Question about Propellerhead Reason 4.0 - Windows and Mac Upgrade Version for PC, Mac
Audio driver in reason 4 keeps disconecting
It will work for a while then dissconect. i go to preperences to try and get it working but then none of the audio drivers will work. they just dissconnect instantly. All other sound on pc is fine. If i restart the pc it works for about a minute then dissconects.
The error that comes up says, 'your audio driver has stopped working, please go to preferences and choose another'.
I have tryed reinstalling
If you could help it would save my life.
Thanks
  • 1 more comment
  • Anonymous Jan 11, 2009
    I have the same problem with Reason 4 + Vista 32bit sp1.
    My hardware:
    M-audio Profire 610 + Core 3 Duo 2GHz
  • Anonymous Feb 18, 2009
    I really really freek out with this ... everything is ok i have sound everywhere except the reason 4 .... it keeps saying me that the audi driver stooped working and that i must get another one .... whe can tell me what to do
  • kampmaniak Feb 26, 2009
    I have a similar problem. I installed a driver that came with my Behringer USB midi controller. When I start Reason without the midi controller connected via USB, Reason says that the driver could not be found. I know that's because the controller isn't connected, of course. But I also have to connect the USB cable to the very same port I installed the Behringer driver on, otherwise this driver can't be used. When I want to use a different USB port, that means I will have to select a different driver in the Reason Preference menu. It sounded a bit odd to me at first, but that's the way it works.
    There is a signal in Reason when I press a key on the midi controller, but no sound. Not even when I play a Reason song that I recorded earlier. Every other sound on my computer works though. When I select the ASIO Multimedia Driver, I do get sound in Reason, but at a very high latency.
Hey, this worked for me!
Edit: Preferences: Page: Audio Then simply change the 'Audio Card Driver' until you can hear reason playing sound.
Posted on Jan 18, 2010
  • alphaaomegaa Apr 13, 2011
    the same problem also happened with me!...i waz going ******* insane because of this!...thank you gutmantis for the solution!
Hello to all,
I came across a similar problem with all of the symptoms you described, although I use Windows 7 and a Edirol UA-25X.
With one particular song I am creating, the audio driver just stops responding right after a loop.
I figured that, since I have a template of instruments set as a default song to start making new musics, I removed the last instrument that I inserted and after an audio driver reset the problem stopped (note that the audio driver reset was tested before without success).
So my guess is for you to try removing some instruments and try. Maybe a sound sample is jamming the audio driver at a particular point.
I hope it will solve your problems.
Greetings from Portugal.
Flávio
Posted on Jan 15, 2010
The heating seat is not working
In driver's seat you must dissconect gray terminal with 3 pins and check contonuity between 1 and 2, and next between 2 and 3 pin. There should be continuity. If not, the heater inside seat is out of order. Passanger's seat has gray 4p terminal. There must be continuity between 2 and 3, and 3 and 4 pin. Don't dissconect yellow conectors (SRS)! If you are not sure dissconect first battery for 10 min. Btw, check first all fuses inside car (both side-driver's and passanger's)) and check under-hood fuses.
Apr 13, 2013 | 2004 Honda Odyssey
My sound isent working on reason 3
I can't remember if reason 3 settings are setup like version 4 and 5, but you should find the audio settings under the edit / Preferences menu. In the page drop down box press Audio. Now in the Audio Card driver, select DX Primary Sound Driver. This will use the same driver that windows does. If you see one that says ASIO use that as it is lowest latency. If that doesn't work you may need a better sound card. Reason 3 does not support a lot of generic sound cards. You might also try downloading the latest driver for your sound card, I could help you locate a driver if you give me the model of your PC and / the model of your sound card.
Chris
Jul 01, 2011 | Propellerhead Reason 3.0 (991010004) for...
Cant istall audio drivers
This page contains the XP drivers for your device.
Post your results back here, especially if you run into additional problems installing your driver...
Apr 10, 2009 | HP Computers & Internet
Fan wont quit
the fan switch is located in the rad.dissconect it and see if fan stops
Jan 18, 2009 | 1992 Volkswagen Jetta
My computer's sound does't work after formatting what shall i do
Go to the Compaq website. Use the support option. You should be able to find your system there with a list of drivers for it. Try the sound drivers one by one until you find the one that works. Make sure you delete the ones that do not work and keep only the good one. Hope this helps.
Dec 21, 2008 | Compaq Audio card Sound Card
Audio connection problems
its all about your sound device not working at all! you can work it as before jus reinstall the proper drivers then its done restart your pc after reinstalling the drivers and your problem is solved
Nov 27, 2007 | Computers & Internet
Problems with reasons 4 in mac book to be recongnized
did you install the UB drivers? And which version of the drivers? Which os are you running?
keep me posted.
Nov 13, 2007 | M-Audio Maudio USB Midisport 4x4...
Audio drivers
What is the exact Brand & Model # for PC? if you can find that out go directly to your Manufactures website and look under a link called Support/Download Drivers. This should help u find the exact audio drivers for that PC.
Sep 09, 2007 | Computers & Internet
Propellerhead Reason 4.0 - Windows and Mac Upgrade Version for PC, Mac  Logo
4,883 people viewed this question
Top Propellerhead Computers & Internet Experts
Chris Larocque
Nikki  Mclean
Nikki Mclean
Alun Cox
Are you a Propellerhead Computer and Internet Expert? Answer questions, earn points and help others
