Question about Bunn Pour-Omatic Coffeemaker, 10 Cup White
Burnt out light bulb
The on/off swith is burnt out. How do I fix it?
    Genius:
  • 1,673 Answers
You would have to order the part from the manufacture if you were to fix it yourself. It may need new crimp connectors for the switch.
It is best to take the coffeemaker to an appliance service center. There are some serious safety issues when servicing these appliances. The internal parts are not always simple to replace. They use crimped wire connectors and specialized parts. There are crimping tools required to replace these connectors.
For something like a coffeemaker you may find it not feasible to service. The parts and labor can add up to a fair amount.
Jerry G.
Posted on Jan 10, 2009
Location of turn signal relay 2005 mdx
Check under the hood for the computer or relay center, it could be under the dashboard on the driver side against the wall.
Apr 11, 2014 | 2005 Acura MDX
Deivers tail light/brake light do not work..reverse works..when i lock my car the lights flash except for that one and the drivers light..headlights work fine though.drivers headlight bulb connector looks...
Could be a broken wire at the socket. Sounds like a burnt bulb also. Sometimes a burnt bulb will do the same thing as you are describing. Once you get this fixed, all should work. If flashing to quickly, replace the flasher stat unit!
Sep 04, 2013 | Volkswagen GTI Cars & Trucks
While the brake lights and turn signals work, the tail lights do not.
The earth connection is simply the chassis ground on the vehicle. "Ground" and "earth" refer to exactly the same thing. Either the light swith is bad ,you have a fuse that looks good but is actually burnt out,or the wire that runs back to the tail lights is broken.
Oct 13, 2012 | 1995 Ford Explorer
Right turn signal flashes fast
One of the bulbs is burnt out. Turn on hazard lights and check bulbs.
Dec 31, 2010 | 2005 Ford Taurus
My flashers wont flash any longer but the light just stays on and I have to keep moving the swith up and down to notifiy people that I am turning.
change the flasher fuse. Also, check to see if any of your bulbs are burnt out. On most cars, this will cause the signals not to work properly.
Jun 15, 2010 | 2003 Audi A6
Turn lights come on but do not blink
This means that one of the bulbs somewhere is burnt out. Its a fail safe to get the consumer to fix burnt out lights. if you do not have a bad bulb then it is the flasher, this is located in you fuse box. It needs to be replaced. ($5)
Jan 08, 2010 | 1994 GMC Jimmy
Left rear brake light stopped working but bulb and fuses are OK.
These are Dual Function Bulbs. They control the Parking Lights and the Brake Lights. This Bulb is Burnt out on the Brake Coil inside the Bulb. I have actually seen Bulbs that were Bad But you could not Tell by jast looking at them. It should be fine with a New Bulb. Please Rate My Response! Thanks!
Feb 05, 2009 | 1999 Ford Expedition
Brake Light Problem
the bulbs are a dual philament eventhough the tail lights work the brake light part of the bulb is burnt out
Sep 03, 2008 | 2006 Hyundai Sonata
Bunn Pour-Omatic Coffeemaker, 10 Cup White Logo
137 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
