Question about RCA Televison & Video
RCA 20F514TD has lost horizontal hold. How can I adjust this? I have found no button or menu option discussed in the manual or by searching.
Adjust screen horizontal position on a 20F514TD SDTV/DVD combo unit
    Top Expert:
  • RCA Master
  • 74,482 Answers
Horizontal rolling is the fault to your TV I assumes. It is a circuit fault. It can't be adjusted by customer controls. Contact any experienced service technician.
Posted on Nov 27, 2012
  • wesred123
    wesred123 Nov 27, 2012
    its not rolling, just shifted by ~1in.
  • The Knight
    The Knight Nov 27, 2012
    If so, you have to enter its 'Service Menu' option. Not user menu will do. Check this link. It might help you.
4 Suggested Answers
  • 3 Answers
SOURCE: horizontal adjustment.
I have the same problem. Just what is the repair?
Garry Meyer gfm001@aol.com
Posted on Jul 27, 2008
  • 33 Answers
SOURCE: lost remote control. can't change language
It is always more difficult to operate the menu features of a tv using the manual buttons on the tv. I recommend you unplug the ac cord of the tv from the wall for a day while you go out and buy a universal remote control. After plugging the tv back in and turning it on initially most television on screen prompts immediately direct you to the set up menu which includes setting the language.
Follow the instructions on the universal remote and program the remote to the tv using the power button on the remote to determine if you have reached the right code. It will then be possible to operate the menu features of the tv via the remote control and thus change the language back to english.
Posted on Apr 28, 2009
  • 139 Answers
SOURCE: Can't find menu on hotel tv
YOU WILL NEED THE SPECIAL REMOTE TO DO THIS. AND I THINK SOME OF THEM HAVE ABILITY IN SERVICE MENU TO TURN OFF HOTEL MODE. OR YOU CAN TRY USING ANY PHILLIPS/MAGNAVOX REMOTE WITH THE STATUS BUTTON AND TRY THIS.
PRESS MENU-9-6-5-2-STATUS AND YOU SHOULD BE IN THE SERVICE MODE TURN OFF THE HOTEL MODE
Posted on Dec 28, 2009
I have a jvc kdhdr50......and I'm wondering how to adjust the bass and treble also how to turn the loudness on
This is discussed on page 26 of manual. Press and hold MENU and select USER for EQ. Under EQ you will have options to adjust SUB BASS, BASS, MID BASS, ULTRA HIGH, HIGH, MID HIGH, AND MID
Aug 10, 2014 | Car Audio & Video
Green convergence is off on RCA p52955 how to fix
i can manually, or auto adjust the convergence in the set-up menu of my RCA, take a look at your options after hitting the 'menu' button
Oct 23, 2013 | RCA P52955 52" Rear Projection Television
Which service manual setting controls horizontal size?
You're discussing about the factory mode adjustments. The horizontal width adjustments will not be there. You have to adjust it by replacing certain capacitors at the horizontal output stage.
May 18, 2013 | Panasonic CT-20G6 20" TV
It has tripple vision and looks like a bow tie.
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    Need code to enter on remote to engage multipoint convergence adjustments.Need save proceedure after adjustments are made & exit proceedure for RCA Projection TV Model # HD52W59, ITC 222A
    To get the code to enter on your remote to engage multipoint convergence adjustments, you need to contact the rca customer care for that, you get them your model number and they will get your code for you.
    To process and save the adjustment made, follow the steps below;
    1. Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
    2. Enter the menu on your TV. Use the remote control and bring up the menu.
    3. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
    4. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
    5. Press "Enter." A crosshair pattern will appear on your screen.
    6. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
    7. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
    8. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
    9. Repeat these steps for all colors.
    Take care
    Jul 06, 2010 | Televison & Video
    How do I change the date and time in my Emerson EM2646 phone? I lost my manual. Thx
    Follow the following steps :
    1. Press and hold the dial/menu button until “Options Menu” is shown in the display.
    2. Use the up/down buttons to scroll through the options below, and press the dial/menu
    button to select the desired option you wish to set:
    • Set Language
    • Local Area Code
    • Set Time/Date
    • Set Flash Time
    • LED Contrast
    • Set Tone/Pulse
    • Exit Options
    3. Use the up/down buttons to adjust the setting, and press the dial/menu button to confirm
    and set.
    Manual is available in the following link,
    http://southerntelecom.com/emersonsupport/downloads/EM2646.pdf
    Jun 01, 2010 | Emerson EMSEM2646WH Phone
    Zoom adjust on RCA D52W19 tv WITHOUT remote
    if you have the original remote, your right and left arrow keys adjust the size, if size changes during commercials, get into your options and turn off the auto-size option, if you don't have the original remote, you must find a universal with proper mright and left arrow buttons.
    Sep 15, 2009 | RCA D52W19 52" Rear Projection Television
    Viewsonic VX2235wm Horizontal Image Problem
    Tricky one. Have you tried using different dispay resolutions from your Windows Display Control Panel?
    ie 1200x1014, 1600x1400, etc.
    When you say you used the manual adjust, do you mean the horizontal sync option?
    Did you perform a Settings Recall?
    And most monitors have a way of entering into an engineering "Factory Service Menu". Usually by depressing specific buttons while the monitor is OFF, and then pressing the power button while still holding the others. Then let all button go at once. From there, hit the normal button that you use for getting into the OSD. In the OSD, there's usually a new field with all kinds of cool new settings to play with. One of them being a soft reset. You'll have to search the net for how to enter into your Factory service menu.
    Oh wait! I know!
    If your picture has moved to the right, move yourself accordingly.
    So that now you and your picture will be aligned properly.
    He he he...
    Kidding!
    That one was from ViewSonic customer support.
    Apr 03, 2009 | ViewSonic VX2235wm LCD Monitor
    Zoom control
    Use the menu key on the set it has a size selection in the menu set it on widescreen or 16:9 I suggest buying a new original remote as even a new RCA universal remote may not have the ZOOM or aspect control on them.
    Aug 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
    Manual for timex 609t alarm clock
    you should be able to just push the Time button (top one third from the right) and when it starts to blink, just change it like you change the alarm.
    Oct 17, 2007 | Audio Players & Recorders
    Televison & Video Logo
    110 people viewed this question
    Top RCA Televison & Video Experts
    matt martin
    matt martin
    Computer Repairing
    Computer Repairing
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
