Question about Acer AL1912 19" LCD Monitor
The screen height is to high - Acer AL1912 19" LCD Monitor
Cs-21m16ml tv has lines lower half of screen and screen height slightly reduced and non linear. help
You're losing your high voltage to the picture tube. Have it checked at a repair shop. The voltages present on the tube will knock you on your a** if you're not careful.
Nov 17, 2014 | Televison & Video
The size on the TV Guide on Screen is too small, can that be changed?
Take your Shaw Remote Control.
Press SETTINGS.
Use the LEFT/RIGHT buttons to highlight the "home" icon.
Press OK.
Press the DOWN button to highlight the "Setup" button.
Press OK.
Highlight GUIDE SETUP.
Press OK.
Select GRID CELL HEIGHT.
Set it to DOUBLE HEIGHT.
Press OK
Press EXIT.
Mar 16, 2014 | Samsung Heating & Cooling
How do I adjust screen margins on ILO tv?
The picture height to your TV is too high. Check whether Zoom action is On or not. If it is ON, make it OFF.
Aug 11, 2012 | iLO IWT3206 TV
The Automatic Height Control is stuck in between high and neutral. It doesn't seem to react to when I shift to lo position to neutral. It did move to high but did not fully return neutral height. I...
this sounds like a height sensor is broken in the rear....ur best bet is to bring it to a qualified service repair center an have body codes pulled on this....if the height sensor is the prob it will be a easy repair since they r located on the control arms which have easy access...this will also cause the vsc lite to come on since the height control is incorporated into this circuit...as for ur nav screen its sounds like a seperate problem but codes can also be pulled for this also....i would say for the nav screen to take it to a lexus dealer, im sure they have seen this prob before so u wont be paying extra labor time for them to find the prob
Jul 15, 2011 | 2005 Lexus GX470
How to enlarge a picture that is scanned or copied? When i scan or copy a picture it is too small and I want to enlarge it in order to view it better.
hi
Open an image. Go to the Image Menu and select Image Size. This is where you can change an image’s resolution and print size (width and height). The following Image Size dialog box will appear:
Notethat the width and the height of the image as you view it on yourmonitor is not necessarily representative of the image’s actual widthand height—i.e., the size it would print out at (print size).Average monitor resolution is 72 dpi. If you view a 72 dpi image at100% in Photoshop, chances are that it will appear on your screen inits actual print size. However, this is not true when viewing a 300 dpiimage. A 300 dpi image viewed on-screen at 100% will be enormous. Don’tget tricked into believing that what you see on your monitor is whatyou’ll get when you print or place the image into another application.The best way to determine what your image’s actual print size will beis through the Image Size dialog box.
When the Resample Imagebox is checked, any changes you make to an image’s width or height willnot change the image’s resolution, and as such, any changes you make toan image’s resolution will not affect the image’s width and height.Keep in mind, however, when you increase width and height, orresolution, with the Resample Image box checked, you are adding pixelsto your image. These pixels don’t actually exist so Photoshop mustcreate them. As such, you will succeed only in degrading the quality ofyour image.
If you want to increase an image’swidth and height, or resolution, then uncheck the Resample Image box.Now any changes you make to the image’s width and height will changethe image’s resolution, and vice versa:
  • If you decrease resolution, the width and height will increase.
  • If you increase resolution, the width and height will decrease.
  • If you increase the width or height, the resolution will decrease.
  • If you decrease the width or height, the resolution will increase.
Thebest way to increase the width and height of a scanned image is to scanthe image in at a high resolution (about twice what your finalresolution should be), and with the Resample Image box unchecked, decrease the resolution. Once the image width and height is where you want it, you can then check the Resample Imagebox and type in the resolution you want if the resolution is too high.At this point, as long as you don’t increase resolution, or width andheight, your image quality will not suffer.
Aug 07, 2010 | HP Officejet 5610 All-In-One InkJet...
How do you adjust a headlight from pointing up to the right height
VERTICAL AIM ADJUSTMENT
1. Park the vehicle on a level surface approximately 7.6 meters (25 feet)
from a vertical wall or screen directly in front of it.
2. Measure the height from the
center of your headlamp to the
ground and mark a 2.4 meter (8
foot) horizontal reference line on
the vertical wall or screen at this
height (a piece of masking tape
works well). The center of the lamp
is marked by a 3.0 mm circle on the
headlamp lens.
3. Turn on the low beam headlamps to illuminate the wall or screen and
open the hood.
4. On the wall or screen you will
observe a light pattern with a
distinct horizontal edge of high
intensity light with a slight angle
towards the right. If this edge is not
at the horizontal reference line, the
beam will need to be adjusted.
5. Locate the vertical adjuster on
each headlamp, then use a 4 mm
socket/wrench to turn the adjuster
either counterclockwise (to adjust
down) or clockwise (to adjust up)
aligning the upper edge of the light
pattern up to the horizontal line
6. HORIZONTAL AIM IS NOT
REQUIRED FOR THIS VEHICLE
AND IS NON-ADJUSTABLE.
Mar 09, 2010 | 2002 Ford Explorer
Picture height adjustment
The screen parameters were factory set by firmware programing during production.
If over time the picture became out of spec, this is due to some components that have changed in characteristics with use and age.
The fix is to have the set properly serviced. The tech will have to troubleshoot the set to find the defective parts and change them.
Jerry G.
Jul 13, 2008 | RCA F27636BC 27" TV
Acer AL1912 19" LCD Monitor Logo
32 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
