It's a whirlpool, maybe 6 months old... Started a load and it just stopped in the middle of the first wash cycle.
  • 14,363 Answers
Unplug from wall, wait a minute,then plug back up and see if that works. May reset it.
Posted on Nov 26, 2012
BUDDY08
  • 128 Answers
SOURCE: Whirlpool LSB6300 died mid-cycle now only clicks
HOPE THIS WORK, DON'T FORGET TO RATE ME
  • Timer is fried.
  • Washer went off-balance and tripped the off-balance switch.
  • Posted on Dec 28, 2008
    jsrock516
    • 5911 Answers
    SOURCE: whirlpool Ultimate Care II Washing Machine Rinse cycle not workin
    Most of these spin related problems are attributed to a lid switch malfunction. A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
    http://www.fixya.com/support/r385198-replacing_lid_switch
    If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
    Let me know if you need further assistance. I hope this helps you.
    Posted on Jun 30, 2009
    • 142 Answers
    SOURCE: Shows OE error. Won't spin
    if its only 6ths old call out the manufactures.
    Posted on Sep 28, 2009
    milten1
    • 1304 Answers
    SOURCE: in the middle of a cycle, it has stopped and is
    nf is NO fill
    i would check your cold water line
    take it off the machine and check the screen as well
    no fill means it is timming out waiting for water
    Posted on Oct 09, 2009
    SOURCE: flashing code F71 then F70
    We've owned a Whirlpool Duet Washer (WFW9200SQ00) for about 3 years. We started getting the F70 error code intermittently about 6 months ago and it seems to progressively be getting worse. Unplugging the unit for a few minutes resets the error, but it comes back about every 2nd or 3rd load causing my wife a lot of frustration and with 4 kids, our laundry was backing up. After reading several Forum's, I found the F70 error code indicates a "heartbeat" communication error between the various electronic boards inside the washer and the consensus seems to be the most likely culprit is the Motor Control Unit (MCU) board. Before spending nearly $250 for a replacement board (http://www.helpfulparts.com/servlet/the-5733/8183196/Detail) with no guarantee that it would fix the problem, I decided to take the board out of the machine and inspect it. What I found is the connector for the communication (the connector with three blue wires) on this board is a very unreliable connector that uses the edge of the printed circuit board on one side of the connection instead of a real connector soldered to the board. In addition, the fit of this connector seems to loose to make a good connection. I noticed a little bit of corrosion on the board contacts which I cleaned with rubbing alcohol and a pencil eraser. After re-installing the cleaned board we've done several loads with (keeping my fingers crossed) no errors. I am still concerned about the reliability of this connection. Because of it's location, this board is subject to a fair amount of vibration and because of the loose fit I'm concerned that this issue will only come back over time. I've already decided that if the error comes back I will solder wires to the contacts on the board to provide a more robust connection. It's a shame that you can spend well over $1,000 on a top of the line washer, and in order to save $.10 Whirlpool decided to use a very poor connector in a critical area. It makes you wonder where else did they skimp to save a few pennies?!! Our next washer will not be a Whirlpool, and next time will not get a high end washer with all the bells and whistles.
    Posted on Jan 03, 2010
    IT OFTEN (MORE AND MORE LATEY) WILL STOP IN THE MIDDLE OF A WASH CYCLE AND FLASH F 11 AND SOETIMES DL- I CAN'T GET IT TO START AGAIN. IT USE TO HAPPEN ONLY DURING NORMAL WASH CYCLE, BUT MORE RECENTLY, IT...
    F11 indicates a problem with the Motherboard that goes into the Computer Control Unit.
    Is an expensive part (£150/$200) plus labour so maybe time to just move on......
    Dec 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Sep 28, 2009 | LG WM-2277HW Front Load Washer
    Leaves white marks on coloured clothes
    I'd try putting the machine on a hot fill wash, max water level put in half a cup of baking soda when the machine starts to washer turn it off and leave it to soak overnight, then let it finish the cycle the next day. Also make sure you tip some of the hot water down the beach dispenser and clean all around the top of the machine
    Cheers
    Mar 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washer stops in middle of cycle,
    Junk it! Cut you losses now. I had a Calypso for 6 years and went through 3 pumps, various circuit boards , a drive motor ,etc..... not to mention the down time of not having a washer in a 4 person household. We bought a Whirlpool Duet HT 9200. Clean , fresh laundry not all balled up anymore. Junk it. You'll thank me.
    Nov 01, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
    Washing Machines Logo
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
