Question about Makita 8444DWDE 18V 1/2" MXT Hammer Driver - Drill Kit
I need a bearing or all rotor for my makita hammer driver drill
8444dwde hammer driver drill
  • 2,176 Answers
They dont list just a bearing for the armature. They sell as an assembly. The part number for it is 629831-4. if you want to look at a breakdown of this tool go to Makitatools.com and type in your model number and click on parts breakdown.
Posted on Jan 10, 2009
How to replace chuck bearing for makita hp1630 hammer drill.
is this the bearing that is gone ..its on the armature
ifit is you have to take the casing apart
Jun 29, 2016 | Makita Drills
Chuck jaws on my dw960 arent aligned
It sounds like that the chuck jaws are out of alignment. You will need to get a new chuck.
Nov 09, 2012 | Makita 18 Volt Cordless Hammer Drill Kit ...
Bhp452 makita cordless drill smoking. how can i troubleshoot?
the switch or motor is wired incorrectly. These parts are polarity sensitive. The smoking I would assume is from the old switch and now the rotation is reversed. Let me know if you need more assistance.
Dec 10, 2011 | Makita 18 Volt Cordless Hammer Drill Kit ...
Cant assemble my makita battery gun i need a diagram
go to makitausa.com and you can download a parts schematic. You will need your model number for this. Let me know if you need more assistance and if you do I need the model number also.
Oct 13, 2011 | Makita 18 Volt Cordless Hammer Drill Kit ...
The screw point got stuck inside of the makita
Low quality steel drill bits get stuck in the Makita because the hammer impact squashes the metal, forming a ridge that gets snagged on the anvil's steel ball bearing. Use only impact drill bits.
Sep 15, 2011 | Makita 18V LXT Lithium - Ion Cordless...
How to dismantle a makita HP electrical hammer drill, want to replace the brushes
Check out the split drawing on this page.
If your makita does not have any outside accessible brush caps, you need to dismantle it.
lay it on the side, where the side with the screws securing the to halves together is facing up.
Remove all screws (some may be hidden under labels etc.) Gently pry the halves apart, locate the brushes disconnect their leads if any, and remove. Install new brushes and make sure the move freely, and that they are springloaded when in place. Gently rotate the rotor to ensure everything is ok . Reassemble and test drill. If the brushes leaves long streaks of noticeably large sparks, something has gone wrong or the rotor was damaged in the first place, causing excessive wear.
Sep 13, 2010 | Makita HP1620F Electric Hammer Drills
How to pull apart makita 6980 impact wrench
the battery is removed. remove all screws around the outside of the drill/driver. the side comes off. the motor is a johnson motor connected to the planetary drive and hammer/anvil assembly. the motor drive extends inside the anvil via one gear off the motor. the hammer and anvil come out as one piece. if you depress the center of theanvil with an arbor press, two ball bearings come out and the escapment comes out with the spring. now you can clean the inside of the hammer and gears of the hammer drive.
Oct 20, 2009 | Makita 12V Cordless Impact Driver -...
How to change a chuck on makita 8444 drill
Hi there, the chuck will screw onto the spindle of the drill but there is also a screw to undo. Open the chuch out fully then look down the centre of the chuck and you will find a philips head. The thread on the screw is opposite to the normail way so instead of undoing to the left, undo to the right.there should be threadlock on the screw so may be abit tough for the first turn. Once removed a strong pair of grips and a good tug should then remove the old chuck, some are more orqard than others to remove so just keep trying.
Oct 18, 2009 | Makita 18 Volt Cordless Hammer Drill Kit ...
Struggling to remove chuck from makita 84444d
K what you need to do is remove the chuck retaining screw LH threads and then switch the gear selector to low and the clutch to drill only. Find a bent handle allen wrench about the chuck capacity and lock it in the jaws. put the chuck on a workbench or block of wood and on the long part of the wrench have it at about a 30 degree angle and strike it counter clockwise and that should remove it. you might have to hit it a couple times
Aug 20, 2009 | Makita 8444DWDE 18V 1/2" MXT Hammer Driver...
My Makita handrill is not working. It's just like loose,and the drill is not rotating anymore.
Your bearings in the Clutch have fallen out of place.
Basically the tension screws pulling the clutch against the body.
Have became loose. If you Tighten them most likely wont fix it.
You should contact Makita. If you do open the drill. The Clutch assembly will be a task to reassemble. And the warranty might be voided.
Aug 17, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita 8444DWDE 18V 1/2" MXT Hammer Driver - Drill Kit Logo
239 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
