Question about KitchenAid Kitchen Ranges
Getting error code f1e6 in kitchenaid superba range
Whenever I try to use the oven to bake or broil, it starts ok, but after 5 minutes or so it shuts off and gives me error code F1E6
    Top Expert:
  • KitchenAid Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 27, 2012
  •  Henry E Corniel-Lantigua
    KGS0A906PSS00. Also, I had the control board replaced and the issue persists.
  • Richard Roth
    Richard Roth Nov 27, 2012
    Check all the wiring connections to be sure they are seated correctly and making good contact.
SOURCE: Kitchenaid Superba Gas Range
It appeared to be something to do with the plenum and cleaning - repair man came - cleansed and it was okay. MK
Posted on Aug 31, 2008
  • 126 Answers
SOURCE: Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Posted on Dec 10, 2007
  • 833 Answers
SOURCE: Oven will not bake or broil
bann...why did you replace the element? It is possible that the relay or the control circuit were the problems and still are. The hi limit switch is a temperature 'box' which is designed to open the circuit in case of overheating. Rarely a problem. First, these units are 3 wire units. That means 220 volts ... two breakers. They may be part of a linked unit or separate. Turn them BOTH off and then on. Do all of your burners heat properly on high? If you have a voltage tester, you can test to see if the voltage is there. Unplug the unit. The vertical slot is neutral. Each of the other slots with the neutral should light the tester. If not, your problem is outside the stove.
Posted on Dec 12, 2007
SOURCE: Fan runs when oven is baking or broiling
Yes, this is normal.
Posted on Apr 07, 2009
SOURCE: Just purchased a Tappan TEF326FB and oven will not
After much effort, and thanks to ABSOLUTELY NO HELP from Lowe's (where I bought this range) OR any of the contact numbers their 1-800-# referred me to (ie. SEARS Appliance repair in Californina, Chicago, etc.) or the the local Warranty repair service here (where we were finally referred to - they were "too" busy" to come look at it until 7 days later on June 25),
I managed to find out that the "F30" error code meant an "Open probe connection". and to "check resistance at room temp & compare to RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Chck Sensor wiring harness between EOC & Sensor Probe connection". I had no way to troubleshoot all of this or even to know where to look for the RTD probe or the wiring harness hookup. By the time I was able to find out what the error code mean't, I had taken the range back to Lowes where they tried to tell me that they shouldn't take it back because I had bought it a week earlier - even though It sat in the box and was not installed until 7 days after purchased. They finally took it back.
I promptly went to another appliance dealer (not Lowes or Sears) and bought a similar range which worked fine upon hookup. Too much hassle dealing with these folks.
Posted on Jun 19, 2009
Getting an F15 error code when trying to start Oven.
Error code f15 'Frigidaire FEB30T7FC Stainless Steel ...
www.faqqq.com/.../error-code-f15-frigidaire-feb30t7fc-stainless-steel-ele...
Error code f15 'Frigidaire FEB30T7FC Stainless Steel Electric Double Oven ... I'mtrying to open up a Unity3D game.exe that is on a remote computer through my main desktop. ... How 2016 will be the start of your virtual reality future - CNET.
Kenmore range shows f15 error code - ApplianceJunk.com
appliancejunk.com > ... > Forum Index > Range, Oven & Cooktop Repair
Oct 31, 2010 - 10 posts - ‎5 authors
Kenmore range suddenly started flashing f15 error code. With Thanksgiving just around the corner, i need help with this repair. Thanks.
Dec 30, 2015 | KitchenAid Kitchen Ranges
My frigidaire fef368gch was working fine and then the oven just stopped baking. It will broil but not bake. What causes this and how do I fix it?
Good Morning Shari,
I see that you are having trouble with your Frigidaire range, model# FEF368GCH, and the bake element not working while the broil element is. I suggest giving your appliance a hard reset, by shutting the power off at your home's circuit breaker, for 2-3 minutes. When power is restored, you will have to reset the clock by entering in the time and pressing start. Start a bake cycle, and if you notice that the bake element is still not working, I suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
WP
Apr 23, 2014 | Frigidaire FEF368GC
Kitchen Aid Superba double oven
f5e1 is a door locking error. try shutting off power for a minimum of 2 minutes to reset the control board. If you still get the error replace the latch. Here is the part to order.
Jun 19, 2013 | KitchenAid Architect Series KEMC308KSS...
Kitchenaid kgrc608
Try this,
FAULT ERROR: F1 E3NOTE:Make sure harness to P1 connector is correctly installed
per wiring diagram before performing the following steps:
STEP 1 Power off and wait 5 seconds.
STEP 2 Power on and wait 5 seconds.
STEP 3 Press the following keys:
CONVECTION - CONV. BROIL CLEAN BAKED GOODS 190 TIMER SET
NON-CONVECTION - CLEAN STOP TIME 0 OVEN LIGHT 1
STEP 4 Press START.
STEP 5 Make sure Timer ID is the same as the oven.
STEP 6 Press CANCEL to exit.
Nov 27, 2012 | KitchenAid KGRC608LSS Gas Kitchen Range
Error code f1 e3
Try this out,
STEP 4 Press START.
Nov 27, 2012 | Kitchen Ranges
The oven preheats, but then "cools down" before I
Most likely the problem is your bake element. When the oven is preheating it uses both the bake and the broil element. When it's done preheating it uses only the bake element, so the broil element is heating it up, and since the bake element is not working the temperature drops until it starts preheating again.
Jan 30, 2011 | KitchenAid KERS807SSS Electric Kitchen...
Upper Oven doesn't heat in bake or broil. Lower /Ctrl panel OK
check to see if both ovens are the same circuit if they are you have a internal problem with your upper oven internal circuits or damaged wirering contact a qualified service tecnitian
Oct 07, 2009 | Ovens
Oven flashes F2 and beeps in the middle of baking or broiling something. Our oven is all electric and recently whenever we start to broil or bake something, after a little while it will shut off and the...
HI. an F-2 during a baking cycle is the result of an out of control oven temp that has reached Temperatures above 615F-630F
If this actual over temperature condition occurred, Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred, Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Aug 04, 2009 | GE Ovens
Open Questions:
Kitchen Ranges Logo
365 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
