Question about Pool & Spa
How do you heat up a eurospa canterbury hot tub
Spa thermal overheating
Turn off all power to the hot tub as soon as you realize it is overheating. The spa should have an automatic shut off when the water temperature reaches about 112 degrees fahrenheit. Call your hot tub dealer or manufacturer for service options. There are a variety of conditions that could lead to the overheating of your hot tub, but may differ in various hot tub models and brands. Check the water level of the hot tub. Low water levels could be the culprit for the over heating, so you may just need to add more water to the hot tub.
Check the shut-off valves in the hot tub. If they are closed while the hot tub heater is on, it could cause the water to reach unsafe temperatures.
Clean the hot tub filter. A dirty filter could be blocking the flow of water, causing the water to sit in the hot tub and overheat.
Turn the power back on after finding the problem and talking to the hot tub dealer. The hot tub will probably not start back up until the water reaches a safe temperature
Jan 06, 2012 | Endless Summer Pool & Spa
Hot tub won't sence heat display says 70 and water is 114. All i did was shut the breaker off and change the seals. i have checked all the cables in and out of the control panel. Do you think it could be...
Yes ... it is not working or it is disconnected ... You have a serious defect somewhere.
Please, NEVER GET INTO WATER MORE THAN 105f ... and if it is at 105 ... limit your stay to 15 minutes ... Never put a kid into water that is more than 98. Modern hot tubs are not suppose to heat above 105.
not to mention it cost you a arm and a leg to heat that water ...
May 14, 2010 | Pool & Spa
My hot tub will not heat up. The motor is running
sounds like the heating element has gone to the next life,.....you can test it with an ohm tester,....MAKE SURE POWER OFF WHILE WORKING ON IT!!!! but no doubt it just needs a "heating element" cracklin joe
Jan 05, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Savannah spas
probably a dirty filter!! take it out turn tub off to reset turn back on with filter out and c if nthis solves problem if so replace filter.
Nov 20, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
Pump is running ever 5 minutes. The heat in the
Sounds as if the 'mode' for the tub is set to sense the temperature of the water. see if there is a setting on the control box to a 'timed' setting for filtering and heating instead of controlled by the temperature setting. the problem is the the control box is away from the water and when it calls for heat it is because the water is cooler there than in the hot tub. so when it calls for heat and the water starts to circulate it gets the hot water from the body of the hot tub and then shut down because it senses the 'hot water'. make sense?
Feb 23, 2009 | Blue Wave Aruba 15' Round 54" Resin Pool...
Jaccuzi hot tub will not heat?
sounds like it maybe the heater again. Have you pulled it out and checked the ohms? it should be at least 10.5 ohms
it could be the thermostat or the pressure switch - if either of those are not working it will not heat either.
Dec 28, 2008 | Home
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
