Question about Philips Magnavox 27MS343S 27" TV
Magnavox 27ms3435 child lock on no remote how can i remove child lock and use
5 Suggested Answers
night71
  • 327 Answers
SOURCE: magnavox child lock
In a lot of cases you can just unplug the tele and leave it for about 24 hrs. This should erase the memory and if you will have to reprogram all your channels again,clock and so forth.
Posted on Oct 30, 2007
SOURCE: magnavox child lock tv
my remote control doesn't work, and i can turn the tv on because i lock to just use with the remote control. How can turn the tv on if i do not have a remote control?
Posted on Jan 20, 2008
  • 4 Answers
SOURCE: 27" MAGNAVOX W/ CHILD LOCK ON- NO REMOTE!
hi just thought id let yo all no i had the same problem with a waltham but all i had to do was use a phillips remote that was lying around it had all the right buttons and was for a normal tv 32" not hd or flat =0) im not saying this will help every one but its possible that other remotes might work too!
p.s. its worth a try
Posted on Jun 30, 2008
SOURCE: remove child lock
i have a beko tv which i want someone should help me find ser vicemode
Posted on Jul 07, 2008
praky16
  • 744 Answers
SOURCE: How to turn off child lock without remote on LG tv.
hi..To do a Child Lock, follow these steps:
  1. Turn on your TV.
  2. On the remote, press the Menu button. The Set-Up Menu appears.
  3. Scroll to the Key Lock function and set function to Off.
  4. Press the Exit button to exit....
ur problem will be solved.. rate me!!!!
thank u
Posted on Apr 10, 2009
Megapower. how do I remove the child lock without a remote?
How to reset "Child lock" on TV without remote ' Electronics Forum ...
www.electro-tech-online.com > ... > Repairing Electronics
Apr 8, 2010 - 21 posts - ‎11 authors
I opened the TV, but no "switch" on the PCB to do a "reset to factory". ... You almost certainly need the remote, and also the service manual that .... and I was able to get into the menu by remote and to disable the Child lock.
How to disable child lock on Magnavox 27MS343S without remote - TV ...
www.tv-forums.com/.../How_to_disable_child_lock_on_Magnavox_27...
Sep 23, 2012 - 7 posts - ‎3 authors
Hello, I have accidentally turned on the child lock (not parental lock) on my Magnavox 27MS343S for which I do not have a remote. Since the ... panasonic television child lock
Apr 21, 2012
Apr 8, 2010
More results from www.tv-forums.com
Jan 01, 2016 | Televison & Video
Did you try disconnecting the TV overnight to reset it?
Feb 09, 2008 | Philips Magnavox 27MS343S 27" TV
Son lost remote for his tv and the child lock has come on how do i turn it off
THE SOLUTION FOR THIS FIX, AS IT WORKED FOR ME....I WAS LOCKED OUT BBY THE DUMB CHILD LOCK FOR TWO MONTHS, BOOUGHT A NEW REMOTE THAT DIDNT WORK....GET A 10$ REMOTE FROM THE STORE, AND ENTER CODE 0224 IT KILLS THE CHILD LOCK FEATURE..THEN YOU CAN POWER ON THE TV..GO TO MENU AND SELECT CHILD LOCK AND DEACTIVATE IT! THANKS ALOT MAGNAVOX..IT WAS NOT IN THE MANUAL FOR THE TV OR THE REMOTE FOR THE TV EITHER......CAPERS~
Oct 04, 2011 | Philips Magnavox 27MS343S 27" TV
My magnavox tv has no remote and it has child lock how to unlock?
Use this web link http://www.m4c.magnavox.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=TV_CONVENTIONAL_CA&sct=TV_LARGE_25_29_SU&grp=TV_GR&session=20090602164521_68.190.209.25&ctn=27MS343S&mid=Link_UserManuals&hlt=Link_UserManuals to go to the Magnavox website and view a copy of the owners manual on pages 23 & 24. It will explains how to change the setting of the lock with the front panel controls. If this does not work for you you can call Magnavox customer support at this telephone number 1-800-705-200. Give them the model number of you television and tell them the problem you are having with the child lock.Locking you out of the television operation.I hope this information helps you with your problem.
Jun 02, 2009 | Philips Magnavox 27MS343S 27" TV
take ur tv to someone local who fixes tvs. they will have a magnavox remote. use the remote and press tv/av simultaneously pressing enter
Apr 16, 2009 | Philips Magnavox 27MS343S 27" TV
Child lock
you will need your original remote control and go through the menu to unlock it. find your original remote control by typing in your TV model number in the search on www.replacementremotes.com and your original remote will pop right up. very easy to use.
May 31, 2008 | Philips Magnavox Learning Universal Remote
Child lock
hi.... i did child lock my tv magnavox and can't turn on ,,,because my remote control is broke now.. so tell me please how could turn on my tv Please Tanks...
Feb 20, 2008 | Philips Magnavox 27MS343S 27" TV
Magnavox child lock tv
Jan 20, 2008 | Philips Magnavox 27MS343S 27" TV
Child lock
I called Philips Magnavox to be sure because i have the same issue. Yes you do have to have the original remote and they do not sell it directly from the manufacturer. I was given a website from the rep that I spoke with so that I could buy the original remote. It is www.andrewselectronics.com and the part number is 996500015582 and the price listed is 47.37.
Jan 13, 2008 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 27MS343S 27" TV Logo
112 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
