty, the motor will overheat, resulting in the machine shutting off.
Rinse thoroughly in warm water, and allow to air dry thoroughly before reinstalling. I recommend having two filters so you have one to use while the other is drying.
Other problems are possible, but generally entail taking the vacuum to a repair shop for diagnosis and repair.
Feb 12, 2011 | Broan-NuTone CV450 Central Bagged Central...
Will not turn off when hose is pulled out of wall
Some units have an on/off switch on the power unit itself. Check to make sure that is not turned on. Unplug your power unit and remove the 2 low voltage wires (not the power cord itself) . The low voltage wires start at the unit and run throught your home and attach to each hose inlet. They are usually attached to the unit by simple wire terminals or wire capped to small wires coming out. Just unlug the terminals or unscrew the wire caps and pull the connections apart. Plug your machine back in. If it still comes on the problem is the relay or circuit board/switch/ relay assembly inside the unit. If it doesn't come on with the low voltage wires unattached then you may have two wires touching somewhere in the low voltage wiring.
Jan 26, 2010 | Broan-NuTone CV450 Central Bagged Central...
My nutone vacuum system won't shut off when I pull the hose out of the wall...any thoughts
The relay that turns the machine off from any of the several places where you connect, is probably stuck.
The relay is operated by low voltage. When you connect your hose, you comlete the low voltage circuit and energize the 110 volt system, and the machine comes on. When you pull the hose out, the relay is suppose to release.
those are my thoughts
I hope this is of value to you.
a
Sep 27, 2009 | Broan-NuTone CV450 Central Bagged Central...
I need a relay board for a Nutone CV 450 12.6 amp dual motor vacumn unit. Where can I locate one? Part #??? Unit will run by itself, then shut off. Unit wll not run at all. It has a mind of its own....
Unfortunately I don't have a part number for you, but you can call this number 1800.322.2965. Tell them you need a new relay board for your system and they'll be able to help you. They cost around 99$. for anything else you might need, go to www.thinkvacuums.com
Sep 01, 2009 | Broan-NuTone CV450 Central Bagged Central...
Vacuum won't shut off
the relay is most likely the problem, they get burnt and the contacts stay together leaving the unit on. Try www.builtinvacuum.com for parts.
Aug 20, 2009 | Broan-NuTone CV450 Central Bagged Central...
My nutone cv556 wont shut off
It sounds like the relay is bad. This website has a pretty good trouble shooting page.
https://www.centralvacuumstores.com/cvs/trouble_help.php#wont_turn_on
Sep 28, 2008 | Broan-NuTone CV450 Central Bagged Central...
Unit will not turn on
Unplug the vacuum unit from the wall. If it is hard wired turn off the circuit breaker
Jul 30, 2008 | Broan-NuTone CV450 Central Bagged Central...
Nutone CV 450
If the top comes off, it will be by the motor and exhaust. Just replace it with the new one, make sure you don't mix up any wires. Also unplug it from the AC first.
Jun 22, 2008 | Broan-NuTone CV450 Central Bagged Central...
Broan-NuTone CV450 Central Bagged Central System Vacuum Logo
219 people viewed this question
Top Broan-NuTone Vacuums Experts
Steve
Gerry Harvey
Gerry Harvey
JoeVacs
Are you a Broan-NuTone Vacuum Expert? Answer questions, earn points and help others
