Question about Mad Catz PS3 Bluetooth® Headset Wireless Headset
When i connect my bt headset to my ps3 it automatically turns the bt headset off.it is compatible and sinked.
  • Anonymous Mar 31, 2009
    mine too
Did you already pair the device to the ps3? usually the security code is 0000.
Posted on Jan 10, 2009
Driver for bluetooth headset Genius BT-03A
go to add hardware option and search your device and when it says to install the software select the option to install it automatically and then you will be asked for an internet connection and the software will be installed automatically
Apr 07, 2012 | Genius BT-03A Bluetooth Headset
How do i connect my motorolla hz800 bluetooth to ps3
I think i've figured it out. I have turned the multi-point connection off and then paired the Finiti with my phone and PS3 separately. Just make sure that you have your phone's bluetooth connection or other device turned off before turning on your PS3, and then make the connection between Finiti and PS3 and you should be good. Then when you're done using the PS3, and its powered off, you can turn the phone BT connection back on and you should be good.
Jan 07, 2012 | Motorola Mobility FINITI Headset
I bought a madcatz bluetooth headset for ps3 and it wont connect and let me scan. it was made in 2007. Any way I can fix it??
did it ever work for you are you holding the power-sync button long enough on the bt headset's load up light should stay solid or keep blinking till it sync's up start the ps3 bluetooth settings to start looking while you start to connect it hope that helps if not the bt set could be faulty try syncing it to a cell phone
Nov 17, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
No sound from bluetooth headset when paired w/ ps3 and audio set
the bluetooth headset is not compatible.get a compatible headset for ps3
Dec 03, 2009 | Sony Playstation 3 (PS3) Console
Bluetooth setup
You need to pair your phone with your bluetooth headset.
  1. Turn on your phone's bluetooth and search for bluetooth devices.
  2. While the phoneis searching and the BT headset is off, press and hold the call/end button on the bluetooth headset until it's light glows steadily. Do not let go until the phone finds it.
  3. Pair the devices and allow the BT headset to connect automatically.
  4. To connect, press and hold call/end button on BT headset like the one in step 2.
Nov 11, 2009 | Radio Communications
Im trying to set up my blue tooth to work on my ps3 but no signal is found what am i doing wrong?
You need to pair your PS3 with your bluetooth headset.
  1. Turn on your PS3's bluetooth and search for bluetooth devices.
  2. While the PS3 is searching and the BT headset is off, press and hold the call/end button on the bluetooth headset until it's light glows steadily. Do not let go until the PS3 finds it.
Oct 25, 2009 | Samsung WEP410 Bluetooth Headset Wireless...
Connecting blue tooth headset to PS3
the headset needs to be compliant with proper usb standards
Bluetooth version (ver 1.1, 1.2, 2.0 (2.1?)) for ps3.
makesure the headset is fully charged, and follow the user guide.
if the code is not 0000, then try 1234,, or 9999
here is the link for the connecting to ps3 guide from sony blog
http://boardsus.playstation.com/playstation/board/message?message.uid=26900460
May 15, 2008 | Cell Phones
How do i hook my bluetooth to my ps3
After you have connected the headset to the PS3™ system, you can verify that the PS3™ system is receiving voice input from the headset
and that the headset is correctly playing output.
To test and configure your headset
In your PS3™ system’s home menu, go to [Settings] > [Accessory Settings] > [Audio Device Settings].
After you pair a Bluetooth® device with the PS3™ system, the Bluetooth® device becomes the default for both input and output audio. If the
headset is working correctly, you can hear your voice loopback in the headset. The audio input bar will indicate your voice level.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Mad Catz PS3 Bluetooth® Headset Wireless Headset Logo
144 people viewed this question
Top Mad Catz Radio Communications Experts
TO Lady
Michael Vincent Cruz
Tom Chichester
Are you a Mad Catz Radio Communication Expert? Answer questions, earn points and help others
