Question about Runco Reflection VX-1c Multimedia Projector
How to connect runco VX101c processor with a projector
2 Suggested Answers
paul4265
  • 592 Answers
SOURCE: On my runco vx101c ,
Hi.
It sounds to me like the new bulb that you've purchased is just as bad as the old one that you took out.
If this was a regular flat screen tv, instead of a projector, then I would say that it was a cpapcitor problem.
But you said that the problem didn't come around UNTIL you replaced the bulb.
I wonder, does the bulb have a special way that it needs to be seated in it's plug?
It could be that it can only go in one direction in order for the contacts to work properly.
Now, it could be that, in removing the old bulb and replacing it, you might have damaged the solder for the socket, preventing the plug from getting a good connection.
Also, sometimes when replacing bulbs, other parts such as resistors can fail.
This can be to voltage instability, electrostatic discharge, power failures, and so on.
I would take the new bulb out, and take it and the old one to Fry's, or to BestBuy.
They both seem to have a rather well stocked supply area for bulbs, it could be that even though your bulbs might LOOK the same, they may be quite different as to the way they are made on the insides.
I hope this helps you out some, and good luck!
Posted on Mar 14, 2011
RunCo VX1000c RS-232 communication codes
Hi Kevin,
The manual for the RuCo VX1000c is available at http://www.aboutprojectors.com/pdf/runco-vx-1000ci-manual.pdf
The RS232 codes and protocols are towards the back of the manual. According to the manual, the PFP connects to the projector using a CAT5 cable.
HTH.
Jan 02, 2013 | Office Equipment & Supplies
How do I replace the bulb hours in my Runco Media VX-4000d Projector? I already replaced the bulb. Thank you for your help!
Please contact Runco support at 1-800-23-RUNCO. We can assist you.
Sal Di Giacomo
Runco International
WW Service Manager
sal.digiacomo@runco.com
Aug 05, 2011 | Runco VX-5000ci Multimedia Projector
On my runco vx101c , after changeing the old bulb to a new bulb . The runco turns on but the lamp wont turn on . Just a clicking sound from the lamp driver and 2 led light green and orange on the led...
You only want to reset if the projector doesn't turn on because it is a safety feature so the lamp does not explode. They get really hot and need to be replaced when due.
There is a reset button on the inside of the
RGB connection bay(look deep) for a reset button, hold it down until the lamp light turns blue.
If flipped over on it's back, you would see it straight down beyond the connectors. Of course this will reset to factory settings. let me hear how it goes good luck!
Mar 13, 2011 | Runco Reflection VX-1c Multimedia...
My RUNCO projector is projecting upside down and we cant seam to fix it. Any advice?
1. Press the menu button on the remote to bring up the on-screen menu. 2. Select the Setup Menu 3. Select Picture Orientation 4. Change the configuration so that the image and text appear correctly.
Feb 28, 2011 | Runco Reflection VX-1c Multimedia...
My Runco CL-410 projector runs for about 30-45 seconds, then the lamp turns off. The hour meter says it has 471 hours on it. Any ideas?
Look inside the lamp. If you look into it if you see any white build up at its base, replace it. Need help, let me know.
Jan 09, 2011 | Runco CL-410 Multimedia Projector
Reset lamp timer runco vx-5000
Using the remote control for your projector, turn the unit on, then select 'menu' on the remote. On the menu that pops up in the screen, select 'SERVICE', then 'DISPLAY DEVICE', then 'INSTALLATION'... once you select that, scroll over to the "RESET" under the lamp hours... this should reset it.
Here is a link to the owners manual for your unit.
http://runco.com/legacy_prods/legacy_manuals/VX4000d_5000d_manual-v3-1.pdf
Nov 01, 2008 | Runco VX-5000ci Multimedia Projector
Need to adjust from full screen to wide screen on Runco SC3050
You need to use the remote, press the Menu button... on the menu that pops up on the screen, use the remote to scroll down to where it says "aspect ratio", and then select enter.
From that menu, you can select all the different aspect ratios that your Runco can perform.
Here is a link for the owners manual, straight from Runco.
http://runco.com/legacy_prods/legacy_manuals/CL-510_510LT.pdf
Oct 11, 2008 | Runco CL-510LT Multimedia Projector
Service menu passcode for runco vx-1000d
I understand you have a VX-1000d.
You only want to reset if the projector doesn't turn on because it is a safety feature so the lamp does not explode. They get really hot and need to be replaced when due. You can buy one from the supplier or online.
Do you have the processor?
Normal 0 MicrosoftInternetExplorer4
Aug 21, 2008 | Runco Reflection VX-1c Multimedia...
Projector problem
I have a great deal of experience with that projector in particular.
The burning smell along with the circle on the screen can be one of two thing in the same general area. Both are not good.
The lamp assembly has its own dedicated cooling fans. these fans can sometimes **** in dust and insects. the lamp runs at a very high temperature and can burn those things quickly. I have often found old lamps with particles fused to the glass.
The other situation is that the lamp burned something and it got stuck to the glass somewhere in the light path.
if I remember right the projector monitors the temprature of the bulb and will shutdown if it gets too hot.
Runco is based in california and has a great turn around time on projectors. Unfortunately with Runco you would be hard pressed to find a technician that wouldn't just send it to them for repairs anyways. The major down side with Runco is that customers cannot talk directly to engineers or service men.
Locate a Runco authorized retailer in your area, check runcoes site. and give them a call to see if they cant send it to runco for you. if you cannot find one in your area call Roscor or Blair & Associates in Chicago.
May 02, 2008 | Runco CL-510LT Multimedia Projector
Runco Reflection VX-1c Multimedia Projector Logo
26 people viewed this question
Top Runco Office Equipment & Supplies Experts
Colin Stickland
Colin Stickland
Are you a Runco Office Equipment and Supply Expert? Answer questions, earn points and help others
