Question about Viking Designer Series DMOR200SS
How do I fix a viking microwave if the display light is very dim?
Microwave model RMV320SS clock/timer light dim
For Viking RVM320SS, that would be a fault in the backlight circuit.
If you're in the US or Canada, I regularly repair and upgrade these with the aim of correcting and preventing display errors. For details, feel free to contact me via my site below.
Always include your FULL model number*, FCC ID number*, and detailed symptom information. * from the tag in the cooking cavity or elsewhere on the oven (or send a clear photo of tag)
William E. Miller
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Jan 20, 2017 | Microwave Ovens
The light is dim with the door open or closed running.whats wrong?
Lights lowering in the kitchen when turning on microwave ...
diy.stackexchange.com/.../lights-lowering-in-the-kitchen-when-turning-o...
Nov 4, 2012 - Lights lowering in the kitchen when turning on microwave oven: symptom of an ... In the best case, this may be normal if the dimming is minor.
Possible causes of dim Microwave Oven display ' All About Circuits
forum.allaboutcircuits.com > ... > Electronics > General Electronics Chat
Jun 13, 2013 - I've seen some Microwave ovens that will not display a backlight anymore. They still work, but the display is so dim, you have to be inches away to. ...Monitoring the output of a light-dependent resistor, or photoresistor, allows ...
What Is Causing My House Lights To Dim?
blog.1000bulbs.com/what-is-causing-my-house-lights-to-dim/
Dec 21, 2015 | Microwave Ovens
Light is dim
Why do my lights in my house dim when I use the Microwave or dryer ...
https://answers.yahoo.com/question/index?qid...
Jan 16, 2010 - I dont run a lot electricity. It seems that if I run something like themicrowave any lights that are on dim. Is something wrong here? I dont see why ... Light on microwave too dim to read -- can it be fixed? ' Yahoo ...
May 11, 2014
My lights dim when I turn on a powerful electrical device ...
Dec 31, 2007
Why causes all the lights to dim and then brighten repeatedly ...
Dec 28, 2006
More results from answers.yahoo.com
Dimming Microwave Light - Breville Support
brevilleusasupport.com/bmo734xl/dimming-microwave-light/
Apr 10, 2014 - Occasionally, when using power settings that are lower then the normal 100% cooking power, the light inside the microwave cavity may dim.
Whirlpool microwave g2 - Panel lights but no text visible
It is a logic problem or at least electrolytic capacitors that dim the display too far. The display could be repaired if it isn't a ic (logic) problem if it is then you need the whole display replaced
Nov 29, 2013 | Microwave Ovens
Viking microwave vmos200
mine did the same thing took back apart cleaned put back togerther no fix bout new one
May 10, 2013 | Viking VMOS200 Microwave Oven
The display on my Sharp Grill 2 Convection Model R 82ojs-f is too dim to read.
either the display is bad or the unit may have a setting in the menu for adjusting the brightness level
Dec 04, 2012 | Microwave Ovens
LCD display is working but very dim and hard to see
This is a common failure of the control panel assemblies of these and similar microwaves. We repair these control panbel assemblies nationwide for only $32.50. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 18, 2007 | Sharp R-326FS 1100 Watts Microwave Oven
Viking Designer Series DMOR200SS Logo
363 people viewed this question
Top Viking Microwave Ovens Experts
William Miller
William Miller
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Are you a Viking Microwave Oven Expert? Answer questions, earn points and help others
