Question about Asrock P4i65G Motherboard
No video on asrock p4i45G motherboards
4 similar computers and all have the same problem no video. when starting up I get three short beeps
  • Asrock Master
  • 3,606 Answers
Hello the homepage is here:
http://www.asrock.com/mb/Intel/P4i65G/?cat=Manual
3 short beeps: base 64 k ram failure.
If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Read more here:
http://www.computerhope.com/issues/ch000996.htm
Beep codes:
http://www.computerhope.com/beep.htm
The fault could also be: power supply, or bad capacitors on the mainboard.
Good luck
Posted on Nov 26, 2012
  • Andy Hillebregt Nov 28, 2012
    Thak you I fixed the problem on one of them and two are dead motherboards. The last one I ned to diagnose farther when I have time. Again Thanks
5 Suggested Answers
sodeep
  • 3267 Answers
SOURCE: i hava a asrock board k7s41 beeps three times
3 beeps means problem with the RAM. If u recently changed them, check whether they are clipped in their slots properly. If need be remove them, gently clean the contact points with a piece if clean paper & reinsert them in their slots carefully. I hope they are matching pairs with the same FSB..........sodeep
Posted on Jun 13, 2009
adnanbhatti
  • 1188 Answers
SOURCE: i want asrock audio and video drivers for asrock
Click on the link below and you will be navigated to a webpage listing all the required drivers. Simply click on the 'click here' button in the download column next to your required driver, choose any server and download will start. It is free of cost.
P4i45GV R5.0 Drivers
User manual is also available on the same page.
Thank you.
Posted on Oct 03, 2009
SOURCE: Asrock P4i45gv motherboard problem
i am remove the motherboard & plaste the headsink inthe cpu cooling fan then start my computer cpu fan is running but no cpu heet no beep sound
Posted on Feb 26, 2010
rustysheriff
  • 344 Answers
SOURCE: what does a AMI bios beep code of one long and 9 short
AMI BIOS beep codes Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code
Descriptions
1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed
Posted on Jun 01, 2010
Need a motherboaed
check video card and ram out maybe wrong ram or not in right
Nov 17, 2013 | Asrock AM2NF6G-VSTA Motherboard
Motherboard starts but no signal in the monitor
Hello here is the cpu list:
http://www.asrock.com/mb/Intel/P4i45G/?cat=CPU
Other cpu`s than them on the list, does not fit the mainboard.
This will cause the mainboard not to boot up, when the cpu is wrong.
The (wrong) cpu will fit the socket, but it does not fit the cache size, fsb, and so on.
Look also in the manual:
http://www.asrock.com/mb/Intel/P4i45G/?cat=Manual
The problem could also be the power supply failing, try to change that.
Did it boot up before you changed the cpu ???
Any beep codes ??
Look also at this page:
http://www.tomshardware.co.uk/forum/261145-13-perform-steps-posting-boot-video-problems
Good luck
Feb 17, 2013 | Asrock P4I45G Motherboard
What are the elitegroup Computer system Beep error codes
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Jul 05, 2011 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
I want intel asrock 845 motherboard driver pls give me the link for free download
Here is the link you required,
1. www.asrock.com/mb/faq.asp?Model=P4i45G
2. www.chipdrivers.com/driver/motherboard/asrock/845gv-m
3.www.downloadatoz.com/driver/.../4696,asrock-p4i45gv-motherboard-driver. html
Let me know that i Fixya the problem.
Thanking you,
B.Krishnamacharyulu
Nov 08, 2010 | Intel D845GVSR Motherboard
Pc keeps beeping 3 times and nothing on the moniter
remove the RAM(MEMORY CHIPS) from *********** board and reinsert.if the problem is same replace the chips,get new chips.mostly cleaning the golden lines on the chip with pencil/school rubber solves the problem.
No beep is usually a power problem that can be related to the power supply, motherboard or both. Always check your battery power before thinking there is a bigger problem.
Step3
One beep is a normal POST. That means everything is fine. Two, Three, or Four short beeps are normally about the memory of the machine. If there is a problem with one of your memory chips you should get beeps of different combinations in this area. If you get two or three short beeps, one or both of your memory chips could be in trouble.
Step4
Five beeps point toward motherboard or CPU problems. Make sure your memory and video card are seated properly. Try removing them and putting them back in, only if you are comfortable with computers. Six, seven and eight beeps. Eight beeps indicate problems with your video card. Six or Seven are CPU, or a bad chip on the motherboard. Nine beeps mean the BIOS is bad. Replace the motherboard. Ten beeps means the problem is in the CMOS. All chips need to be replaced.
thanks.
Jul 11, 2009 | Asrock 775i65G Motherboard
Give computer graphic for make ivcons small
open link and download driver.....
http://www.asrock.com/mb/download.asp?Model=P4i45G
Jul 01, 2009 | Asrock P4I45G Motherboard
HOW TO GRAPHIC CARD
Hi im josh in cebu phils. may i helped you? It simple problem friend. since your motherboard is p4 and it has an avp slot not pci e.You buy AGP graphic card having a higher memory 256 or 512 mb and 128 or 256 bit. so that you will get the the best performance on that p4 board. i suggest to get higher ram and bigger hard disk space and a sound card for maximum performance.Good luck..
Feb 16, 2009 | Asrock P4I45G Motherboard
Asrock P4i65G Motherboard Logo
149 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
