Question about Rubbermaid Commercial Products Used 4401 Plastic Trolly Utility Transport Cart
Do i take the rings off the casters before i insert them into the dowels?
The dowels are in now i can not push the wheels in far enough to click into the groves in the dowels should i take the rings off of the casters first?
How do i put the steering wheel back on my 1989 buick lesabre ?
If you look very closely you will see either a small demarcation or scatch on the center ring and steering shaft. Line these up and replace the washer and nut. Then torque to company specs. 25-35 ft lbs should surfice.
Mar 31, 2012 | 1989 Buick LeSabre
How do i remove an ignition in a gmc jimmy 2000 without a key?
Hello, Dan. First, disconnect the negative (-)/ground on the battery Dan are you mechanically inclined. If not then don't attempted this job.
You will need to remove all the plastic covers on the steering column. Remove the horn ring.--two screws under the steering wheel. Remove the horn ring and disconnect the horn plug. Remove the steering wheel nut. Use a steering wheel puller to remove the steering wheel.
Remove the turn signal switch that fit around the upper part of the steering column. Then remove the some of the parts that are associated with the steering wheel and/or column.
Now, look at the ignition switch flange, it a big chunk of aluminum. Now look for a large aluminum dowel pin 5/8" in diameter that is driven into the chuck of aluminum but it is parallel to the steering column.
This aluminum dowel pin will have to be drill out before you can get ignition housing off, If there is adjustable steering column lever, remove this also.
Now, once the dowel pin has been removed, looking for a **** in the ignition housing. Take chisel and insert into this ****, drive the chisel into the **** until the ignition housing is loose to be remove by sliding it up over the steering column.
If you buy a new ignition switch, on purchase the switch with keys. Don't buy the hole new ignition housing.. If you do it will get expensive.
In the ignition (old) housing drive out the ignition switch pins that keeps the ignition switch in the housing. Install the new ignition switch re-insert the ignition switch hold pins.
I am fairly sure that Carquest/ NAPA some other larger auto parts will have ignition housing bolt. If they try to sell you a replacement aluminum dowel pin don't buy it. It is almost impossible to install the aluminum dowel pin without the proper tools, so use a bolt to squeeze ignition housing together.
Before putting everything back together. Now, check the new ignition switch to make sure it works. I wish you lot of luck. GB...stewbison
Sep 27, 2011 | 2000 GMC Jimmy
How do the wheels install
10. You will find four casters (Figure B) and a dolly (Figure C) with your wet/dry vacuum. Assemble as follows:
11. If the casters are not already installed in dolly, insert casters into bottom of dolly by placing stem of caster into holes provided. Ap- ply pressure and twisting motion until casters snap into place (Figure 1).
12. With cord disconnected from receptacle and tank cover removed, turn tank upside down so that bottom is facing up.
May 29, 2011 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Need exploded view of 1995 dodge 2500 left front u-joint removal process. How does main bearing race come off?
FRONT DRIVE AXLE Hubs and Bearings REMOVAL & INSTALLATION Models 44, 60, 70 and 80 with Manual or Automatic Locking Hubs
  1. Raise the vehicle and install jackstands.
  2. Refer to Manual or Automatic Free Running Hub Removal and Installation and remove the hub assemblies. Fig. 1: Remove the outer locknut on the Model 60/70 front drive axle 88477g63.gif
  3. Remove the wheel bearing lock nut, using a hub nut wrench.
  4. Remove the lock ring from the bearing adjusting nut. This can be done with your finger tips or a screwdriver. Fig. 2: Exploded view of the front hub retaining hardware 88471109.gif
  5. Using a hub nut wrench remove the bearing adjusting nut.
  6. Remove the caliper and suspend it out of the way (see the brake section).
  7. Slide the hub and disc assembly off the spindle. The outer wheel bearing will slide out as the hub is removed, so be prepared to catch it. To install:
  8. Carefully position the hub and disc assembly on the spindle.
  9. Install the outer bearing cone and roller, and the adjusting nut. NOTE: The adjusting nut has a small dowel on one side. This dowel faces outward to engage the locking ring.
