Purple Sanyo tv - Televison & Video
  • 97 Answers
Looks like there is no green colour on the tube, maybe just a tarnished connector at he back of tube, common prob with old tubes, you can try removing the neck board fron the back of the tube, gently wiggle it and pull back it should come off then push it back, on this often cures prob where the connecting pins become tarnished, be carefull not to touch the pins on the tube or the back of the neck board, you will get a shock! only hold the neck pcb by the edges, best switch set off and unplug for a few hours first! if this doesnt work, probly one of the colour drive transistors on the neck board is dead
Posted on Nov 26, 2012
  • Ryan Palmer Jan 23, 2013
    Thanks, it's a temporary fix, but extremely short. Looks like we're buying a new tv.
I have green and purple running up down my tv
the connections to the lcd are damaged an not easily fixed or cannot be fixed
reset the connection to the board an try its your only fix u can do.
Oct 19, 2014 | Sanyo Televison & Video
Tv problems troubleshooting
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 07, 2014 | Sanyo DP42849 42 in. HDTV
I have green or purple or dark lines scrolling up the screen on my Sanyo 42 inch plasma TV
These lines are often caused by interference. Try putting a filter on the input power plug. Make sure there is nothing near by that can be causing interference, like another monitor or computer, microwave oven, fluorescent light, etc. Make sure all the antenna leads are tight and the converter box well grounded. Is this dish or cable?
Oct 31, 2012 | Televison & Video
How do you fix a purple screen on a sanyo avm2752 tv?
One color missing is the problem to your set. There is no Green color output. Check this link, and find the post discussing about one color predominant screen. You can get more details there.
Sep 23, 2012 | Sanyo AVM-2759S 27" TV
Hello there is a green and purple line going across the screen
Please tell me whats the make and model of the tv so that I can help you out. This is because the cause of the problem varies with the type of the tv(LCD, Plasma, Projection tv etc.,)
May 09, 2011 | Sanyo Televison & Video
My kid ran a magnet across the screen now there's a purple blotch along the top of the screen.
The TV needs to be degaussed.
There is an automatic degausser built in but it may NOT be strong enough.
Try this: Turn off the TV and let cool for 10 minutes. Then turn on for one minute.
Repeat the previous sequence until screen is clear of blotches.
The cooling period re-arms the degausing circuit.
If this doesn't fix it adequately, you need to find a TV repairman that has a degausing coil... these are getting a bit rare now. It would take him ten minutes with the coil to fix it.
Dec 25, 2009 | Sanyo AVM-2506 TV
I have a rca 311 w to program into a sanyo tv
Code For Model RCR311W
Code 1004 for Sanyo TV Code 1048 for Sanyo TV Code 1049 for Sanyo TV Code 1073 for Sanyo TV Code 1080 for Sanyo TV Code 1162 for Sanyo TV Code 1169 for Sanyo TV Code 1180 for Sanyo TV
Jun 05, 2009 | RCA RCR311B Remote Control
Sanyo DS24425 Intermittent Discoloration
It seems like this problem would have to be with the picture tube itself, although I have never run into this symptom in over 30 years of servicing TV's. If the CRT is still in warranty I would get it checked out. Otherwise it probably not be worth repairing. If you end up replacing the set, check out the Toshiba 24" model. I have had good luck with that model in the past.
Feb 11, 2007 | Sanyo DS24425 24" TV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
