Question about Frigidaire Affinity ATF6000F Front Load Washer
How to put the washer in test mode - Frigidaire Affinity ATF6000F Front Load Washer
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
Here is the service manual.
Posted on Nov 27, 2012
What is the button combination to put the LG washer in test mode?
i believe it is the power button along with the two center buttons on the right.
Mar 30, 2015 | LG WM2701HV Front Load Ultra Capacity...
How do I put my Frigidaire front loader into test mode?
Hello Angel BriBri, that's a great question!
I see that you would like to put your Frigidaire washer into test mode and you do not have the available buttons listed on the average test. Could you please provide me with your model number? You can usually locate the model number on the serial tag which can be found on the door frame of your washer. With that information I can look over your manual to see if I can locate the diagnostic mode. I look forward to assisting you. -Matt
Oct 18, 2014 | Frigidaire Washing Machines
The washer comes up "TEST" instead of the
Hello & Welcome to FixYa
Someone accidentally put it into TEST mode and to get it out of the test mode follow this:-- Unplug the washer for 4 minutes and then plug it back and press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off. Please get back to me if you have any other questions.
Kevin
Feb 15, 2011 | Hotpoint Aquarius WD640 Front Load...
Control lock light is on and cannot get the washer to do anything
Try putting the machine into diagnostic mode. If it won't enter diagnostic mode, then you need to replace the main control board.
DIAGNOSTIC TEST
The washer must be empty and the control must be in theOFF
state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
?Close the door.
?PushCONTROL/ON(if present on this model).
?Select theDRAIN/SPINcycle.
?SelectNO SPINby pressing theSPIN SPEEDtouch-pad.
?PushPREWASH OPTIONfour times within five seconds. (If
PREWASH OPTIONis not present on this model, pressEXTRA
RINSEfour times within five seconds.) C:00 will light up on the
display.
If the Starting procedure fails, push thePAUSE/CANCELtouch-pad,
then repeat the starting procedure.
Test Program Control
In order to advance to the next step of the test procedure, push
PREWASH OPTIONtouch-pad two times. IfPREWASH OPTIONis not
present on this model, pressEXTRA RINSEtwo times.
Dec 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not start. The control lock light is illuminated on the washer panel. I unplugged the machine and replugged it in. Washer still displays "control lock" Any suggestions?
DIAGNOSTIC TEST
?Close the door.
display.
Nov 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I put a Kenmore 417.44092500 into test mode
Each one of these washers comes with a technical datra sheet inside. The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. Some model washers have two versions of diagnostics that include SHORT and LONG step modes to include simple and more advanced troubleshooting procedures. Since the procedures for entering diagnostics differs between models, it is recommended that you refer to this tech sheet to ensure you perform the procedures correctly.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
Read through the information provided and let me know if you have any further questions. I hope this can help you.
Apr 07, 2010 | Kenmore Energy Star 44092 Front Load...
I have somehow managed to put my hotpoint aquarius into test mode
To get out of it you need to press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off.
Mar 15, 2010 | Hotpoint Aquarius WD640 Front Load...
Resetting washer
FOR MOST JUST UNPLUGGING AND RE PLUGGING BACK UP SHOULD RESET UNIT. IF YOU HAVE MANUEL CHECK TO SEE IF THERE IS A TEST MODE YOU CAN PUT IT IN AFTER UNPLUGGING AND REPLUGGING .
Mar 03, 2010 | Maytag EPIC MFW9700S Front Load Washer
Washer will not drain (nd help code)
I found that one the plastic features on the bottom of the pump housing that mount the pump to the sheet metal floor of the washer had broken off. This allowed the pump to move around during opperation which cause the power connections to become loose and have intermitant contact. I cleaned up the connections and used shills to tighten up the pump mount and it works fine. Pretty dissapointing to pay a "qualified" technician to come and overlook such a simple problem and tell me to buy a new board :(
May 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
The display says test no matter wat program i put it on. how can i get it out of test mode please
i think u must press 2 funktion keys together to switch off from the test or demo mode
try to check the manual
May 15, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Frigidaire Affinity ATF6000F Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
