The audio is distorted for your TV or the settings for the sounds have become mismatched or the speakers are speakers are not working on your TV the fans might be broken with your TV and the TV is starting to malfunction.
Hi Clair, thank you for allowing me to assist you.
When the refrigerator is
beeping or buzzing, it may be a warning sign of a possible malfunction or an
unsafe, interior temperature. To silence the buzzer, you can depress the ALARM
OFF button. However, if you have already done this, try unplugging the unit or
flipping the household circuit breaker for about ten minutes.
If the alarm continues, it could possibly be experiencing a
communication problem with the temperature control/board or wiring failure. I
would recommend connecting with a professional appliance tech for a clear-cut
diagnosis.
You said, your Frigidaire freezer 17 cu. ft. , it keeps buzzing or peeping The alarm may be malfunctioning or it may be warning you of low temperature. You can go to any hard ware store and buy a refrigerator thermometer and ask them if it can go into a freezer too!It can, But ask anyway!
If it is cold enough then it is a faulty alarm going off. Your freezer may be equipped with an alarm. Here is some information that may help you find it and turn it off if you wish Temp Alarm (audible only or audible with warning light)
This feature is designed to provide a warning of possible malfunction. If the
temperature of the food rises to a level unsafe for long-term storage, the buzzer will
sound. The red light will also glow on models so equipped. The Temp Alarm feature
operates on household electricity. If power fails, the alarm will not perform. An ON/
OFF switch allows you to deactivate the Temp Alarm when not wanted. The freezer
is shipped with Temp Alarm in the OFF position. After freezer has run approximately
4 hours, the red light, if equipped, will go off. Then you may activate the Temp Alarm
without the alarm sounding.
Press the ON switch to activate the Temp Alarm. To deactivate, press the OFF switch.
If the alarm sounds, be sure freezer is properly leveled, and the door closes freely, and
seals properly. If you suspect a technical malfunction, call an authorized servicer
immediately.
Let me no what you find. Huuum Please remember to leave a rating before you leave
That black disc is the "backup" alarm if you lose power.... The battery then takes over and "buzzs" throught that little speaker too wake you... even tho there is no power... Mine buzzes too... cut that little speaker outta there.!