  10. Using a hub nut wrench tighten the bearing adjustment nut to 50 ft. lbs. (68 Nm), while rotating the wheel back and forth to seat the bearings.
  11. Back off the adjusting nut approximately 90°.
  12. Install the lock ring by turning the nut to the nearest hole and inserting the dowel pin. NOTE: The dowel pin must seat in a lock ring hole for proper bearing adjustment and wheel retention.
  13. Install the outer lock nut and tighten to 50-80 ft. lbs. (68-108 Nm). Final end-play of the wheel on the spindle should be 0.001-0.010 in. (0.025-0.25mm).
  14. Assemble the hub parts.
  15. Install the caliper.
  16. Remove the jackstands and lower the vehicle.
Model 44 With Full-Time 4-Wheel Drive
  1. Remove the wheel cover.
  2. Remove the cotter pin and loosen the axle shaft nut. Fig. 3: Remove the wheel bearing adjusting nut from the Model 44 front axle 88477g64.gif
  3. Raise the support the front end on jackstands.
  4. Remove the wheels. Fig. 4: Exploded view of the Model 44 wheel bearing adjusting nut, retaining washer and locknut in their correct relationship 88477g65.gif
  5. Unbolt the caliper and support it out of the way. DO NOT DISCONNECT THE BRAKE LINE!
  6. Remove the inboard brake pad.
  7. Remove the axle shaft nut and washer.
  8. Through the hole provided in the rotor, remove the six retainer bolts.
  9. Position pull C-4358, or equivalent, over the wheel lugs and install the lug nuts. Tighten the main screw of the puller to remove the hub, bearings, retainer and outer seal as an assembly.
  10. Insert a prybar through the U-joint and wedge the shaft inward as far as it will go. Make sure that it is wedged securely and can't be moved.
  11. Install the hub, rotor and bearing assembly and tighten the retainer bolts to 30 ft. lbs. (40 Nm) in a crisscross pattern.
  12. Install the brake adapter. Tighten the bolts to 85 ft. lbs. (115 Nm).
  13. Remove the prybar form the U-joint.
  14. Install the axle shaft nut and tighten it to 100 ft. lbs. (136 Nm), then continue tightening it to align the cotter pin holes. Install the cotter pin.
  15. Using the lube fitting, fill the knuckle with NLGI, Grade 2, multi-purpose EP grease until the grease is seen flowing through the inner seal. Fig. 5: Lubrication fitting location on the rotor top hat 88477g69.gif
  16. Install the inner brake pad and caliper (see Section 9).
  17. Install the wheels and tighten the lug nuts to 110 ft. lbs. (150 Nm).
Nov 05, 2010 | 1995 Dodge Ram 2500
Hi,I am a Diesal mec.for Peterbilt in Utah,I have 1998 dodge ram 1500 I found that I have the right front axle u-joint going bad I have the parts.I have heard some bad things of how hard it is to get the...
  13. Install the outer lock nut and tighten to 50–80 ft. lbs. (68–108 Nm). Final end-play of the wheel on the spindle should be 0.001-0.010 in. (0.025-0.25mm).
Aug 18, 2010 | 1998 Dodge Ram 1500 4WD
How to replace a Jaguar X Type fron wheel bearing
Jaguar 2000-06
Wheel Bearings
Removal & Installation
  1. Remove the brake disc.
  2. Remove and discard the retaining clip. Detach the ABS sensor.
  3. Remove and discard the O-ring seal.
  4. Remove the wheel hub and bearing retaining bolts.
  5. Remove the wheel hub and bearing.
  6. Prior to applying sealer, clean the ABS sensor sealing surface and the ABS sensor aperture sealing surface.
  7. Install a new O-ring seal.
  8. Apply a 2.5mm bead of Loctite Ultra Blue 587 Silicone (RTV) sealer to the ABS sensor sealing surface.
  9. Install a new ABS sensor retaining clip.
  10. Install the hub/bearing assembly. Tighten to 90 Nm.
  1. Remove wheel knuckle.
NOTE When removing the wheel hub from the wheel knuckle the bearing will be destroyed and the bearing inner ring will remain on the wheel hub.
