How to find waste toner in canon ir 3045 - Office Equipment & Supplies
  • 168 Answers
SOURCE: Where is the waste toner container in a Canon 5020i?
ok on the right side of the copier lower right cover 2 screws pakes the panel off behind it is a large plastic bottle pull it out empty it put it back in. then in this order touch these keys... add func// 2 & 8 at same time / then add func again screen should change to serv mode.. then in this order touch copier / counter / misc/ waste toner / clear /ok turn off and on good luck
Posted on Jan 03, 2009
  • 59 Answers
SOURCE: Changing Waste Toner in CANON IR3245I
Open up the toner cover, undo the screw.
Then on the flat surface under the paper delivery tray there is a round cutout , remove this little cover to reveal a screw, undo this and slide the front cover off to the left. The waste toner bottle is now visible.
Posted on Apr 01, 2009
  • 153 Answers
SOURCE: waste toner
to change the waste toner on your IR 5055, stand directly in front of machine and look on the right hand side of it where the power switch is a black button on right hand sdie at the back and you will see 4 screws and a metal plate that will come off the waste toner bottle is in there just empty it out and refit to machine all will work, now on your IRC3170 just undo front door and you will see a clear bottle just undo the black screw and take out the bottle and you will see a couple of little clear windows in the bottle make sure you take them out and clean them before you emtpy the bottle, this is where the machines shines a light through it to tell if the bottle is full or not so make sure you have them clean. refit the bottle and all will be ok
Posted on Jun 01, 2009
  • 6 Answers
SOURCE: Toner waste container location
The waste toner is in the front, open front cover and the white bottle in the middle is the waste toner cartridge. Remove the black screw, and empty or replace the cartridge.
Posted on Jun 02, 2009
  • 40 Answers
SOURCE: Canon IR2018 keeps saying waste toner full
...the waste compartment is same unit in the drum unit...if you know how to take out the drum unit then you can see the waste compartment...but be carefull not to damage the drum...couse its will cost you a lot, the price of a drum is high...and if you can change the blade in the drum unit then you can emptying the waste toner...better call for the expert technician...
Posted on Jul 09, 2009
Show me a picture of the waster toner on canon ir3035
It's in the front of the machine,abowe the paper casette.Part number for the waste toner box is FM2- 0303-000
Oct 08, 2014 | Canon iR3035 Copier
How to solve canon ir 3300 error code e0000190000
Neele, Error code E000019-0000 is a waste toner full , to get rid of this error, remove the waste toner bottle located left rear side of the machine,dispose of waste toner and clean the neck of the bottle because waste toner could obstruct the toner sensor beam. Switch off then on, OK to use.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Thread Canon IR 2200 Error E000019 0000
Canon ERROR 19 Waste Toner Tank
Jun 13, 2014 | Canon (6981A002AA) for imagerunner 2200,...
Canon IR 3225 error 0000-191-0000
Error code E000019-0000 is a waste toner full error, in order to get rid of this error you need to remove the waste toner bottle located in the left side of the machine
May 31, 2014 | Canon imageRUNNER 3225 Black and White...
Canon ir 3045 error code E00002 0000
CANON IR 3045 ERROR CODE E000002-000, plz urgent rply solution
Dec 01, 2011 | Canon iR 2016i Black and White Copier
Where is the waste toner receptacle located on the canon IR 3300i
Lower rear right portion has a small vertical panel held by one screw. The waste bottle is behind this panel.
Aug 13, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Waste toner collection IR 5570
remove the small lower( rear)right side cover 2screw then you will see the waste bottle youcan pull it out and throw away the waste toner
Jul 15, 2009 | Canon imageRUNNER 5570 Copier
Canan ir 1018 make sound
Normally nise come from the drum unit when the waste toner is too full.Remove the waste toner by removing the drum unit and remove the waste toner plug and disgard the waste toner and reinsert the drum unit.
May 18, 2009 | Canon imageRUNNER 1023iF Black and White...
Canon IR 5070 waste toner?
If you losen the lower right cover of your machine you will find the bottel there.
This lower right cover you will find on the right side of the machine,it is the lower small cover.There is only one skrew to losen,remove the cover and then the bottle.Empty the bottle and put it back.
Hope this will help.
Nov 24, 2008 | Office Equipment & Supplies
1,369 people viewed this question
