Xerox phaser 6180mfp 123-314 error code
Control panel error 123-314
3 Suggested Answers
wrinaldo
  • 185 Answers
SOURCE: Xerox Phaser error code: 09,038.46:37640
The ink loader 133K27771 is probably defective
Whit
Item, Inc.
Posted on Aug 10, 2010
  • 92 Answers
SOURCE: Phaser 6180MFP has error code
Hi, the error code you mention suggests you are able to print a start page but still the error is constantly displayed on the device.
This error is related to a failure on the Fax module, originated by a possible corrupted job on the device memory.
3 Ways to solve this.
  1. Unplug the device from the power cord and leave it for around 10 minutes. Then plug the power cord back on. This will allow the memory to clean.
  2. Clean the memory. Before you do that print a configuration report to ensure you keep all configuration data, such as network information. On the front panel navigate to System > Admin Menu >Maintenance > Initialize NVM. Be aware this procedure might erase your network configuration. therefore is important to print the configuration report previously
  3. The same steps taken in Step2 will be required but done on a Diagnostic menu. For this I would advise you to contact Xerox to get an onsite visit.
Hope this helps. Regards,
Posted on Oct 04, 2010
My Westinghouse fridge reads CN AND ER on the control panel temperature settings
Communications error between the control panel and the main electronic controller. Unplug it for about 10 minutes, then plug it back in. If the error comes back, you have some bad components. It will need to be repaired.
Aug 02, 2016 | Westinghouse Refrigerators
FO ERROR ON OVEN
Seems F0 is a problem either with the control panel or with the key panel
Here is a test to find out whether its your control panel or control board:
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
You can go to this site to find replacements
Mar 14, 2008 | GE Profile JKP56 Electric Double Oven
The control panel is on but there is nothing display
did u check cable for control panel is it seated well in panel also check cable to other side to where cable goes to board if it,s fine then if u have another tested control panel swap with it hope fully will be fine if not then it would be board of control panel try and let me know
Feb 26, 2014 | Kyocera Mita KM-1650 All-In-One Printer
Ricoh aficio 3035/3045 error sc 672 not able to proceed to service mode also, kindly help me pls.
possible a bad operation panel replace or 672 B
After powering on the machine, the
communication circuit between the
controller and the operation panel is not
opened, or communication with
controller is interrupted after a normal
startup.
Controller stall
Controller board installed incorrectly
Controller board defective
Operation panel connector loose or
defective
690 A GAVD block I2C bus error
An error is detected in the GAVD
communication I2C control register of
the GABIC2.
I2C bus on BICU defective
691 A GAVD FCI block I2C bus error
An error is detected in the FCI
the GABIC2.
692 A CDIC GAVD block I2C bus error
An error is detected in the CDIC
the GABIC2.
700 B ARDF original pick-up malfunction
After the
Sep 21, 2012 | Ricoh Aficio 3045, 3035 Kit
Error codeE6 F2
Remove the power from the oven. Open the control panel and unplug the key pad ribbon from the control board. Assemble the control panel back and turn the power on. Wait a few hours.
If the error code came back on, replace the control board.
If the error code did not show up, replace the control panel (the key pad comes as a control panel assembly).
- The part number for the new control board AP3595759
- The part number for the black/stainless control panel AP3131755
Good luck.
Gene. __________________Hi I did some research for your oven and this is what i found , someone with the same problem , control board needs to be replaced , if you click on the web page below it will explain it to you , good luck Frank
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/1094-whirlpool-fault-code-e6-f2.html#ixzz1gYuqvZnV
Dec 14, 2011 | Whirlpool RBD275PR Electric Double Oven
What is Kenmore double oven error code "F7" mean?
For the F7 error code:
What color is your key panel? Black or White?
Aug 06, 2011 | Kenmore Ovens
Warning codes f2 & e3 on Whirlpool oven . Warning beeps alerted us to a problem.
good luck
Feb 27, 2010 | Whirlpool Ovens
GE JGBP85WEB5WW - F7 / E9 Error codes
Well first of all you determine if problem is with the Key Panel or Control by-
This error code means Function pad button stuck or Bad clock: Unstick button or Replace Electronic Range Control (ERC).
Post comments for more help or information........
Good Luck!!
Aug 31, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Error code e5-23
That's a "Control panel communication abnormal" error. That could be anything from a loose connector under the control panel to bad control panel boards or any of the boards in the back of the machine. If resetting the power doesn't take care of it, it might be toast.
Jan 25, 2008 | Panasonic FP-7750 Black and White Copier
162 people viewed this question
jasbo
jasbo