Fig. Using special tools, remove the wheel hub-X-Type
  1. Using special tools, remove the wheel hub.
  2. Using a suitable tool, remove the bearing inner ring.
  3. Using special tools, remove the wheel bearing.
    Fig. Using a suitable tool, remove the bearing inner ring-X-Type
    Fig. Using special tools, remove the wheel bearing-X-Type
To install:
Fig. Insert special tool 204-312 in to 204-309-X-Type
  1. Insert special tool 204-312 in to 204-309.
  2. Support the wheel knuckle on special tools.
NOTE Make sure wheel bearing is correctly orientated with the colored side facing inboard.
  1. Align the bearing over special tool.
  2. Using special tools, press bearing into wheel knuckle.
  3. Change special tool 204-312 to 204-313.
  4. Align the bearing and wheel knuckle over special tool.
  5. Slide wheel hub over the guide and align to the bearing.
  6. Using special tools install the wheel hub.
  7. Install the wheel knuckle.
    Fig. Using special tools, press bearing into wheel knuckle-X-Type
    Fig. Change special tool 204-312 to 204-313-X-Type
    Fig. Align the bearing and wheel knuckle over special tool-X-Type
    Fig. Slide wheel hub over the guide and align to the bearing-X-Type
  1. Raise front of vehicle and support on stands.
  2. Remove appropriate road wheel.
  3. Using wire or string, secure brake caliper to road spring to take weight off brake hose.
  4. Raise vehicle sufficient to provide access for special tool 204-111.
  5. Install special tool 204-111 in road spring.
  6. Slacken tool adjuster to suit spring length.
  7. Install adaptor and thrust collar.
  8. Position stem of tool in center of spring passing dowel through slot in suspension turret.
    Fig. Install special tool 204-111 in road spring-XJ Range and XK Range
    Fig. Position stem of tool in center of spring passing dowel through slot in suspension turret-XJ Range and XK Range
NOTE When turning tool adjuster, ensure that tool stem does not rotate and disturb position of dowel in suspension turret.
  1. Engage dowel of special tool 204-111 in suspension turret and rotate to position across slot.
  2. Lower vehicle onto stands.
  3. Rotate tool adjuster to tension spring.
  4. Remove wheel speed sensor securing screw and withdraw sensor from vertical link.
  5. Remove nut securing tie rod outer ball joint to steering arm.
  6. Release ball joint from vertical link.
  7. Install special tool 211-098 on tie rod outer ball joint.
  8. Tighten tool bolt to release taper pin from vertical link.
  9. Remove special tool from ball joint and position tie rod for access.
  10. Remove nut securing upper control arm ball joint to vertical link.
    Fig. Install special tool 211-098 on tie rod outer ball joint-XJ Range and XK Range
continue...
Aug 03, 2010 | 2002 Jaguar X-Type
Roomba circles
Yes, this is known issue and if your bumper moves freely, you might be facing a sensor fault caused by poor quality of components.
Here is a guide to fix it
http://www.schneordesign.com/Avi/irobot/roomba_mod2.htm
Have fun
Avi
Sep 12, 2009 | iRobot Roomba 560 Robotic Vacuum
How can I remove a lodged oil dip stick? Top part of grip has broken off. Someone tried to remove it but lodged it in further down.
Needle nose plyers.
If those wont reach in far enough - you might have to remove the dipstick tube..
Jul 22, 2009 | 2004 Nissan Sentra
Scooba
Ensure that the front caster can spin freely, pivot, and rotate. Remove the caster by pulling it out and clear any dirt. Reinsert the wheel and lightly push the wheel up and down
Jun 30, 2008 | iRobot 5800 Scooba Vacuum
Rubbermaid Commercial Products Used 4401 Plastic Trolly Utility Transport Cart Logo
75 people viewed this question
Top Rubbermaid Commercial Products Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Rubbermaid Commercial Products Furniture Expert? Answer questions, earn points and help others
