Question about Xerox Phaser Office Equipment & Supplies
Xerox phaser 6180mfp 123-314 error code - Phaser Xerox Office Equipment & Supplies
pineworks
  • 4041 Answers
SOURCE: Xerox Phaser 8560 - error code 09 037 45 108564
Hi there
That's a ink loader error, due to the 8200 ink stick; to fix it:
- Power down the printer.
- Hold the back button and the info button at the same time, without letting go, power up the printer.
- Keep holding down the buttons until the XEROX logo comes fully to the center of the screen, keep holding for 2 more seconds, then let go. I'll take about a minute or two for the Diagnostic screen to come up, the display will turn blank and black.
- When the Diagnostic screen comes up go to down to the Function or Exercise option, there will be an option that says "clear ISC faults" it'll ask you to press OK to confirm, after you do then you will exit Diagnostics and the printer will reboot.
It should be fine until it happens again. Until all the 8200 ink is gone you will probably be doing this a few more times. Also make sure the 8200 ink is not jammed inside the ink loader, if it is then you have to un-jam it some how.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
SOURCE: Xerox Phaser 6180MFP i have replaced toners
Supposedly the 6180MFP allows the user to select a non-genuine mode (select "Non-Xerox Toner" on the maintenance menu). This option is listed on page 9-18 of the User Guide, and I think it's the same as the Non-Genuine mode described on page 1-38 of the Service Manual. However, when I actually look for this option on my printer it doesn't appear to be present. Maybe Xerox removed it and didn't update the documentation? Anyone else know about this setting?
Posted on May 11, 2010
wrinaldo
  • 185 Answers
SOURCE: Xerox Phaser error code: 09,038.46:37640
The ink loader 133K27771 is probably defective
Whit
Item, Inc.
Posted on Aug 10, 2010
  • 92 Answers
SOURCE: Phaser 6180MFP has error code
Hi, the error code you mention suggests you are able to print a start page but still the error is constantly displayed on the device.
This error is related to a failure on the Fax module, originated by a possible corrupted job on the device memory.
3 Ways to solve this.
  1. Unplug the device from the power cord and leave it for around 10 minutes. Then plug the power cord back on. This will allow the memory to clean.
  2. Clean the memory. Before you do that print a configuration report to ensure you keep all configuration data, such as network information. On the front panel navigate to System > Admin Menu >Maintenance > Initialize NVM. Be aware this procedure might erase your network configuration. therefore is important to print the configuration report previously
  3. The same steps taken in Step2 will be required but done on a Diagnostic menu. For this I would advise you to contact Xerox to get an onsite visit.
Hope this helps. Regards,
Posted on Oct 04, 2010
  • 304 Answers
SOURCE: I have error on my
116-324: Controller Error (Illegal Exception)
To access Service Mode, press Up and Down Arrows at power ON.
Go to EEPROM Test
EEPROM Test
? Start
? Processing
? Check OK
Performs write/read/verification of the test patterns (0xff, 0xaa, 0x55, and 0x00) on one byte at every 0x400 from the first address of EEPROM.
Posted on Sep 14, 2011
Will not print in color
You can find answers to your Xerox questions at www.xerox.com/support
If the machine will copy in color it should print in color.
After verifying that it will copy in color, verify your driver is capable of being switched from black and white to color. If there are no color settings then you have the wrong driver. The link above will take you to the support page where you can download new drivers.
Mar 26, 2013 | XEROX MULTIFUNCTIONS Xerox Phaser...
ERROR 016-782 XEROX 6180MFP with windows7.
While there is no specific download for Win7 for this KB, you could try one of the others:
http://support.microsoft.com/kb/916846
Sep 21, 2011 | Xerox Phaser 6180N Laser Printer
Phaser 6180MFP has error code 133-290 how to correct, and what is it.
Oct 04, 2010 | Xerox 6180MFP/N Printer
I have a Xerox Phaser 6180MFP and when I print #10 standard envelopes and #9 renturn envelopes the envelopes come out with badly pressed wrinkles on the end of the envelope that comes out last. I have...
I am looking for a diagram on how to print envelopes with my phaser 6180 mfp - when I put the envelopes in, it keeps telling me that I need to put paper in. where can I find such diagram?
May 21, 2010 | Xerox Phaser 6180N Laser Printer
There are a couple of possibilities here.
Is the printer on a 'page pack' contract ?
Are the toners really chipped for the printer you have ?
There are 8 printers (including the multifunction variants as yours is) that take a SIMILAR cartridge.
They vary in capacity and chip. Some remanufacturers don't realise and have been sening out cartidges for these with the wrong chip fitted.
There has also been a bad batch of chips (a while ago now).
The solution is quuite simple, contact your supplier tell them what the problem is (error message etc) and they should be able to check the cartridge in their test printer (a GOOD remanufacturer will have a test printer for each of the cartridges they produce - how could they test their product otherwise !!).
Oct 09, 2009 | Xerox 6180MFP/D Printer
Xerox phaser 6180 mfp error code 133-290
Before attempting to resolve the error 133. -290, print a copy of the configuration report on the copier / fax. Use the navigation on the front panel to access the configuration menu to get the impression. Review printing to make sure it understands the network settings. This is a protection against configuration settings being lost when you troubleshoot.
Clearing Memory reset the memory of the Xerox Phaser 6180MFP, Dell 3110cn or Dell Machine 3115cn to erase the stored contents and eliminate corrupted data. Disconnect the analog line and power cord from the printer. Wait at least 10 minutes. Then reconnect the analog line and the power cord. As the machine starts, press the "All Clear" "Stop" buttons to prevent automatic printing of the status page. Check the error display panel 133 to 290 times the machine is fully initialized.
Corrupt Adjustmen
Jun 20, 2009 | Xerox 6180MFP/N Printer
275 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
