Question about Consew Sewing Machines
Sewing machine motor ps-6 manuel - Consew Sewing Machines
The brother sewing machine is a PS-1750 . What happened when you started sewing and the foot control is moving ,but the machine is not.
could be something wrong with the motor, or a wiring problem, make sure the foor pedal plug is making secure connection with the machine also
Jun 11, 2015 | Brother Sewing Machines
Manuel for a brother xl 5011 sewing machine
Please type find manual ..... on the internet. You should get several links. At times some manuals are the same for other sewing machine, and the link should let you know.
Apr 07, 2010 | Sewing Machines
Buttonhole problem
When doing the button hole....after installing the button hole foot and lowering the foot....and adding the button so the automatic button hole size is determined...you lower the button hole lever it will touch the back of the button hole foot. this holds the button hole foot in the proper position...if this lever is not all the way down...the machine blips at you...check to see that it is down all the way...I hope this helps you..It truly does all that it advertises and is a great machine...BBill01
P.S. you can adjust width and length of the stich also...see instruction manual. pg 28-30
Jan 06, 2007 | Juki HZL-E80 Computerized Sewing Machine
Sewing Machines Logo
43 people viewed this question
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Shehu Pro
Shehu Pro
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
